Old 02-13-2010, 07:22 PM   #1
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
www.ClintonRacing.com
Default A new take on the frame rail brake duct setup
I got the new brake duct setup finished/painted today and got some pics. This is all based off Dunk's attempt to use the frame rail as a duct piece. We just made some innovations on his idea.
I saw a couple of issues with using his revised idea (chopping the frame rail out and welding in a full length tube). 1) I wanted to keep the crumple zone just in case of an on track accident, it seems like having that energy aboorption would be a good idea. 2) There is a main subframe mount bolt that runs through that channel (can be seen in one of the pictures). I did not want to cut that thing out, and wasn't really sure how Dunk got around it with his idea.
The vast majority of the work was done by Robb at Godspeed Fabrications in Auburn, WA. Robb is a great guy that is a very skilled fabricator and welder. I strongly recommend him!!
The front "bumper" piece is removable and uses the OE bumper studs/bolts to hold it one. The inlet round ducts transistion into a square-ish shape where the inlet meets the frame rail. AND as a bonus, we dropped 20lbs off the front of the car by removing the front bumper beam and replacing it with our setup.
Then we did basically the same thing where the outlet duct is. The front side was shaped to match the frame rail so that the transistion from square to round is as smooth as possible.
We finished the ducting off with some hi-temp heavy duty flexible ducting and the Quantum Motorsports brake ducts.
Just testing subjectively by using a compressed air nozzle from about 4 feet away it feels like there is not much flow loss from the front of the car to the rotor (based on what we could feel with our hands).
All I have left to do is insert some screens in the inlets to prevent large debris from getting in there. Should have that done tonight.
generalee69 is offline   Reply With Quote
Old 02-13-2010, 08:32 PM   #2
25rsti
Member#: 166324
swift idea, i like.
surprise you guys kept the stock front subframe....its heavy
Old 02-13-2010, 09:05 PM   #3
watchdoc
Member#: 104821
2015 Outback LTD
So, your "tubes" line up with the fog lights?
watchdoc is offline   Reply With Quote
Old 02-13-2010, 09:15 PM   #4
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
They look to close together to line up with the fog lights. Cutting holes in the front bumper? Do you have a link to Dunks setup for reference?
Honest Bob is offline   Reply With Quote
Old 02-13-2010, 09:15 PM   #5
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
very smart idea. i like it.
WREX88 is offline   Reply With Quote
Old 02-13-2010, 09:29 PM   #6
wrx5door
Member#: 229654
2002 ej207/vf36
MBP
cool-cool...
hope its a track only car!...cause if your coastal or up in the frozen north with salted roads... :S
wrx5door is offline   Reply With Quote
Old 02-13-2010, 09:41 PM   #7
MasterKwan
Member#: 98961
2003 WRX
It's also very strong and effective. It's only 28 lbs and it's low on the car.
Old 02-13-2010, 11:30 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
http://forums.nasioc.com/forums/show...ke+ducts+frame
generallee, what's the rest of the setup? As the others asked, where do the inlets mate to the front bumper?
Pat Olsen
Old 02-14-2010, 12:01 AM   #9
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
Originally Posted by 25rsti View Post
swift idea, i like.
It hasn't been a weak enough of a link to need addressing... yet. I'm sure some day we will upgrade to something that is stronger and lighter.
Pat Olsen
Thanks Pat for posting up that link.
Yes we had to cut 2 holes in the bumper cover to run the inlets. It worked out pretty well in my opinion though. The inlet follows the radius of the fog light cover in the upper corner. Looks fairly "natural".
Old 02-14-2010, 11:41 AM   #10
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Not bad, you'll definitely get more airflow the way dunk did it but this is a lot less work.
boost junkie is offline   Reply With Quote
Old 02-14-2010, 11:47 AM   #11
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
+1 neet idea
rexworx is offline   Reply With Quote
Old 02-14-2010, 11:48 AM   #12
x00
Member#: 153955
05 Sti
good idea
x00 is offline   Reply With Quote
Old 02-14-2010, 03:03 PM   #13
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
I was hoping he would chime in here and discuss how he got around the subframe bolt that runs through the middle of the channel. We had to actually knock out a piece that completely blocks that airflow passage and just beef up the bolt support.
