Old 02-28-2010, 01:36 PM   #76
Bug-Rex
Member#: 190935
02 Slam'd Bugeye
LOL member accnt. points
Originally Posted by PARANOID56 View Post
all looks good, however, these lights arnt designed to be mounted from the side. the beam pattern is set in the reflector so you might try turning the lens so its horzontal (cant remember if you can do that or not)
Those lights also aren't designed for HID bulbs.
Bug-Rex is offline   Reply With Quote
Old 02-28-2010, 10:17 PM   #77
vwown3d
Member#: 69991
Leh Keen
Approved
Originally Posted by BoXinWRX View Post
hey what did you use to shave the front bumper? i've been thinking of doing this but i dont' want to use fiberglass or something like that, where it could possibly crack over a winter.....
Cutting the bracket out leaves a hole so you have to fiberglass it. It must flex a little so i'm assuming bondo would just crack.
vwown3d is offline   Reply With Quote
Old 02-28-2010, 11:05 PM   #78
02boxer
Member#: 139853
2002 wrx....its tsxy
the lamp looks rotated. It's really only the wiring holding you from turning them, they may be notched (keyed fit), can't remember tho...but that can be modified.
I would go back on the HID's tho...not for the beam pattern...for the fact that the lamp is so SMALL...and likely won't like any prolonged exposure to heat
chris
02boxer is offline   Reply With Quote
Old 03-01-2010, 12:08 AM   #79
relliMmoT
Member#: 206931
2004 WRX Wagon
6MT JBP 318WHP//300WTQ
delete/// double post ///delete
relliMmoT is offline   Reply With Quote
Old 03-01-2010, 12:28 AM   #80
relliMmoT
Member#: 206931
2004 WRX Wagon
I cant find a hot link of that 'who gives a *' jack-off smiley. Theyre very bright (55w 2300k) and focused just as the halogen bulbs were. Im thinking of going back to halogen and roof mounting the HID in some Hella DE driving light projectors integrated into my roof rack fairing though.
1: I ground down the notch.
2: The wiring will move in and out of the grommet to allow you to make all your connections inside the lens.
3: I use them so little that im not worried about the lens and body overheating- the grille would melt before the body ever would. The plastic may get brittle after like a decade though (insert jack-off smiley again)
Thanks! And on the Hellas im step ahead of that thought; had the same thought. I modded the lens holding bracket and shaved off the glass nub so I could turn them upright. PITA.
Originally Posted by D Money View Post
Now on yours, it looks like you have lots of line. How does that look mounted? I had a 10" line and it was too long and I didn't like how it looked, so I dropped to the smallest option of -3AN high pressure line I could find and that was 8". Also, I used a banjo style fitting on the one end where it looks like you did a straight connection to the slave cylinder.
I actually just installed it this weekend. That line was too rigid and long so I went with a line about 1.5' long and spiral wound. You did fine with 8"?? Did you go from master to original hard line or straight to the slave?
I was also going to do a mod thread on this. Maybe we could collaborate and have 'millers way' and 'd moneys' way on the same. PM or add to your original post on that idea.
Old 03-01-2010, 04:36 AM   #81
SupaHottSauce
Member#: 111725
2003 Dylan Peterson
is a scammer
Originally Posted by kh15 View Post
sort story...bought the autometer pod...fit like crap....cut it up....bondo glass + 4 days of sanding = this....
and yes i have 3 gauges now
Looks very nice, I like it
SupaHottSauce is offline   Reply With Quote
Old 03-01-2010, 08:59 AM   #82
STi__G
Member#: 206414
2009 STI
I pulled my spare and jack for two reason.
1. I wanted to lose some weight (just over 30 lbs)
2. My winter wheels are a different diameter than the spare. So using it could be potentially damaging to my diffs.
BUT, I wanted it to look OEM as much as possible without putting too much time and effort into it.
The "holder is made of 1" sheets of Styrofoam glued together covered in black felt. Everything is held tightly in place. I recently did a lapping day on a snow covered track that was heavily rutted and nothing moved or made any noise.
The "Safety Spair" is made by Slime. The green goo is safe for aluminum rims and is water soluble. Its not like the aerosol stuff that is harsh on rims and hard to wash off the inside of the tire. Apparently it is good for punctures up to a quarter of an inch. It is useless against tire/rim separations. If that's the case, I'll probably need a flatbed anyway. To repair a leak, you pour the goo in the tire, roll the wheel so the stuff coats the inside of the tire then pump it up using the 12V air compressor. The Spec C and Corvette use a similar setup so its nothing new.
It will still support any cargo weight I put in the hatch also.
Thanks for looking.
STi__G is offline   Reply With Quote
Old 03-01-2010, 02:52 PM   #83
TurboGoat324
Member#: 208297
2004 WRX
Thanks for looking.
That is really clean! Looks great, and it looks OEM! Great job!
TurboGoat324 is offline   Reply With Quote
Old 03-01-2010, 02:58 PM   #84
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I am down for that. I had to custom order the 8" line as the fitting shop I went to had a minimum of a 10" pre-made -3AN high pressure line. Do you have pics of what yours looks like? For mine, the parts I ended up using cost only $32.00 and connects the master cylinder directly to the slave cylinder.
Parts needed:
Banjo fitting to -3AN
8" -3AN high pressure line (two -3AN straight fittings on each end)
2 crush washers
M10x1.0 to -3AN fitting
and that's it! It looks 100x better then any aftermarket clutch line out there too. It also deletes all that garbage that is unneccesary and gives you a straight connection between the two.
