Old 02-12-2010, 04:44 PM   #1
Thor6
Member#: 229211
2003 WRX
MBP
Default 06 to 03 Transmission swap help
Will an 06 wrx transmission swap into an 03 wrx? If so, what will I need?
Thor6 is offline   Reply With Quote
Old 02-13-2010, 04:41 PM   #2
Disaster646
Member#: 135382
02 6spd hybrid wrx
fpgreen+E85 ftw [email protected]
im not too sure.. i did a 06 sti spd swap into my 02 wrx.. and it was very simple.. but i think a 06wrx transmission have a different rear differential ratio. and they also use a push type clutch, meaning u will need the tranny.. the rear diff.. and probably the front axles which are male ends which go into the transmission.. and also change the slave cylinder and fork.. to the push type .. if i was u.. i would just get a 04-05 wrx transmission.. and the only things u probably have to change are.. the front axles the 06 are not any stronger than the 06-07 versions with the 3.70 rear diff.. plus ur bugeye has a 3.54 rear diff.. if u are concerned about breaking gears. ur only options are ppg or 6spd transmissions.. trust me go this route.. or in the future when u read this post again.. u'll be pissed.. .. i used to baby my 04 tranny..and one time tuning the car.. on 3rd gear pulls i ripped the teeth..
Disaster646 is offline   Reply With Quote
Old 02-14-2010, 01:42 AM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
The '06-'07 WRX transmissions are a whole nother animal from the '02-05 (which are not wholely dissimilar from the STi transmission). I believe you will need new axles (not 100% you can't reuse stubs), new styled rear diff, new style slave cylinder, clutch fork, and pressure plate... that might be it.
ProdriveDreams is offline   Reply With Quote
Sti Transmission Swap Help 02cnybugeye Subaru Conversions 3 02-15-2009 10:15 AM
LGT Transmission swap help...400whp!!!! mtcs Newbies & FAQs 13 12-02-2008 01:36 PM
FS(ca): feeler 06 5 speed transmission swap Unrealgtx Drivetrain 11 10-21-2008 07:44 PM
Transmission swap...help! LKY13 Newbies & FAQs 5 08-29-2008 11:41 AM
Call to arms: 4EAT to 5MT transmission swap (WRX) Kha0S New England Impreza Club Forum -- NESIC 9 03-24-2003 09:22 PM
