Old 02-13-2010, 12:10 AM   #1
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
Default Rs-t gets tuned/dyno'd
Finally had the car ready to get tuned.
Car journal http://www.rs25.com/forums/f145/t780...-love-car.html
Had some issues trying to track down a Ignition problem, might be the iridium plugs, had them gapped down to 18-19 ish and helped. You can see in the Higher RPM the blank spot where this happens.
Plus Emanage has is teething problems.
Might have a small exhaust leak, and the car was only seeing 4-5psi.
00RS Stock Block
Emanage Ultimate
38mm Tial EWG 6psi Spring
Td04
wrx 440's
Cx-Racing FMIC
HKS BOV
Blue = Base Run N/A
Red = Boost
freeride is offline   Reply With Quote
Old 02-13-2010, 10:51 AM   #2
cdnsigop
Member#: 226535
1998 Impreza L (RIP)
Nice work! A couple more pounds of boost will make a HUGE difference...
Where is Ancaster?
cdnsigop is offline   Reply With Quote
Old 02-14-2010, 04:10 PM   #3
freeride
Member#: 49783
SRP/white
Pretty much Hamilton on the 403.
Old 02-18-2010, 06:31 PM   #4
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
You should be making a little more then 18 hp from a td04/ewg install. Even though you're only running 4-5 lbs i'd think at least 50 hp should be obtainable. I'd definitely check for boost leaks and do some more trouble shooting.
Mike
GrimmSpeed is online now   Reply With Quote
Old 02-18-2010, 10:08 PM   #5
freeride
Member#: 49783
SRP/white
well its almost 40 hp not 18 but yes it still needs some tweaking.
Old 02-19-2010, 10:56 AM   #6
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Sorry i was reading across
Good luck getting this project up to it's full potential, i'm sure it will be a blast!
Mike
Old 02-19-2010, 05:30 PM   #7
freeride
Member#: 49783
SRP/white
No prob :P Its got a Grimmspeed product on her :P (wastegate Bracket) Thinking about picking up the MBC from you guys.
Great products
Old 02-20-2010, 10:15 AM   #8
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
lets see how much she can take before the your rods go SNAP !
IllNastyImpreza is offline   Reply With Quote
Old 02-20-2010, 03:36 PM   #9
freeride
Member#: 49783
SRP/white
I could go 9psi and she if she lasts a year :P
Old 06-16-2010, 07:09 PM   #10
freeride
Member#: 49783
SRP/white
Lill update, Head gaskets went, so I was going to go with new rods and pistons to handle more boost but getting a nice new STI block was easier and cheaper!
so sitting at 8 psi for a small break in and then up to 16-18 psi we shall go.
New STI block, Cometic HG, ARP head studs, Mishimoto Rad with slim fans and a manual Boost controller.
Old 06-17-2010, 09:42 AM   #11
subadub07
Member#: 177611
07' Outback Sport
Garnet Red Pearl
awesome! seems like it would be a fun ride
subadub07 is offline   Reply With Quote
Gonna Get Tuned Think I Should Get Bigger Injectors- What Size Should I Get? ScoobyNubieToo! Engine Management & Tuning 13 01-08-2009 10:58 AM
Keep AP & get tuned, or just get a tune? Donzo AccessPort 7 06-28-2007 02:11 PM
Utec Tune...Anywhere to get tuned? urabusXRW Tri-State Area Forum 1 11-23-2003 08:17 AM
Tuning dates and prices here. If you want to get tuned, now is the time ! STEALTH-WRX Southern California Impreza Club Forum -- SCIC 111 11-20-2003 11:08 PM