Originally Posted by 04ImprezaWRX View Post
Whats Alex sending you D the CF shift boot piece? Ill post pics of my where I put my Defi controller its CLEAN never seen it done before either.
Send me pics!!!!
D Money is offline   Reply With Quote
Old 03-01-2010, 03:06 PM   #85
kh15
Member#: 132400
2004 sti
wrb
ok im starting a new rule...no quotes with pics attached! I dont need to see the same thing 500 times.
kh15 is offline   Reply With Quote
Old 03-01-2010, 03:33 PM   #86
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
It's one thing if you're quoting a single pic from a previous page, but when it's the post directly above the comment ... that's just gonna wear out my scroll wheel.
Just type "^ That looks great!" and we know what you mean.
2point0 is offline   Reply With Quote
Old 03-01-2010, 03:33 PM   #87
SupaHottSauce
Member#: 111725
2003 Dylan Peterson
is a scammer
I added that rule on the first post already. It will never really work, too many poeple dont read.
Sometimes you need to quote photos to help with clarity of your post. I usually just quote one photo out of the group just to help people know what im talking about.
I am with you though. It can get annoying to scroll past 15 photos over and over again.
Old 03-01-2010, 05:20 PM   #88
relliMmoT
Member#: 206931
2004 WRX Wagon
I bet I could have read all of NASIOC if it werent for all the scrolling through people quoting a million pictures right below the post their commenting on where its only some 'motivational statement' or something like "That is really clean! Looks great, and it looks OEM! Great job!".
I bet their servers would breathe so much better too.
STI_G: Im jealous, I didnt know the 'storage floor' was all one big 'flap' on the newb Imprezas. I wonder if I could order the big 'flap' you have to replace all my separate little 'flaps'
Old 03-03-2010, 12:28 PM   #89
ABeastinWRX
Member#: 239469
2004 WRX
PSM for now ;)
Originally Posted by OUScooby View Post
Seems like a bit of a light bar theme going on here so I'll post mine too, I also posted it the unique mod thread, but I'll post here as well:
Custom fab light bar, polished with 4 hella 500ff.
I took it on a dark canyon last night it was great, like driving in daylight.
damnnnnnnnnnnnnn haha sick nice bro
ABeastinWRX is offline   Reply With Quote
Old 03-03-2010, 01:37 PM   #90
myklwrx
Member#: 150791
2002 wrx wagon
midnight black pearl
hahaha well that lasted long ^^^^^
myklwrx is offline   Reply With Quote
Old 03-03-2010, 01:48 PM   #91
TchainT
Member#: 147750
2004 Legacy Outback
NEW new rule: Spend more time talking about the rules than the mods
TchainT is offline   Reply With Quote
Old 03-03-2010, 06:28 PM   #92
10Dub
Member#: 205430
2010 WRX
Oh relax!! When people post a comment, I want to see the picture they're referring to even if I've already seen it. Is it really that difficult to use your mouse and just scroll past pix you've already seen...?
10Dub is offline   Reply With Quote
Old 03-04-2010, 02:54 AM   #93
relliMmoT
Member#: 206931
2004 WRX Wagon
Except its the bane of this forum. Its bad for bandwidth, which adds to forum cost, which jacks up prices for our vendors, which jacks up our parts prices in a small way. And yes IMO it is a PITA when your scrolling through pages and pages of it. I miss a lotve info scrolling through "DAAMNNNNN THATS SICK BRO" with 4 pictures quoted to it. You get to scrolling so much you skip actual pertinent stuff.
Now what SHOULD be done for a thread like this is "PICTURES ONLY; NO REPLYS/COMMENTS/QUOTES: DIY Modification Thread"
Old 03-04-2010, 07:44 AM   #94
kh15
Member#: 132400
2004 sti
wrb
12345
Old 03-04-2010, 09:50 AM   #95
SupaHottSauce
Member#: 111725
2003 Dylan Peterson
is a scammer
Lets get this bad boy back on track. We need some new custom mods posted.
Old 03-04-2010, 11:27 AM   #96
CC4nj
Member#: 136945
2005 WRX/CRX/LGT
Obs. Black
No big deal...but modified the tank to work with the trunk cage...originally the filler cap gets in the way of the cage.
CC4nj is offline   Reply With Quote
Old 03-04-2010, 11:44 AM   #97
torched
Member#: 181569
2002 Impreza WRX
Midnight Black Pearl
Check out my diy mod... A safe place to put my oakleys... Oem look, same interior color. Came out of a 2003 Nissan Altima.
torched is offline   Reply With Quote
Old 03-04-2010, 01:11 PM   #98
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
To small and dark to see.
Old 03-04-2010, 02:15 PM   #99
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
it's a flip-down shades holder on the ceiling, aft of the map lights.
how is that thing mounted?
Old 03-04-2010, 02:18 PM   #100
Kupkake
Member#: 213288
2007 SWP VF39 WRX
Sti Mikey Tuned
this.
and any better pics? was that thing shot on a .2mp camm? haha
Kupkake is offline   Reply With Quote
DIY Modifications cstratton04 Interior & Exterior Modification 135 02-21-2013 06:50 PM
It's out! My DIY swap thread... lancelucas North West Impreza Club Forum -- NWIC 71 11-28-2010 02:00 AM
1993 WRX Modification thread. clean 93 Pre-2002 Factory Turbo Powertrain 37 05-01-2010 03:30 PM
DIY Modifications txl146 Factory 2.0L Turbo Powertrain 6 03-27-2006 04:21 PM
The DIY audio thread. mattjk Off-Topic 29 06-21-2005 07:45 PM
Message Board Statistics All times are GMT -4. The time now is 02:34 AM.
