Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-15-2010, 11:28 PM   #1
hpg88
Member#: 62677
1995 impreza
green
Default 94 Jdm Ej20g Ecu Pinout
can anyone on here please help me. i really need a ecu pinout for a 94 jdm ej20g. i just swapped my motor and im not getting any spark. please let me know if u have any info.
hpg88 is offline   Reply With Quote
Old 02-15-2010, 11:57 PM   #2
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
whats your ecu code.. 4 plug right? give me your email and ill send it
azn0boi04 is offline   Reply With Quote
Old 02-16-2010, 12:04 AM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
http://www.vwrx.com/electrical/95%20...g%20Charts.xls
This one is easy to read. Rob has a good one as well.
Old 02-16-2010, 12:06 AM   #4
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
isnt that for the ej20k? or are the ecu basically the same..
Old 02-16-2010, 12:17 AM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
No it's a G and the ecu is not the same.
Old 02-16-2010, 02:01 AM   #6
suberdave
Member#: 101865
88 GL-10 STi
this is what i have...
EJXXX ECU pinouts.xls
EJ20G JDM UK.pdf
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 03-14-2010, 09:12 PM   #7
Perennialphil
Member#: 241020
Hello there everyone!
Well, I have an EJ20X, X being an unknown atm. I know it's a JDM 94 WRX turbo and the ECU has three yellow plugs, with 16, 22 and 26 pins respectively. From the pinouts I've looked at, it most closely resembles the EJ20K in Suberdave's "EJXXX ECU pinouts.xls" file. I've identified all the wires where the three plugs enter the ECU, but I'm wondering what the "XXX"'s are in the pinout. For example connector B135 pin6-7 and 11-13, connector B136 pin 15 and Connector 137 pin 4-5, 16, 18-19, 22-23. If anyone can help me and shed some light I'd be much obliged.
I've yet to trace the wires to their appropriate ends in the engine, dash, or other parts of the harness as I'm pretty much ignorant on the subject and am learning ALL about 1) Electrical wiring (diagrams and theory/application) 2) Automobiles/maintenance/well everything car related. Simply, I'm not there yet but from what I can see so far, it doesn't even look like the end of the wires I have which connect to the ECU go anywhere on the engine... I have a funny feeling the harness comes from a different engine than the one I have... Some wires seem to be missing and some are spliced in odd ways with other wires which, according to my engineering friend, does not really make any sense. So we think someone tampered with the harness before I got it. The vendor should be contacting me in the next couple of days to shed some light on *those* subjects.
The engine is going into a 1985 A/T Westfalia camper btw... so if anyone has any extra help, feel free :-), I appreciate all advice, tips etc.
Phil
Ottawa, Ontario, Canada
Perennialphil is offline   Reply With Quote
Old 03-14-2010, 09:42 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
A 94 WRX is an EJ20G and should have a 4 plug ecu. If your ecu is a 3 plug it might be from an EJ20K. Best thing to do is post pics of your engine and the code on the ECU and somebody here will tell you what you have from that.
Old 03-16-2010, 02:36 PM   #9
Perennialphil
Member#: 241020
Hullo everyone,
Ok, so some pics of my engine... I can't attach on here and I tried to attach them on VWRX.com, but that just gives me the message "sending request to www.vwrx.com..." and nothing happens. I'm not sure if I can post my email on this forum... but perennialphil@gmail.com. The shiny "nice looking engine" pics I will send you are the ones the vendor sent to me, the others are the recent ones I've taken. If you notice any discrepancies which don't include missing MAF piece, intercooler and fuel hoses or other hoses, feel free to point them out.
The numbers on the ECU in case you can't read them are, from top left to bottom right: 4G, 226 11 AC560, A 18-000 DH7, 6916.
I'm not sure if the "1"'s are 1's or some kind of separation like "|".
Hope this helps you help me! Let me know if any other info is needed.
Phil
Old 03-16-2010, 02:40 PM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
Host your pics on a site like photobucket and then use [img][/img] tags to post them on here. If you can't figure it out pm me and you can email them to me and I'll post them for you.
Old 03-16-2010, 03:26 PM   #11
Perennialphil
Member#: 241020
Default Sweet!
Here's the link let me know if it works or not.
http://pbckt.com/sS.SLh
Old 03-16-2010, 04:06 PM   #12
ROentje
Member#: 162452
2005 S203
gray
just so you know the pics work.
Engine looks like ej20G.(as far as my knowlege goes).
Don't have pinout.
ROentje is offline   Reply With Quote
Old 03-16-2010, 04:08 PM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Ej20H twin turbo. Looks like a bunch of your vacuum hardlines have been cut as well. That thing is going to be a beast to get to run right. With the damage I suggest you convert it over to single turbo and run it like it's an Ej20G or EJ20K.
Old 03-16-2010, 04:24 PM   #14
Perennialphil
Member#: 241020
EJ 20 H twin turbo? You sure? Ok so will the ecu I have work for it? I talked to the vendor today and he told me it was from *that* engine. If it is
an H twin, there would be 4 plugs for the ecu right?
Old 03-16-2010, 05:01 PM   #15
Matt Monson
Member#: 832
99 2.5RS, '85 911
Does it have two downpipes? Does it have two turbos? Twin turbo.
It could be an Ej20R. I didn't look all that closely, and couldn't tell you how many plugs either of them has. But that's not Ej20G. I know that for sure.
Old 03-16-2010, 06:22 PM   #16
Perennialphil
Member#: 241020
Would the ecu I have work?
