Old 02-14-2010, 01:11 PM   #1
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Default 2004 WRX hybrid - 2.5L 9:1 CR GT35R Topspeed tuned
Event: Dyno pull
city and state: Alpharetta, GA
Ambient Temp: ~45*
Elevation: 1,135 FT
Weather: Sunny
Track and Conditions: N/A
slightly up or downhill: N/A
Tires: Brand new 245/40/17 RE01R
Car: 2004, WRX 2.5 liter hybrid with 2.0L heads
Tuner: Doug at Topspeed
Dyno Info: Dynojet
Q16 Peak HP at RPM: 527 hp 6-6.2k rpm
Q16 Peak Torque at RPM: 480 tq ~4.8k rpm
Meth injected Peak HP at RPM: 478 hp 6-6.2k rpm
Meth injected Peak Torque at RPM: 435 tq ~4.8k rpm
Baseline hp/tq for a stock on same dyno: 230hp for stock STi
Target Q16 Boost: 28psi
Target Meth Boost: 25psi
Target AFR: n/a
Fuel: 93 oct + methanol, and Q16
Engine Management: Cobb V2
Engine/Power Modifications: 2005 2.5L shortblock, stock STi rods, stock STi crank, 99.75 CP pistons, Topspeed Spec ring gaps and piston to wall clearances, 2.0L Stock heads, 2.0L valve train, 2.5L 2007 WRX cams, Tial GT35R turbo with .63 Tial hotside, custom modified TurboXS rotated kit, TurboXS fuel rails, Custom grounding kit, Custom AOS modified from several kits, SMC methanol injection with M15 nozzle, Custom 83mm KSTech rotated intake, TurboXS rotated piping for TurboXS FMIC, Maddad equal length headers, Maddad uppipe modified for EWG, tial 44mm EWG, Hallman Pro MBC, Greddy Evo2 exhaust with restrictive resonator removed, Shuriken small battery, and I'm sure I'm missing a lot more....
Driveline Modifications: 2007 STi 6 speed, DCCDPro controller, stock R160 rear end, ACT 6 puck clutch
Suspension Modifications: Tokico DSpec struts and RCE Blacks springs from TiC, Perrin 25mm Front and rear sways, upgraded endlinks, GTspec ALK
Other Modifications: Brembo front brakes, H6 rear brakes, etc.
CoolRex is offline   Reply With Quote
Old 02-14-2010, 01:18 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
First-----simply sick
Are you worried about the stock rods with the q16 map?
enjoy the car and congrats
juanmedina is online now   Reply With Quote
Old 02-14-2010, 01:34 PM   #3
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Nope. They are good for 550 hp and I've seen them at 600 and never break. The 600 hp car they TRIED to kill it (within reason but beat the piss out of it) and it live right on.
The q16 map is a drag map so it'll only be used a few times
I launched the car on the q16 and man WHAT a RIDE! Had my adrenaline going so hard I was shaking.
10's will soon be here.
Old 02-14-2010, 02:13 PM   #4
makeitlookeasy
Member#: 78018
2003 WRX Green PPG
Nice, looks like the 2006 cams held pretty good.
makeitlookeasy is offline   Reply With Quote
Old 02-14-2010, 02:20 PM   #5
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Yeah they held really well for a stock cam. It's in the tune. Thanks for the cams Juan
Old 02-14-2010, 02:21 PM   #6
juanmedina
Member#: 133146
The are actually 2007s
Old 02-14-2010, 02:24 PM   #7
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Doh thought your car was a 06. Fixing it.
Old 02-14-2010, 02:51 PM   #8
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
wow great power! impressive for basically a completely stock engine. car must be a blast
WREX88 is offline   Reply With Quote
Old 02-14-2010, 03:02 PM   #9
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
Yeah thats very impressive for non-ported wrx heads with ANY cams, let alone oem 2.5 cams.
trex616 is offline   Reply With Quote
Old 02-14-2010, 05:16 PM   #10
SUBIEDUDE33
Member#: 149625
2006 wrx
CGM Cosworth HTA35r
wat kind of transmission you runnin and wat clutch ?
wrx tranny wit ppg gears or sti trans ?
