Old 02-12-2010, 12:06 PM   #1
jsin93816
Member#: 227156
2003 wrx
Default wheel bearing grease ?
i am in the process of putting a new rear wheel bearing on my rex and i was wondering if any of you guys repack it with different grease. the bearing is a BECK/ARNLEY Part # 0514162. if you do repack them can you please tell me what grease you use and how it is done i cant seem to find a step by step.
jsin93816 is offline   Reply With Quote
Old 02-12-2010, 12:19 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We use neo HP800 on ours. It helps, but does not prevent failure. As for packing them, we do it by hand. We pull apart the bearing, clean it all up, and then repack it the way I learned many many years ago.
Old 02-12-2010, 12:34 PM   #3
gundamwrx
Member#: 103947
2003 WRX
I'm in the same boat too. Stupid *wah wah wah*
gundamwrx is offline   Reply With Quote
Old 02-12-2010, 03:45 PM   #4
jsin93816
Member#: 227156
2003 wrx
are any special tools needed to repack it ?
Old 02-12-2010, 03:46 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Not really. I use my hand. I put a big glob in my left hand, then roll the bearing into the grease with my right. Then press in a little along the sides. It's really hard to describe.
Old 02-12-2010, 03:55 PM   #6
jsin93816
Member#: 227156
2003 wrx
once i physicly have the bearings in my hands( dam blizzared backed em up) i think ill understand what your saying. thanks for the help
Old 02-12-2010, 05:42 PM   #7
jsin93816
Member#: 227156
2003 wrx
any recomandations on grease that i can pick up at my local auto stores ?
Old 02-13-2010, 01:56 PM   #8
jsin93816
Member#: 227156
2003 wrx
any suggestions ?
Old 02-13-2010, 02:19 PM   #9
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
jsnm is offline   Reply With Quote
Old 02-13-2010, 02:29 PM   #10
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
the way i was taught to pack bearings, is to kind of hold it tight around my middle finger, then with a glob of grease in the left hand like on the bottom of my palm, sort of nick the side and rotate the bearing as i go along. i dont trust repacking machines, its best to do it by hand
happs subi is offline   Reply With Quote
Old 02-13-2010, 02:51 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
you can get the Mobil1 synthetic grease in a tube at Advance Auto if you cant get anything else
I have been using the NEO HP800 for a long time now on just about everything and although it is expensive($37/lb from Baker who call it 'Super Speedway Synthetic Wheel Bearing Grease' )......it is worth it in the end.
Old 02-14-2010, 01:36 AM   #12
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
This way works well for me! though sometimes I hold it like a donut. I like to think of it as sort of pressing gooey cream filling goodness into the side of my donut... hmmm.... donuts...
You've got enough in when there are little ribbons of grease sticking out the other side.
damn I'm fat.
ProdriveDreams is offline   Reply With Quote
Old 02-14-2010, 02:09 AM   #13
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Lol forgot to mention the part when the grease come out the other side. For some reason it makes doing your own wheel bearings worth it lol
Old 02-14-2010, 12:08 PM   #14
jsin93816
Member#: 227156
2003 wrx
haha thanks for the help looks like im gonna have to go with mobil 1 from autozone today.
Old 02-14-2010, 05:51 PM   #15
jsin93816
Member#: 227156
2003 wrx
so i just opened the box that the bearing is in and how to i get the old grease out and the mobil 1 in. do i need to take the bearing apart?
Old 02-14-2010, 09:32 PM   #16
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
I can't remember if the rear is a sealed bearing. The fronts are. If it doesn't come apart just start packing, youll see the color change when the new grease has worked it's way through. Usually if it isn't a sealed bearing it's pretty obvious how to disassemble.
Old 02-14-2010, 09:40 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
then we been doin it wrong for years
Old 02-14-2010, 10:49 PM   #18
jsin93816
Member#: 227156
2003 wrx
im sorry for my lack of knowledge but ill describe the best i can its a metal cylinder that has and inner cylinder that rotates with grease ozing out of both ends how should i go about this...?
Old 02-15-2010, 11:24 AM   #19
jsin93816
Member#: 227156
2003 wrx
any help im trying to push the new through the space in between the two parts and it does not seem to be pushing any of the old grease out
Old 02-15-2010, 12:22 PM   #20
Turn in Concepts
Member#: 93646
Many Track Records
You're doing it wrong. You need to clean out the old grease first. Get a plastic tub, put some gas in it, drop the bearings in, and let soak for a little bit. That'll help break down the grease.
Then swish it about a bit to clean more out. repeat.
Then put them on a towel to dry completely.
THEN put the new grease in.
Old 02-15-2010, 12:25 PM   #21
jsin93816
Member#: 227156
2003 wrx
ok so i can just push it through the gap at that point ?
FS: Wheel Bearings w/seals. Prepacked with Neo HP800 Bearing Grease Gro Harlem Suspension/Brakes/Handling 9 03-04-2009 10:35 AM
Wheel Bearing Grease dunk Motorsports 23 04-27-2008 12:05 AM
wheel bearing grease DJ_STI Newbies & FAQs 8 01-17-2005 10:10 AM
which wheel bearing grease ? JasonE Brakes, Steering & Suspension 3 06-08-2003 11:15 AM
Wheel Bearing Grease BG5 Service & Maintenance 4 12-07-2001 03:25 AM
