Old 02-10-2010, 10:53 AM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default 2011 Chevrolet Silverado Heavy Duty
GM is using the Chicago auto show to unwrap its latest salvo in the heavy-duty pickup wars: the 2011 Chevrolet Silverado Heavy Duty. Available in three-quarter- or one-ton strengths, the new Silverado HD is a workhorse aimed squarely at the new 2010 Dodge Ram Heavy Duty and 2011 Ford F-series Super Duty.
While it consists almost entirely of mechanical updates, rather than a complete vehicle overhaul, the new Silverado HD indeed appears to be a serious piece of work-site hardware. Although the company has yet to outline the improvements for the Silverado’s twin, the 2011 GMC Sierra Heavy Duty, the two should remain identical under the skin, with the GMC set apart by the usual unique aesthetic tweaks.
Harder Hardware and Smarter Software
While GM’s previous HD trucks were no wet noodles, the new Silverado’s underpinnings might as well be milled from solid billet by comparison. The basic formula stays the same—body-on-frame construction, a leaf-sprung live rear axle, and an independent front suspension supported by torsion bars—but every bracket, fastener, and crossmember has been substantially beefed up. GM says that the only significant components to be carried over from the 2010 chassis are the front end’s attachment links for the anti-roll bar.
The Silverado HD’s frame is all new and is now fully boxed for greater strength and rigidity. The truck is available in 11 different configurations, and the frame has been designed for easier mounting of a fifth-wheel hitch in the bed. The conventional rear-mounted hitch is more robust, too.
Maximum towing capacity is said to be a nice round 20,000 pounds with the fifth wheel—16K with the standard hitch—while payload capacity tops out at 6335 pounds. Ford has yet to release its ratings for the ’11 Super Duty, but the 2010 Dodge Ram HD is capable of carrying up to 5130 pounds in the bed and towing up to 17,600 pounds.
The rear suspension’s multi-stage leaf springs are wider, at a full three inches, and are of an asymmetrical design, both of which allow for greater load-carrying ability and improved axle control, according to GM. The independent front suspension—still unique to GM in this segment—has been completely redesigned and can now support up to 6000 pounds, and the minimum weight supported by any four-wheel-drive configuration is enough to allow a snow plow to be fitted. Despite the greater complexity of the GM trucks’ independent front suspension (upper and lower control arms made of forged steel and cast iron, respectively) versus its competitors’ solid-axle layouts, the company remains adamant that the setup offers the same capability while delivering a better ride and being easier to tune for specific applications. The company says the torsion bars can be adjusted with a wrench to compensate for the greater load that a snow plow would apply to the front end.
Along with larger disc brakes—14 inchers front and rear—a standard engine-exhaust-brake system, slightly wider front and rear tracks, and longer wheelbases ranging from 133.6 to 167.7 inches, several other electronic additions are new for 2011. Single-rear-wheel models come standard with electronic stability control, hill-start assist, and automatic grade braking, with a trailer-sway-control system as an option.
The Race to 700 lb-ft of Torque
While outputs have yet to be released, powertrains for the 2011 Silverado HD include a 6.0-liter OHV V-8 paired with a strengthened 6L90 six-speed automatic, as well as the turbocharged 6.6-liter Duramax V-8 diesel with an updated version of the Allison six-speed automatic.
The 6.0-liter**—rated for 360 hp and 380 lb-ft of torque in the 2010 model—gets variable valve timing and a new camshaft, among other tweaks, which GM says will offer a broader torque curve and better efficiency overall. However, the real news is the fourth-generation Duramax diesel, about 60 percent of which the company says is new for 2011. Along with new pistons, rods, and a revised exhaust-gas recirculation cooler, the new diesel is said to be both quieter than before and up to 11 percent more fuel efficient on the highway. Oxides of nitrogen emissions are down 63 percent, too. The common-rail, piezo-actuated fuel-injection system now operates at 30,000 psi and can run on B20 biodiesel.
The exhaust-treatment system has been optimized for 5000-mile service intervals between 5.3-gallon fill ups of fluid for the selective-catalytic-reduction system, while the diesel particulate filter can now go up to 700 miles (up from 400 miles) between regenerations, which helps reduce fuel consumption. Total range for the diesel is now up to 680 miles with the Silverado HD’s standard 36-gallon fuel tank.
GM says specific output for the Duramax is pending SAE certification. The third-gen Duramax made 360 hp and 660 lb-ft of torque—tops in its class—yet GM officials are optimistic that more than 400 hp and 700 lb-ft are in reach with the 2011 modifications. We expect details to come soon, along with specs for Ford’s new 6.7-liter PowerStroke V-8 diesel, which also has been rumored to be close to the 400-hp and 700-lb-ft marks.
The Shiny Stuff
Recognizing the 2011 Silverado HD will pretty much be possible only from the front, as the only changes to the body are a new raised hood with revised Duramax/Allison badges, as well as a new chrome front bumper. New 17- and 18-inch wheels are available across the range, while polished and forged 20s are available on 2500HD models.
