Old 02-14-2010, 10:22 AM   #1
JDMCRIS
Member#: 223690
2001 WRX
Anrazith
Default -6 to perrin Fuel Rails
Hy
I wanna ask if it is ok wenn i go with -6 braided lines from the aeromtiv FPR to my perrin fuel rails or its better wenn i go with -8 ?
Thanxs for your help
chris
JDMCRIS is offline   Reply With Quote
Old 02-14-2010, 11:20 AM   #2
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
-6 will work great. Thats also what Im using.
scby rex is offline   Reply With Quote
Old 02-14-2010, 01:31 PM   #3
MartinSTi05
Member#: 145145
2006 wrx STi
-6 is more than enough for even the mighty ID 2000s.
MartinSTi05 is offline   Reply With Quote
Old 02-14-2010, 02:39 PM   #4
Maxwell Power
Member#: 190729
the perrin fuel rail is set up for the same inner diameter as a -6. Anymore than that is a waste. I run 500 whp on my factory rails and they are -4 equivalent.
Maxwell Power is offline   Reply With Quote
Old 02-15-2010, 03:30 AM   #5
JDMCRIS
Member#: 223690
2001 WRX
Anrazith
Thanxs a lot for your help guys !
Old 02-15-2010, 05:02 AM   #6
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
I run -8 from fuel pump to distribution block then -6 to each rail and -6 back to the FPR.
alcoolaid is offline   Reply With Quote
Old 02-15-2010, 12:13 PM   #7
scby rex
Member#: 104878
02 wrxbastardchild
oem is not -4. its only slightly smaller than -6 yet my -6 hoses fit on it perfect.
Old 02-15-2010, 01:02 PM   #8
Maxwell Power
Member#: 190729
yeah, the hoses and nipples aren't, but the fuel lines between the rails and the bends get down to about a -4. That's why I said "equivalent"
FS/FT : PE 850 cc injectors, perrin fuel rails sidefeed JT's06sti Engine/Power/Exhaust 2 06-19-2010 03:34 PM
What FPR to use with Perrin fuel rails? awd4ever Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-17-2009 12:01 PM
FS: Perrin Fuel Rails/ Aeromotive A1000-6/ Turbo XS RFL BOV 4orcefed240 Engine/Power/Exhaust 14 03-23-2008 09:47 AM
Perrin fuel rail dont seem to fit with APS tgvs 03clipsegts Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 09-12-2007 04:28 PM
Can someone please confirm the correct hoses I need to get for my Perrin Fuel Rails? STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-03-2003 02:14 PM
