Old 02-15-2010, 05:04 PM   #1
motocooney
Member#: 176235
09 Mazdaspeed3
Default 05 STI-20g EWG-354whp/366wtq-Mayhem Tuning
Event: Road Tune
Ambient Temp:30*
Elevation: 500ft above sealevel
Weather:Sucky winter!
Tires: Goodyear Eagle GT 235/40/18
Car: 05 STI
Tuner: Cory Schander / Mayhem Tuning
Dyno Info:Airboy Road Dyno / Smoothing of 5
Peak HP at RPM:[email protected]
Peak Torque at RPM:[email protected]
Baseline hp/tq for a stock on same dyno: N/A - Airboy #s are comparable to lower reading Mustang #s
Target Boost: 22psi
Target AFR: 11.1
Fuel:93oct pump
Engine/Power Modifications: stock 2.5L
TC.com TD05 20g 7cm^2
Grimmspeed EWG Uppipe wrapped
Tial 38mm EWG 17lb springs
DC Sports UEL Header Wrapped
HKS catless DP(wrapped)/ Invidia Street CB
Prodrive 3-port BCS
Turbo XS TMIC
Cobb short ram
Zero Sports after MAF/Perrin Inlet
DW 740cc injectors
Driveline Modifications:ACT HD clutch/Gruppe-S flywheel
Suspension Modifications: Stock struts w/ Cobb sport springs
Whiteline Front 27mm / Rear 24mm swaybars
ebay f/r strut bars ( I know)
Other Modifications:Prodrive PFF7 18x8 wheels
RacingBrake front BBK w/slotted rotors
Axxis Ultimate pads f/r
I had a previous tune @ Benchmark Tuning in Chicago. I made 292whp/336wtq on their Mustang Dyno. I believe I had a torn inlet at the time of the tune. Which was my fault. I replaced the inlet and I started having problems.
I was having some drivability problems. Including but not limited to some totally out of whack Fuel Trims.
The whole story about that can be found here:
http://forums.nasioc.com/forums/show....php?t=1916420
Cory (renosubby)/ Mayhem Tuning contacted me to help. He had my MAF scaling issues fixed almost immediately! After having a look at the map I was running, he told me he was going to work on the fueling/timing and make some real power. He ended up making amazing power!
Cory does Internet Tunes as well as Road/Dyno tuning. He had my car sorted out with first revision of the map. Every revision he sent made more power and felt smoother and more responsive. He had no problem explaining to me what he was doing either.
A few revisions later via Email this is the result!
Cory's a great guy too work with! He really knows what he's doing. The car is very drivable! The transition from the part throttle stuff too all-out is really seamless. It's just smoooooth! The car feels crazy!
Long story short....Thanks Cory
DYNO Graph should be below this first post.
motocooney is offline   Reply With Quote
Old 02-15-2010, 05:30 PM   #2
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Here you go #'s are probably a little higher but we couldn't get a full 4th gear pull because he doesn't want another ticket
Thanks for the kind words Chris and I look forward to working with you in the future. Im trying to get him to go back to the dyno to see what #'s he is actually making on the same dyno.
Cory
renosubby is offline   Reply With Quote
Old 02-15-2010, 05:48 PM   #3
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
nice spool great top end
Old 02-15-2010, 08:00 PM   #4
25rsti
Member#: 166324
torquey! i love it
Old 02-15-2010, 08:24 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
lol, once you're doing 95mph.....might as well just go to 105.
Did you tune it yourself before....or was it tuned at a shop?
A before and after graph of the MAF would be fun to see.......i've graphed mine up after "pro" tunes and been like WTF is that
Old 02-15-2010, 08:54 PM   #6
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
It was tuned at the shop Benchmark....
I got it and the MAF table wasn't touched at all for idle and cruising but the WOT was by 5-8% in a few areas!
It was very jerky at part throttle but the WOT was great. Took a look at his map and made 2 changes. One to the injector scaling and one to the whole maf table. It wasn't jerky anymore and we went from there on the fine tuning.
Cory
Old 02-15-2010, 09:13 PM   #7
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
its safe to assume for this type of internet tuning to occur, that moto has a wideband o2 sensor??
scoobystas is offline   Reply With Quote
Old 02-15-2010, 09:24 PM   #8
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
yep. AEM UEGO.
Old 02-15-2010, 09:59 PM   #9
motocooney
Member#: 176235
09 Mazdaspeed3
I think the fact that I've done like 6 or 7 4th gear WOT runs in the past few days....I feel like I'm pushin my luck a little
I'll update the post if I grow some balls and decide to go for it
Old 02-16-2010, 08:45 AM   #10
al82
Member#: 177913
2011 WRX STi PBP
Nice numbers bro, i have the same turbo from TC.com on my WRX and making similar power.With almost the same mods on the mustang dyno i made 348whp 368wtq.
al82 is offline   Reply With Quote
Old 02-16-2010, 09:13 AM   #11
motocooney
Member#: 176235
09 Mazdaspeed3
That's bad ass. Everyone rags on TC.com but I got this turbo for like
$400! It seems to be doing what it's supposed to do.
You have a 2.5L so you must be spooling crazy fast too, right? I think the 7cm with the EWG is a great combo for the 2.5.
Are you on the stock motor?
