Old 02-12-2010, 06:21 PM   #1
Fine Line Imports
Member#: 81166
2008 Forester
Default 2006 STI APS TSR 70 build
Event: dyno pull
Ambient Temp: 65
Elevation: feet above sea level
Weather: overcast
Tires: 225/45/17 Bridgestone
Car: 2006 STI
Tuner: Miles Hechtman from Fine Line Imports
Dyno Info: Mustang MD500 AWD
Peak HP at RPM:503whp
Peak Torque at RPM: 468
Baseline: Stock STI 245whp 240 torque
Target Boost: 30 psi tapering to 28psi
Fuel: E85 with duel staged injection
Engine/Power Modifications: COBB pro series short block, cobb pro series stage 2 heads, cosworth 278 cams, APS TSR 70 rotated turbo kit, APS FMIC, APS BOV, APS 3.5in TBE, APS fuel rails, APS TGV deletes, APS aux fuel rails, APS main fuel rails, PE 850 CC inj x4, Bosch 600cc inj x4, Aeromotive A1000 fuel pump, wallbro fuel pump, FLI surge tank, Aeromotive FPR, FLI reverse intake manifold pipeing, Aeroquip fuel lines, Link G4 stand alone ECU, Aquamist HFS 6 kit and a spec C ic spray tank.
Driveline: ACT 6 puck clutch with light weight fly wheel.
Suspension Modifications: KW varient 3 coilovers, COBB front and rear swaybars, Whiteline ALK
After a long build up of this 2006 STI it is finally complete. Overall this is one of our favorite engine builds of recent memory. With a great power band and excellent topend this car is truly a blast to drive.
For more info on this car check out our blog at http://fliblog.wordpress.com/categor...owered-06-sti/
Ryan
Fine Line Imports
www.finelineimports.net
Fine Line Imports is offline   Reply With Quote
Old 02-12-2010, 06:51 PM   #2
fourmicah
Member#: 128760
2015 STI
That's an awesome powerband for a turbo that size, that combo of parts definitely works well together!
fourmicah is offline   Reply With Quote
Old 02-12-2010, 08:03 PM   #3
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
400wtq by 3850 rpm thats VF39 spool right there
TS FTW
Old 02-12-2010, 08:48 PM   #4
fourmicah
Member#: 128760
2015 STI
TS FTW
My thoughts exactly! That thing has sweet spool up!
Old 02-12-2010, 09:02 PM   #5
Deuce Cam
Member#: 130444
'85 AE86 GTS
Looks awesome. Is that the standard tsr70 hot side? I'm a little surprised peak hp is at 6000rpm considering all the work, especially the cylinder heads. Although, it looks like it holds fairly well to 6550rpm.
Deuce Cam is offline   Reply With Quote
Old 02-12-2010, 09:14 PM   #6
juanmedina
Member#: 133146
TS setups do not have strong top end as a single scroll setup, this is normal TS behavior
Old 02-12-2010, 10:41 PM   #7
SubieFiesta
Member#: 149426
2002 Subaru WRX
and 2005 Subaru STi
havent seen a link ecu in forever, how is that computer?
SubieFiesta is offline   Reply With Quote
Old 02-13-2010, 01:16 AM   #8
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Honestly, thats an absolutely perfect set up. Sick fuel system, sick engine, sick power, and it spools like a 20g.
godforbid67 is offline   Reply With Quote
Old 02-13-2010, 01:21 AM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
We have 8 injectors. We only make 506 whp. I don't even come close to questioning these numbers!
This will be a beast!
Old 02-13-2010, 01:48 AM   #10
acssa
Member#: 184023
Should make more power that that at that boost....
and the headers and up pipe will soon start cracking.
acssa is offline   Reply With Quote
Old 02-13-2010, 02:11 AM   #11
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Graph = dream powerband
STi Mikey is offline   Reply With Quote
Old 02-13-2010, 08:01 AM   #12
F4Turbo
Member#: 43846
2006 Aspen White STI
86 AE86 GTS 06 WW Evo IX
Yeah, bear in mind that it is the standard TSR70 hot side, not the larger option (I am 99% sure). I personally don't doubt that the car could easily continue pulling up top when/if the hot side is swapped. I think it would also be interesting to see how much is gained and lost with respect to top-end power and low-end spool, after switching to the larger TSR70 hot side.
P.S. That much wtq with stock BBS wheels and tires = smoky burnouts.
F4Turbo is offline   Reply With Quote
Old 02-13-2010, 02:38 PM   #13
godforbid67
Member#: 137168
06 Built SGM WRX
My tuner has a 37r on 26 pounds making similar power on stock bbs and 225 tires. The car spins like nothing else. He took me out on slightly wet roads and the car was cocked sideways all the way through third gear from first.
Old 02-15-2010, 12:27 PM   #14
Fine Line Imports
Member#: 81166
2008 Forester
It is the normal TSR hot side not the 1.06. For now the customer is happy with this power if we ever swap out to a 1.06 hotside I will make sure to post up the graphs.
Ryan
Old 02-15-2010, 12:35 PM   #15
fourmicah
Member#: 128760
2015 STI
Not necessarily, APS realized they had some issues with their headers and from what I've heard, has made the appropriate adjustments and fixed them.
Old 02-23-2010, 03:41 PM   #16
javasti
Member#: 44479
2004 WRX STi
Java Black Pearl
can we see a pic of under the hood
javasti is offline   Reply With Quote
FineLine - 2006STI APS TSR 70 Reverse Intake Manifold Fine Line Imports NASIOC Project Cars 85 02-17-2011 01:16 PM
For Sale: APS TSR 70 twin scroll turbo kit with intake and full race" reversed piping syoung0298 Engine/Power/Exhaust 25 09-23-2008 03:10 PM
2004 STi with APS TSR-70 -- 11.33et @ 127.92mph Dasani Proven Power Bragging 72 06-07-2008 11:34 PM
Aps TSR-70 ?'s Que Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 01-16-2008 05:21 PM
Turbine inquiry about APS TSR 70 Twin Scroll Turbo Kit... nomorem3 Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-11-2006 02:59 PM