Old 03-16-2010, 06:47 PM   #17
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
Info I found says its an EJ20R, 1997 probably. and what Matt said is accurate, that with all that bastardized wiring and things cut here and there, you're in for a lot of giant headaches trying to get it to work. ESPECIALLY if youre planning on swapping into a LHD car. You could convert it to single turbo, i would recommend getting an ej20k or late ej20g wiring harness with the same style of 3-plug ecu. you wouldnt be able to use the EJ20R ECU with a single turbo setup, at least i doubt you could
elislider is offline   Reply With Quote
Old 03-16-2010, 07:01 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
I'm not so sure that the ECU needs to be tossed. Most of the turbo control between the two turbos on that engine is vacuum based. I don't think the electronics are that involved other than on fuel and timing. I suspect it could be managed with a boost controller.
It's been a long time since I've looked there, but the RS Liberty forum in Australia used to have a few good write ups of guys converting their TT's over to single turbo. The other forum you might look at would be SIDC in the UK. Overseas is where you'll find the expertise on the twin to single turbo conversion.
Old 03-16-2010, 07:40 PM   #19
69subaru360
Member#: 159682
1995 WRX
2015 F150
That is quite the mess you bought. I'd agree, convert it to single turbo. For a VW van, you might want to look into an aftermarket standalone ECU and make up a new harness with just the basics to run it. Megasquirt or something similar might work out ok.
Old 03-16-2010, 10:12 PM   #20
sgm_sti
Member#: 241381
bumpp
sgm_sti is offline   Reply With Quote
Old 03-16-2010, 11:57 PM   #21
Perennialphil
Member#: 241020
Thanks a million folks for the replies. Lots of help. I'll have a look at those forums and see what I can learn. A friend of mine did mention I might want to take a look at megasquirt...
So, to be specific, what is the mess I'm looking at? As I menionned earlier, I'm kind of new to the automotive world... What can you all see that's missing or that I would need? I've been talking with a guy from a motorsport outfit who told me the following today:
"the system we use is EMS, the model would be the Stinger, The ecu, harness, igniter and base map is $1500. it will plug on and run right away, it will need some final tuning and is laptop friendly and easy to use. We build these units daily, we do run them in open loop (that means we do not use an oxygen sensor, they do have provisions to do that if requested. it will run off of all your stock sensors and has a dedicated Subaru mode so nothing has to be done with the crank or cam sensor. you can check out the software at www.fuel-injection.com* we are the US west division, also it does not need a MAF to run the engine, it uses a MAP sensor instead"
So, 1500 seems like a lot when a megasquirt unit can be had for 250-400$ ish? The harness... I've been working on mine and it seems dooable, and I understand if I go megasquirt I need to build my own harness right? If I do that, what about the O2 sensor and maf/map. Thing is I don't know which way to go and what combination of things I need to do to make this work. I know I need a maf or a map, but which would work best?What about O2 sensor? Do I need one?
Again, thank you all very much for your help, I appreciate it very much. I'm learning and enjoying it... Problem is time a money both of which I have little of... Gotta on the road in one month, and I have about 2000k before I'm tapped out/broke as... Well...
Phil
Old 03-17-2010, 12:11 AM   #22
69subaru360
Member#: 159682
1995 WRX
2015 F150
By mess, we mean the hacked up wiring and the twin turbos. The twins don't have a very good reputation. You must have talked to outfront motorsports. I've dealt with them twice and they seem to know what they are doing.
Old 03-17-2010, 12:12 AM   #23
Perennialphil
Member#: 241020
Ok some research I've done here :http://en.m.wikipedia.org/wiki/Oxyge...edirected=true suggest I want an O2 sensor and a closed loop... Now, do I want to work with the harness and ecu I have now or get megasquirt? I have a month and very little "credit" left on my credit card ;-). All brainstorming is appreciated! Thanks :-)
Old 03-17-2010, 04:49 AM   #24
elislider
Member#: 133923
03 Legacy GT wagon
most standalone ECU replacements do not actively use the O2 sensor for feedback while running (whereas the stock ecu does, under average driving, ie. closed loop, and not when you are under moderate to heavy throttle, ie. open loop). an O2 sensor (wideband) is traditionally used for tuning so that it is known what values of AFR (air to fuel ratio) result from the different combinations of load/rev/fuel/ignition timing/injector duty/etc., and that can be used as a baseline for making the injector map. knock values are traditionally logged and used to make the ignition timing map as well.
also if you are curious, here is a neat site i found for all the jdm legacy models
http://homepages.ihug.co.nz/~ccgrant/leggymodels.htm
yours right there in the middle of the BD/BG section:
Code:
        BD5
	RS
	BD5B48D
	B type(06/96-07/97)
	MT
	4G
	205
	EJ20RDWCJE
        BG5
	GT-B
	BG5B5CD
	B type(06/96-07/97)
	MT
	4G
	205
	EJ20RDWCJE
Old 03-17-2010, 10:10 AM   #25
Perennialphil
Member#: 241020
Ok so this morning I looked for a VIN. The only two markings I could find on the engine were EJ20 (under the alternator) and 727491, which was on top under where the intercooler would be, between the 2 turbos and just above where the tranny and engine meet. Anyone know if I can use that 6 digit number to find out what happened to this car before I bought it?
need: SMJ foldout page for 94 JDM EJ20G (plug R1) supermoose Subaru Conversions 2 07-03-2015 03:09 PM
JDM forester ECU pinout 02SKReX Pre-2002 Factory Turbo Powertrain 18 10-22-2014 07:47 PM
Need: SMJ foldout page for 94 JDM EJ20G (plug R1) Please! chrisc1991 Subaru Conversions 1 01-20-2009 10:28 AM
EJ20G ECU pinouts smacksube Subaru Conversions 5 12-18-2003 04:07 PM
97 JDM WRX ECU pinouts Subie2 Subaru Conversions 3 07-09-2003 05:05 PM
