Old 02-09-2010, 10:54 PM   #1
240sxguy
Member#: 229791
2002 WRX wagon
Default Low fuel pressure 02' wrx, thoughts?
Fuel pressure pops up to 43 when first starting the car then after about 20 sec of idle it starts dropping down to the low 20s.. which directly follows
the a/f dip. I tested f/p before and after the filter.. same result. I
also tried two different pumps, and I know for a fact the car ran fine
on one of them.
This leaves either the f/p controller or... bad fuel pressure
regulator? I am going to do a bit more reading on this whole situation
to familiarize myself with the controller's function. I doubt it is
the FPR, and removing the fuel line doesn't change anything. Have any
thoughts?
Thanks guys!
Evan
240sxguy is offline   Reply With Quote
Old 02-10-2010, 08:39 AM   #2
rkramer
Member#: 118209
2015 WRX Limitec
The fuel pump runs at 3 different speeds (voltage levels) based on demand, maybe you are just seeing that?
Old 02-10-2010, 08:42 AM   #3
240sxguy
Member#: 229791
2002 WRX wagon
That was my initial thought as well, but 22psi of fuel is definitely not enough to atomize it well enough. Looking around here on the forum it appears that 42-43 with the vac off is more in the normal range (and really pretty much an industry standard).
I think the controller might be bad, I got this car with a blown motor so I am not entirely sure what has been done to it!
Thanks.
Evan
Old 02-10-2010, 09:18 AM   #4
xsnapshot
Member#: 170973
2004 WRX 4EAT
Subcribed. I think I'm having the same issue.
xsnapshot is offline   Reply With Quote
Old 02-10-2010, 09:31 AM   #5
240sxguy
Member#: 229791
2002 WRX wagon
xsnapshot, have you put a fuel pressure gauge on your car?
Old 03-07-2010, 05:53 PM   #6
240sxguy
Member#: 229791
2002 WRX wagon
The answer (as far as I know) was bad fuel controller. I bypassed it completely with a relay.
Evan
Old 03-08-2010, 01:11 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Evan
this may cause the frequent failure of the fuel pump as it isnt rated for 100% duty cycle and will burn it up
Old 03-08-2010, 07:24 AM   #8
240sxguy
Member#: 229791
2002 WRX wagon
Uncle Scotty, I have a walbro pump in my car. I run the one in my 240sx wide open every day.
I do plan on trying to find a new fuel controller though, thanks for the heads up.
Evan
Old 03-08-2010, 07:26 AM   #9
bboylocob
Member#: 151809
2007 WRX
go to dealer. my frind just had the same probl. he went to the dealer and come to find out it is a manf. probl. with the fuel lines. they had to replace the entire fuel lines under warrenty even though his is an 02
bboylocob is offline   Reply With Quote
Old 03-08-2010, 07:29 AM   #10
240sxguy
Member#: 229791
2002 WRX wagon
Yo mods, can we lock this thread? It has been resolved and the reason for the problem has been posted.
Evan
Lean condition via low fuel pressure? BadTrip UTEC 18 11-06-2006 12:23 PM
low fuel pressure notgm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-20-2006 08:37 PM
Suddenly, Low Fuel Pressure at idle?? IowaRS Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-02-2005 06:32 PM
Low Fuel Pressure, help! Diezel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-14-2004 03:32 PM
Low fuel Pressure ej20g joehack98 Subaru Conversions 12 01-26-2004 04:26 AM