SUBIEDUDE33 is offline   Reply With Quote
Old 02-14-2010, 05:23 PM   #11
OK007STI
Member#: 185346
2007 Impreza WRX STi
looks to be an 07 sti tranny
OK007STI is offline   Reply With Quote
Old 02-14-2010, 05:45 PM   #12
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Very nice numbers!
Jubert69 is offline   Reply With Quote
Old 02-14-2010, 06:01 PM   #13
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
2007 st trans, act 6 puck clutch
Old 02-14-2010, 06:33 PM   #14
r0nzar
Member#: 78957
'06 Evo IX RS
White on white on salt
Just curious, what's the difference between ej205 cams and the 2007 ej255 cams? Wouldn't they be worse up top since the powerband shifted left in '06-'07?
r0nzar is offline   Reply With Quote
Old 02-14-2010, 07:00 PM   #15
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
the powerband shifted to the left cause they are 2.5L instead of 2.0
these cams are just like sti cams
Old 02-14-2010, 07:28 PM   #16
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Nice, good to see your car going finally. I have followed your build for some time now.
godforbid67 is offline   Reply With Quote
Old 02-14-2010, 07:48 PM   #17
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
coolrex you got any pictures of your turbo kit? i read you have a custom modified turboxs vband kit.
ownnij is offline   Reply With Quote
Old 02-14-2010, 07:55 PM   #18
neversummer489
Member#: 153729
PSM Bugeye
Missing rod bearing??
Nice numbers I will be finishing a build similar to this soon main difference is 272 cams and my heads are from an 04 sti. I think I have just made up my mind on a 35r with a .63 hotside
Thanks!!!
neversummer489 is offline   Reply With Quote
Old 02-14-2010, 08:07 PM   #19
godforbid67
Member#: 137168
06 Built SGM WRX
They are your cams right Juan?
Old 02-14-2010, 08:37 PM   #20
juanmedina
Member#: 133146
yeah.
Old 02-14-2010, 09:13 PM   #21
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
No they are my cams
Old 02-14-2010, 09:19 PM   #22
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
This was old and while I was buttoning up the final bits and before the final changes with the intake and MAF system. Now I have a KSTech 83mm intake, no blow thru, all the piping is black. I'll update tomorrow if I can get home before dark. But I love how this kit is in your face when you pop the hood.
Old 02-14-2010, 09:28 PM   #23
wrblueballs
Member#: 121549
2005 WRX 20G, PPG
holy smokes. makes me not wanna wait to go hybrid.
wrblueballs is offline   Reply With Quote
Old 02-14-2010, 09:33 PM   #24
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Very nice! I wanna ride!
robbieshonda is offline   Reply With Quote
Old 02-14-2010, 10:34 PM   #25
CatfaceType-R
Member#: 81102
^^^same here, along with some other classic ppb and nasioc users in the car for the ride
<---loves to see an older nasioc dude(lost my sn from pre 03) going fast in a subi in 2010
CatfaceType-R is offline   Reply With Quote
COBB Tuning Surgeline: 2004 WRX Wagon 2.5L GT35R E85 Employee Car Build Cobb Tuning Proven Power Bragging 34 11-30-2011 06:04 AM
Break-in tune: 2.5L 9:1 CR EJ257 + GT35R = 430whp @ 15-16psi jays05 Proven Power Bragging 96 03-05-2010 08:36 AM
AZ - 2004 WRX with 2.5l STi engine. jblackwell Private Vehicle 'For Sale' Classifieds 18 08-13-2009 12:51 AM
FS VA: 2004 WRX STI 2.5l Rods and Pistons billy720 Engine/Power/Exhaust 1 06-04-2007 09:28 AM
FS: 2004 WRX JDM 2.5L motor 10k miles - TN aaronkuschel Private Vehicle 'For Sale' Classifieds 1 03-17-2006 02:08 PM
