Old 02-10-2010, 12:14 PM   #1
Evolved8
Member#: 230476
Default Tech help HID HELP PLEASE give me some info
Did a quick search couldn't find anything, anyways...
Vehicle info: 2006 Subaru Legacy GT BONE STOCK
I bought a plug and play HID kit and I'm having some problems.
When i have the key in acc lights operate on and off fine. When I start the car one goes out and stays off. I have installed Warning cancelers but same problem occurs.
Can someone please chime in and help me out with this issue...
thanks in advance
Evolved8 is offline   Reply With Quote
Old 02-10-2010, 02:48 PM   #2
Evolved8
Member#: 230476
Anyone??
Old 02-10-2010, 05:57 PM   #3
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Did you disconnect your DRLs?
There is, however, a universal solution for this and all the future problems that you are going to have with that kit. Throw it in the trash.
FourOnTheFloor65 is offline   Reply With Quote
Old 02-10-2010, 06:32 PM   #4
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Old 02-10-2010, 07:13 PM   #5
TRDRacer
Member#: 212793
2003 Built 2.5L 35R
World Rally Blue
Disconnect your DRL's underneath your passenger side dash and not the one in the engine! Also I would recommend getting a relay installed with your HID kit and get some grounding kit to stabilize voltage as Subaru's alternators are complete garbage and can't keep voltage steady, which will make it so only 1 ballast will turn on.
TRDRacer is offline   Reply With Quote
Old 02-10-2010, 08:51 PM   #6
Evolved8
Member#: 230476
Thanks, Do you have further info on the location of the drl switch?? pictures??
Old 02-10-2010, 09:00 PM   #7
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
Fill out your profile please.
Old 02-11-2010, 10:11 AM   #8
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
This again?
XanRules is offline   Reply With Quote
Old 02-11-2010, 03:22 PM   #9
TRDRacer
Member#: 212793
2003 Built 2.5L 35R
World Rally Blue
On the WRX they are located right behind the kick panel on the passanger door. Once you look up into the dash their should be a little black box that has a connector on it. Just disconnect the connector. I would search on good on on here for your car though. Just type in "Disable Legacy DRL's" you should get a tone of info as this has been covered millions of times!
Old 02-12-2010, 09:33 AM   #10
Evolved8
Member#: 230476
Thanks for the help i will search.
Old 02-12-2010, 12:53 PM   #11
Evolved8
Member#: 230476
Searched and could not find what I needed does anyone have any input?
Old 02-12-2010, 04:15 PM   #12
boosten-n-bluntin
Member#: 233417
boosten-n-bluntin is offline   Reply With Quote
Give me some info....... brucers25 Subaru Conversions 4 04-07-2010 12:37 PM
TXIC Track whores... Give me some info :) Davenow Texas Impreza Club Forum -- TXIC 6 01-19-2006 09:46 PM
can anyone give me some info on this car? Dennis ex24 Off-Topic 27 05-26-2005 02:54 PM
Need help ! I love you if you give me some info. Atomic Orgasm Texas Impreza Club Forum -- TXIC 2 02-25-2002 05:46 PM
could you rally people give me some info? :-) Damon Brakes, Steering & Suspension 14 12-11-2000 10:52 AM
