Old 02-11-2010, 01:22 PM   #1
charles_knoebel
Member#: 232792
2010 Impreza 2.5i
Gray
Default Largest Rims for 2010 2.5i
What are the largest rims I can put on my 2010 2.5i w/o problems? 17's or 18's?
Thanks
charles_knoebel is offline   Reply With Quote
Old 02-11-2010, 01:27 PM   #2
imprezaL2345
Member#: 108188
1993 Impreza L 1.8T
Lotus Storm Titanium
edit..
imprezaL2345 is offline   Reply With Quote
Old 02-11-2010, 01:28 PM   #3
Longinus
Member#: 187727
2001 GC6 Impreza
BRP w/ dust magnet paint
I mean you could probably put on 20's, but that's (hopefully) not what you want.
Longinus is offline   Reply With Quote
Old 02-11-2010, 01:32 PM   #4
T_Racer69
Member#: 188079
2003 Stg 2 Bug Wagon
Sonic Yellow
So may variables in that question. Are you doing straight street driving, some backroads, smooth roads, pothole infested roads, track, rally-x? The second big thing is tires. You could prob. run 18-19 with lower profile tires. the overall diameter is what will determine that.
Also, you need to watch the offset of the wheel, as some may only come in an offset that will hinder it from working(ie: hitting a strut, fender liner at full lock, etc. Search in the members gallery for pics of the 2.5i, will give you some good info and reference points.
Travis
T_Racer69 is offline   Reply With Quote
Old 02-11-2010, 01:34 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
dubs....ha gotsta gets da dubs or ya aint k00
ya just gotsta be k00 so gets ya da dubs
Old 02-11-2010, 01:39 PM   #6
charles_knoebel
Member#: 232792
2010 Impreza 2.5i
Gray
Thanks T_Racer, I'll check it out.
Old 02-12-2010, 11:16 AM   #7
v1gc8
Member#: 238186
2001 Impreza 2.5RS
Grey
go 17's and find a sticky tire with a near stock sidewall for some abuse protection (assuming this is a paved application.) I run fifteens on my 2001 RS with 55% sidewall performance tires usually during the non snow season and it can take quite some abuse in contrast to 16's with 45% sidewall. If this is a street wheel then think about the rims denting over time. now those sixteens due to a thin 45% sidewall and a quick off road excursion are sitting in a metal heap and waiting to be melted down.
last summer on my 1997 2 door i ran 15" 1997 legacy outback rims painted gold with old worn down Kevlar reinforced Gravel tires, from that point on wrecking the tires or the wheels was nearly impossible.
v1gc8 is offline   Reply With Quote
Old 02-12-2010, 09:31 PM   #8
mosc
Member#: 177401
2015 STi White
You can get some tires in 225/30/20 (25.3") which will work on 20x8" wheels (generally no other size). Not sure if you can find 20x8" 5x100 wheels with a decent offset but assuming you could, you could run 20" wheels on a WRX fairly painlessly. Until you hit a pothole that is...
19" would be far easier and you'd actually have a few wheels/tires to choose from.
17" and 18" are by far the most common aftermarket choices.
Personally, I run as much sidewall as I can. Thing is they don't make many 16" tires past 225 wide, nor do they make a wheel that would clear my brakes. As such, I use 17"s. I ran 18"s for a while but hated the ride.
mosc is offline   Reply With Quote
exhuast system for 2010 2.5i impreza kansai104 Newbies & FAQs 3 08-09-2010 12:40 AM
WTT: 2006wrx rims and tires for 2006 2.5i rims and tires subiesurfer Tri-State Area Private Classifieds 3 10-27-2009 09:10 PM
Any idea on ETA for 2010 2.5i Premium? fukamoto New England Impreza Club Forum -- NESIC 6 10-05-2009 07:12 PM
tires for 2010 2.5i HB kman25i Tire & Wheel 6 07-22-2009 03:58 AM
Purchasing rims for the 2.5i AWDDownShift Newbies & FAQs 2 09-25-2008 08:09 AM
