Old 02-12-2010, 01:46 PM   #1
garageGT
Member#: 80524
Default How to lose power with an intercooler upgrade
oversized intercooler core with a factory turbo is your solution
http://garagegtlinks.blogspot.com/20...er-choice.html
garageGT is offline   Reply With Quote
Old 02-12-2010, 01:49 PM   #2
classicaddict
Member#: 220619
04 wrx wagon
nice looking intercooler setup tho....save the fact they handed a blind man a can of spray paint and said "have at it!"
classicaddict is offline   Reply With Quote
Old 02-12-2010, 01:55 PM   #3
garageGT
Member#: 80524
paint job is not too bad compared to sizing ! that core is for a 42R turbo
Old 02-12-2010, 01:58 PM   #4
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
damn thats a big pressure drop!!
WREX88 is offline   Reply With Quote
Old 02-12-2010, 02:00 PM   #5
meccjoo
Member#: 97522
wow 6-7 psi drop???
meccjoo is offline   Reply With Quote
Old 02-12-2010, 02:03 PM   #6
garageGT
Member#: 80524
^ yep we couldnt see more than 16psi at the intake manifold..turbo was at 22-23psi range..
Old 02-12-2010, 02:31 PM   #7
hobbesnapoli
Member#: 221436
02 WRX vf39
Could be a garbage intercooler too- no idea on the brand?
hobbesnapoli is offline   Reply With Quote
Old 02-12-2010, 02:49 PM   #8
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
dude that sucks
Brother EddieJ. is offline   Reply With Quote
Old 02-12-2010, 03:00 PM   #9
garageGT
Member#: 80524
The core is high quality, but the endtanks were chopped for new & smaller piping..This is a serious intercooler, but on the wrong car..
Old 02-12-2010, 03:09 PM   #10
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
what were the size of the intercooler pipes?
kevinh211 is offline   Reply With Quote
Old 02-12-2010, 03:29 PM   #11
garageGT
Member#: 80524
no idea what the size was before chopping..
core has 2" in/out piping to match the turbo discharge & help with throttle response, and a stepper hose to go into the 2 3/4" TB
Old 02-12-2010, 03:32 PM   #12
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Holy chit man. Hasnt anyone noticed WTF is going on at 4000RPM????
Its probably bad that what ever is happening is literally ocurring right at peak torque.
STi Mikey is offline   Reply With Quote
Old 02-12-2010, 03:33 PM   #13
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Not all IC's are the same. You say its a high quality core but you have no idea who made it...
project_skyline is offline   Reply With Quote
Old 02-12-2010, 03:45 PM   #14
garageGT
Member#: 80524
needs avcs tune which will happen with the new FMIC kit we will install for him..
Old 02-12-2010, 03:54 PM   #15
garageGT
Member#: 80524
Yes all cores have different efficiency.
the point is the size choice of the core here..I would install this along with a GT4288R but not with the OE turbo.
I know who installed it, but no idea who made it..has cast endtanks..
Old 02-12-2010, 04:20 PM   #16
wittmer25
Member#: 102970
2004 STi gt30r
Increasing the size of the intercooler should not have affected peak horsepower in a negative way. By looking at the results, the end tanks and/or core must have been extremely restrictive causing the loss in peak power.
wittmer25 is offline   Reply With Quote
Old 02-12-2010, 05:44 PM   #17
garageGT
Member#: 80524
when you have major pressure drop, your peak HP is also affected because you only have 16psi at the intake manifold no matter what duty cycle you run..
Old 02-12-2010, 06:28 PM   #18
wittmer25
Member#: 102970
2004 STi gt30r
I think you missed my point. You stated that an incorrectly "sized" intercooler (such as oversized) can cause too much pressure drop. An intercooler that is truly oversized (higher flowing potential) will not be more restrictive and will not cause more pressure drop than a smaller one. This is just a crappy intercooler wether its the end tanks or core or both. Its not because its "over sized". In fact if it made that much pressure drop with a small turbo, it sure as heck won't work better with a much larger turbo.
Old 02-12-2010, 06:52 PM   #19
garageGT
Member#: 80524
No, on the contrary I think you are not thinking like we do OE turbo cannot push enough air to fill this thing up fast enough. Actually this could work well with a big frame garrett..
Old 02-12-2010, 07:07 PM   #20
Checkers
Member#: 188440
98 1.6 Liters
of fury!
I don't understand how an oversize intercooler can lower peak power. Transient response, yes, but thermodynamically speaking, the turbo flows X amount of air. A 100% efficient intercooler will induce a pressure drop as it cools the flow (right?), but no intercooler can affect how much air is being moved by the turbo. The larger the intercooler, holding intercooler efficiency constant, will simply cool the flow further, leading to greater power, not lower power.
The only theoretical explanation I can imagine being reasonably accurate is the one posited above - that this was an extremely inefficient core.
Checkers is offline   Reply With Quote
Old 02-12-2010, 07:21 PM   #21
garageGT
Member#: 80524
our problem here is not filling the intercooler fast enough, we cant fill it up before its sucked by the motor.
Volume over pressure..
and its actually fluiddynamics you mention, not thermo..
Old 02-12-2010, 07:50 PM   #22
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
interesting although i don't know who is right on this one.
maxpowr is offline   Reply With Quote
Old 02-12-2010, 09:26 PM   #23
48mpg
Member#: 58405
2004 Element GT65'd
Hydra, Hydramist'd STi
I'm going with wittmer on this.
volumetrically, the stock turbo will fill the intercooler.
the efficiency of the intercooler will cause the pressure drop.
a core that is too big will just cause it to take longer to fill and pressurize.
with all the e-thugging put aside, the wrong intercooler is def. not as good as the right intercooler.
when the wrong intercooler is of crap design/efficiency/size/endtank/piping or all of the above, it just makes the right intercooler look that much better.
and without putting all the math on here. at 23 psia, assuming that intercooler is 30*10*4, the mass of the air in the intercooler is ~0.1 lbm prolly less, a vf39 flows what ~35lbm/min.
and in defense of the guy who painted it, it prolly looks alot worse because of the flash when the picture was taken. in person I'm sure it looks descent.
48mpg is offline   Reply With Quote
Old 02-12-2010, 09:35 PM   #24
CatfaceType-R
Member#: 81102
wittmer is correct, and it's forced not sucked
CatfaceType-R is offline   Reply With Quote
Old 02-12-2010, 09:46 PM   #25
SubieFiesta
Member#: 149426
2002 Subaru WRX
and 2005 Subaru STi
^^^ I also agree with wittmer.
Something is up with that tune to. Looks like timing being pulled. Which is probably the reason why you lost power not to mention the wavy HP that matches the waves in TQ.
SubieFiesta is offline   Reply With Quote
Will I lose power with no muffler? WrxRick Newbies & FAQs 33 05-04-2008 01:22 AM
how much more power is to be had with an ewg? godforbid67 Newbies & FAQs 1 10-08-2007 02:05 AM
Its official: We lose power with low octane gas. powerlabs Subaru Conversions 58 02-02-2006 06:57 PM
How to dyno with an intercooler Kevin Thomas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-19-2005 11:45 AM
lose power with Turbo back silencer? Electronsmurf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-13-2003 07:26 PM
