Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 02-13-2010, 10:08 PM   #1
Member#: 176592
2002 WRX-Sold
1998/04 Unicorn RSTi
Default High coolant temp, cel, oil pressure light goes on and off? wtf
Well I'm home from college for 4 days so I did a little work on the car.
-Saggy butt spacers
-Grounding Kit
After I finish, I start the car. It doesn't start and I get a cel. I try to start it again, it starts and the cel goes away. I let the car warm up and then I take it for a 15 minute drive and at some points, I drove the car very aggressively
I get home and the car sits for 2 hours. I get in it to drive my sister to her friends house, car starts up and gets a cel. The coolant temp gauge is also maxed out. I pull the dipstick out, oil is cold. I get back in the car and the oil pressure light is on. I tell my sister whats up, look at the cluster and the oil light is off. I decide to drop my sister off and go find a code reader.
One mile from the house oil light comes back on. I figure I shouldn't push my luck so I drive back to the house.
WTF! Any ideas would be greatly appreciated.
cazwrx187 is offline   Reply With Quote
Old 02-14-2010, 12:58 AM   #2
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
could very well be a ground loop. Where did you install this illustrious grounding kit too?? and did you ever try to pull codes? You really need to pull those codes if there is any.
ProdriveDreams is offline   Reply With Quote
Low fuel light goes on and off at 1/4 tank jasmine008 Service & Maintenance 8 05-03-2010 09:56 AM
High coolant temp, cel, oil pressure light goes on and off? wtf cazwrx187 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-05-2010 03:25 PM
CEL with cruise control lights goign on and off bnr34rb26dett Newbies & FAQs 10 02-12-2009 07:58 PM
CEL goes on and off randomly persian prince Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-08-2007 11:26 AM
E-Brake Light Goes on and off? NycFox Brakes, Steering & Suspension 9 05-20-2007 11:38 AM