The interior is largely carried over, which is fine; the 2010 trucks were well-appointed and very comfortable. The latest version of OnStar is available, as is mobile WiFi, USB, and Bluetooth connectivity. Touch-screen navigation, XM satellite radio, and a rearview camera remain optional, as do other luxury amenities. A slight increase in base prices is expected, but GM says it’s too soon to say how large of a premium the new capabilities will command.
More significant updates to the exterior and interior likely won’t come for another couple years, as GM only recently restarted development of the next-generation, light-duty Silverado and GMC Sierra, which are expected in 2013 or so. Fortunately, that gives us plenty of time to line up the new Silverado HD against the latest Ford and Dodge trucks for another heavy-haulin’ comparison test. Load ’em up
http://www.caranddriver.com/news/car...hotos_and_info
Old 02-10-2010, 11:06 AM   #2
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
um, 30000 psi fuel injection..
well, thats just wow.
SCRAPPYDO is offline   Reply With Quote
Old 02-10-2010, 11:19 AM   #3
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
More efficient and a far cleaner diesel? Good. We definately less toxic heavy duty vehicles.
Now if I'm wearing work gloves am I really able to push the tiny buttons on the Nav or even hit the correct HVAC. I think not.
SLegacy99 is offline   Reply With Quote
Old 02-10-2010, 11:21 AM   #4
SCRAPPYDO
Member#: 873
2014 GLK/allroad
wow, that dash is beyond crappy looking.
Old 02-10-2010, 11:44 AM   #5
White out
Member#: 46277
** LP640
Viper GTS
Very impressive truck.
Nick
White out is offline   Reply With Quote
Old 02-10-2010, 02:43 PM   #6
wrxsubaru
Member#: 65133
That is pretty impressive but I do not get who needs to tow around 20,000 and would want that type of interior. It seems like GM is putting a lot of R&D into a truck that is going go to a pretty small market. A lot of fleets are starting to realize that a standard 1/2 ton will do almost anything and are opting away from the heavy duty stuff except for some specific situations. How many people need to tow over 10,000 pounds regularly? There are some people that routinely do it, but it is a small group that is starting to realize the smaller cheaper option works fine. I would rather see focus more on its smaller truck line that sucks balls. A lot of people would buy a 4 cylinder diesel compact truck that could really tow 5000 pounds. It does not even need to be a diesel just a compact truck that does not suck that has some usability to it.
wrxsubaru is offline   Reply With Quote
Old 02-10-2010, 05:14 PM   #7
Masterauto
Member#: 198376
STI E30 M3
Nissan GT-R 15
Pretty good tuck already especially the locking diff real 4wd. Pulled a few Fords and dodges out in the snowstorm. their 4wd is just 1 wheel in front and 1 in back.
Dodge Cummins great motor but have not driven new one 2011 yet.
Ford powerstoke has many problem, very loud and poor fuel economy. They are making new diesel motor now so....consumer wins with completion.
Masterauto is offline   Reply With Quote
Old 02-10-2010, 05:23 PM   #8
Derbagger
Member#: 32113
05 Saabaru
Satin Grey
while the Ford look better, it's a work truck. who cares.
Derbagger is offline   Reply With Quote
Old 02-10-2010, 05:25 PM   #9
White out
Member#: 46277
** LP640
Viper GTS
There's no money in developing a new small truck line when they already have the 'new' Colorado chassis and the 4.3 Silverado will do exactly what you are asking for (so will extended cab/crew cab Colorado).
Nick
Old 02-10-2010, 06:23 PM   #10
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
I am in that 15K lbs towing demographic and it's hard to find a decent truck that you can use other than the huge 3500's and F350's.
mhoward1 is offline   Reply With Quote
Old 02-10-2010, 06:52 PM   #11
afviper
Member#: 89493
2001 330ci
Why would you wear work gloves when driving/getting ready to drive? The only time I could see myself wearing gloves in a car is when getting in a cold car in the winter. I hear these arguments that work trucks need large knobs and buttons you can operate with heavy gloves, but it makes no sense. I have had a job where I wore work gloves and drove a truck but I took my gloves off when getting in the truck.
afviper is online now   Reply With Quote
Old 02-10-2010, 07:47 PM   #12
daveyboy
Member#: 35419
Nick
I agree.
I know a number of contractors that need this level of capability but like a little coddling since they spend so much time in their pickup.
This weekend, using my Tundra, I towed 10,000 lbs, at 7000' elevation rescuing a trailer behind a Dodge Cummins... I would not want to do that on a regular basis with anything less than a heavy duty diesel... .
daveyboy is offline   Reply With Quote
Old 02-10-2010, 07:54 PM   #13
quentinberg007
Member#: 7887
Is 3 attachment on the torque converter to the drive plate normal? I've torn apart a few ATs in my day and they had 6 attachment points.... and these were CUV/van/sedan transmissions.
quentinberg007 is offline   Reply With Quote
Old 02-11-2010, 09:22 AM   #14
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Seems normal to me...