Maybe the bugeye chassis is just a bit different than the blob eye?
I agree his way will get more airflow, if it is a full 3" all the way through.
The other major restriction, even more so than the frame rail, is the hub mounted Quantum Motorsports duct. That thing is half blocked by the ABS sensor/hub.
We were not having issues with brake temps last season, but this season we bumped our wheel sizes from 7.5" wide to 9.0". We also bumped the horsepower 270ish whp to 330whp. Hopefully this will be enough of an improvement to keep the temps in check.
Old 02-14-2010, 03:21 PM   #14
dunk
Member#: 15359
Unfortunately I'm underway right now and my internet filter won't let me see your pictures.
I think the real trick with effective brake ducting (and one even I haven't perfected yet) is to make sure you block off any escape for air between the duct and the rotor with good backing plates so that all the air that comes through the duct has to leave through the vanes of the rotor. I plan on trying to make better backing plates this year.
-Duncan
dunk is offline   Reply With Quote
Old 02-14-2010, 05:44 PM   #15
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
Very clever!
REDrum is offline   Reply With Quote
Old 07-19-2010, 06:41 PM   #16
GTRobb
Member#: 252498
92 Skyline GTR
www.godspeedfab.com
Thank you
Ray asked me via e-mail if I could make this into a kit. I'm thinking that there is just to much cutting and welding required though.
If you are local to me (Auburn Wa) I can build the system for you though.
GTRobb is offline   Reply With Quote
Old 09-14-2010, 04:19 PM   #17
Bisss
Member#: 234133
2006 Impreza STI
Cool!! Very good work!!
Bisss is offline   Reply With Quote
Old 09-14-2010, 04:33 PM   #18
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
There will be some revisions to the inlets this winter to help get more air through the system. I'll post an update when they are complete.
Old 09-20-2010, 01:05 PM   #19
shaggy-with scoobi
Member#: 207631
2002 XPT Stage 2 WRX
Fat Chicks love that ride
cool idea
shaggy-with scoobi is offline   Reply With Quote
Old 09-20-2010, 01:19 PM   #20
rbahr
Member#: 40671
2006 STI, Outback XT
Grey, Blue
Can you give me a hint - I plan on doing something like this also - BTW great idea!
Ray
rbahr is offline   Reply With Quote
Old 09-20-2010, 11:11 PM   #21
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
I think I need more surface area at the inlet side. So I am planning on enlarging the front where it comes through the bumper cover. The inlet will wind up being roughly 3 times the surface area of the ducting.
Old 09-20-2010, 11:50 PM   #22
rbahr
Member#: 40671
Grey, Blue
Have you done any measurements - I guess the real question is why are you doing this?
Old 09-20-2010, 11:53 PM   #23
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
go take a look at the front end of our car from 2009 RTA in new jersey. You'll notice that we added little scoops to our inlets to catch air sliding off the front bumper.
Otherwise we were limited to air hitting the holes directly.
It made a huge difference in temps, and was one of the many little things that nobody notices unless they are looking really close.
Old 09-20-2010, 11:58 PM   #24
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
I'm not getting enough flow through the inlet to cool the rotors enough. At faster tracks where there is time to cool things down I don't have a problem with (Pacific Raceways and PIR). At slower harder braking tracks (Mission and ORP) I still boil the fluid (RBF600) and overheat the rotors.
I'll have to check it out. Thanks.
Old 09-21-2010, 12:26 AM   #25
rbahr
Member#: 40671
Grey, Blue
Thanks!
Ray
A New Take on the TWO TONE ProjektPhoto Member's Car Gallery 270 12-19-2009 03:51 PM
07 wrx looking for personal takes on the delta w/setups like mine smittypac UTEC 3 02-25-2008 06:27 PM
Do the 02-03' brake ducts fit on the new sti? NewShockerGuy Brakes, Steering & Suspension 10 11-07-2004 11:48 PM
A slightly easier brake duct setup BIGSKYWRX Brakes, Steering & Suspension 15 05-10-2004 01:49 AM
A new take on the silencer mod. with pics GLOATLIP Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 04-16-2002 09:36 PM