Old 02-16-2010, 02:57 PM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
i think im up ~1,500 pulls
The only time i ever got "pulled over" i was sitting on the side of the road changing the map
Cop gave me the 5th degree and made me do half of the drunk tests. He said my eyes looked bloodshot so i said yeah i was going down on your wife and she poked me in the eye.
Old 02-16-2010, 03:58 PM   #13
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
So i said yeah i was going down on your wife and she poked me in the eye.
With what?
2gnt2wrx is offline   Reply With Quote
Old 02-16-2010, 04:32 PM   #14
motocooney
Member#: 176235
09 Mazdaspeed3
I'm way more scared of my wife than the cops! She can put a stop to this **** anytime she wants!
Old 02-16-2010, 04:50 PM   #15
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
nice work Cory!
Send me these logs for review
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 02-16-2010, 04:57 PM   #16
lunatic89
Member#: 224250
05 MR LUNA to U
MR BUILT 35r 13sec FTW
soo Matt couldnt fix it??
lunatic89 is offline   Reply With Quote
Old 02-16-2010, 05:30 PM   #17
motocooney
Member#: 176235
09 Mazdaspeed3
That's not the case at all. He didn't seem too worried about the A/F learning or stuttering when I called him...He sent me a couple revisions of the map to try but nothing changed. Then I replaced the torn inlet and everything got worse.. it got to the point that I knew something was off.
And it'd been like 3-4 months since he tuned the car. I felt like it was my responsibility to get it figured out. Unfortunately, I don't know **** about tuning cars That's when Cory got ahold of me....and made my car very drivable and really ****ing fast
I'm not ragging on Matt or Benchmark Tuning at all. They do great tunes and make great power. They were cool guys and super nice. I believe I was tuned with a leaky inlet. That's something I should've checked before I put my car on their dyno. MAYBE that caused the scaling issues and the drivability issues. I don't know.
All I know is that the car is running better now than it was before or after.
Old 02-16-2010, 05:42 PM   #18
2xhighpsi
Member#: 158089
2004 STi RomRaided
Damn. Good stuff Chris. I knew finding that torn inlet at my house was going to lead to more problems; Glad to hear you got it figured out.
Now I need to take ride in that car
2xhighpsi is offline   Reply With Quote
Old 02-16-2010, 05:49 PM   #19
motocooney
Member#: 176235
09 Mazdaspeed3
Yeah man...I'll give you a shout. Thanks for helpin me out AJ!
Dude, I PMd about loggin with the AEM. It's pretty easy to rig...sort of
EDIT: I won't give you a shout...because my phone got all ****ed up and I don't have your # anymore.
Gimme a shout man
Old 02-16-2010, 07:41 PM   #20
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Originally Posted by Vaus View Post
nice work Cory!
-- Ed
Thanks Ed... I should be giving you the credit for pushing me forward with tuning and training me in some essential areas. I couldn't have done this with out you man!
Here is the power on ed's road dyno software
*** Standard Dyno Chart Disclaimer ***
This software reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock WRX - 155-165whp
Stock STI - 215-225whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
380-390whp - 120-121mph traps
Old 02-16-2010, 07:52 PM   #21
motocooney
Member#: 176235
09 Mazdaspeed3
Mayhem Tuning FTMFW!!!!
Old 02-18-2010, 03:34 PM   #22
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
Thanks for the kind words, i'm glad your car is running right, and that everything is mechanically sound, a rip in the inlet can definitely cause the car to run different and cause driveability issues especially if it was small or almost non-existant when we tuned it then got larger (a possibility as to why the trims would change that much).
If there is anything else we can do to help you, let me know. Congratualtions on the great power
-Matt
Benchmark Tuning is offline   Reply With Quote
Old 02-18-2010, 06:50 PM   #23
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
-Matt
Matt
That's what I was thinking is maybe it was torn before the tune and got worse. Thanks for chimming in!
Cory
Old 02-21-2010, 01:41 PM   #24
Wrx.CHRIS.Wrx
Member#: 202991
2004 fully built
satin black/ lime green
Nice Cory........mayhem Tuning Ftw!!!!!!!
Wrx.CHRIS.Wrx is offline   Reply With Quote
Old 02-21-2010, 01:45 PM   #25
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Thanks Chris.
I wanted to update this! we found out his wled were breaking on WG flapper.
Fixed it and now spool is about 500 rpm sooner! I am loving the EWG on the 7CM 20G. A new graph will be posted soon
05 STI, 20G, EWG, 100% Meth Injection Equilibrium Tuning Proven Power Bragging 40 07-09-2009 04:47 PM
FS: 05 STi Cobb AP V1 w/ custom tune cfelix10 Engine/Power/Exhaust 4 01-25-2008 03:30 PM
FS: 05 sti fp green coilovers sparco Cobb tuned godfather2112 Private Vehicle 'For Sale' Classifieds 35 11-07-2007 06:15 PM
05 STi 20G 91 octane conservative tune 12.72 @ 108 benw Proven Power Bragging 18 11-16-2006 07:53 PM
04/05 STi UTEC & WRX UTEC - Dyno Tuning Available Gruppe-S Bay Area Impreza Club Forum -- BAIC 6 01-19-2005 07:32 PM