Old 02-11-2010, 09:26 AM   #15
SCRAPPYDO
Member#: 873
2014 GLK/allroad
when you have to pay 55000 dollars for this it better come with something other than crap inside. As soon as GM lost their damn mind with their pricing for trucks, people started to expect more. People want to feel like they are in a sedan comfort when driving a truck.
Trucks use to be cheap. Back in the late 70s early 80's, trucks were for work, and not much else. Then the big three learned that they could make 10's of thousands of dollars of profit off each one if they threw some nice seats in it.
In the hey day (read as 'the 90's), GM was making 12-14 grand of pure PROFIT off each overpriced suburban. And people were dumb enough to pay it. Those same people now expect more from trucks, and with fat profits on each one, the big three are happy to oblige.
THAT is why the interior needs to look better than a 12000 dollar cobalt.
Old 02-11-2010, 09:45 AM   #16
Masterauto
Member#: 198376
STI E30 M3
Nissan GT-R 15
India's Mhindra and Tata my have a truck for you soon, Basic work tucks may soon enter US market. Who knows what China may bring in soon. I saw this one hauling a load of logs up a mountain in the 90s inland China. A 1 cyl diesel belched smoke but pulled hard.They carried tremendous loads up mountains. I sure would not like one behind me going down hill. They used the compression to slow down. My guess the photo of the ones full of logs was carrying about 5,000 lbs or more.After hauling you could remove the bed and hook up a plow or other farm implement. I think you agree they don't get more basic than this.They cost about $800. back in mid 90s.
Old 02-11-2010, 12:49 PM   #17
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Lol. Sitting on those logs is about on par with sitting in a GM interior.
Not-EWRX is offline   Reply With Quote
Old 02-11-2010, 01:04 PM   #18
JuggernautTCW
Member#: 169223
wrong. GM doesnt use real wood in the interior, Lexus does though.
JuggernautTCW is offline   Reply With Quote
Old 02-11-2010, 01:14 PM   #19
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
jigga is offline   Reply With Quote
Old 02-11-2010, 01:42 PM   #20
SCRAPPYDO
Member#: 873
2014 GLK/allroad
ouch.. hahaha
Old 02-11-2010, 02:08 PM   #21
SilverSubaab
Member#: 88288
.... At this point,
even I have lost track.
My first thoughts, but I think it is the amazingly bad center stack that brings everything else down........
SilverSubaab is offline   Reply With Quote
Old 02-11-2010, 02:13 PM   #22
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
Finally!
With such a sturdy and powerful drivetrain, the truck deserves better under components. I see far too many GM, Ford, and Dodge trucks with 10,000 miles, and blown out ball joints. Or better yet, brakes that need full replacement every couple years. At the prices they're asking for these trucks, they better come with beefed up components.
steve is offline   Reply With Quote
Old 02-11-2010, 02:21 PM   #23
SkiWrex
Member#: 142559
05 Fozz XT VF39'd
05 PSM Fozz 2.5xs
I do not get who needs to tow around 20,000 ........ a truck that is going go to a pretty small market. How many people need to tow over 10,000 pounds regularly?
Dam dude, come to where I live, HD trucks are ALL the rage, the market for these trucks is HUGE all across the country. Truck lovers who don't tow 20,000 lbs. still buy these trucks because they are daily driver friendly, and it's nice to have the capability to tow if you need to. Plus Diesel engines are much more efficient when towing.
-Construction workers
-Hunters
-Weekend warriors (boats, trailers full of atv's, 5th wheels)
There's alot of people who buy these trucks.
SkiWrex is offline   Reply With Quote
Old 02-16-2010, 07:25 PM   #24
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
I worked for a construction co. for 6 years and I didn't take my gloves off when I drove around the sight, usually loading and unloading materials.
Old 02-17-2010, 01:39 AM   #25
doylfish
Member#: 88099
2004 Audi S4
2003 Suzuki SV1000S
GM used to make very nice interiors. Everything just looks like and feels like crap now ( i was checking out trucks with my dad a few weekends ago, not impressed by the visuals)
doylfish is offline   Reply With Quote
Whiteline Adjustable Heavy Duty 24mm Rear Sway w/ fresh paint & Heavy Duty End Links Keif MWSOC Private Classifieds 1 12-30-2009 07:37 PM
Whiteline Adjustable Heavy Duty Rear Sway Bar w/ fresh paint & Heavy Duty End Links Keif Suspension/Brakes/Handling 2 12-30-2009 07:36 PM
2011 Chevrolet Caprice Police Patrol Vehicle taking over streets in 2011 AVANTI R5 Non-Subaru News & Rumors 36 10-09-2009 01:22 PM
FlexFuel-Branded Chevrolet Silverado Pickup Truck NYCshopper Non-Subaru News & Rumors 0 02-06-2006 04:53 PM
VA: Whiteline Heavy Duty RSB mounts, Whiteline heavy duty rear end links corrie Private 'For Sale' Classifieds 9 01-17-2006 11:00 AM
