Old 02-15-2010, 10:39 PM   #1
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Thumbs up Gates timing belt kit for $380
I'm in need of a timing belt change and while searching i came up to this site
https://www.aqmotorsports.com/shoppi...action=process
they sell the Gates full kit for only $380 and shipping to mu house is $17. Seems too cheap to be true. Any reason i should stop and not buy? I also have a 04 but it says will for 05+. Will it fit on the 04?
BlackFighter is offline   Reply With Quote
Old 02-15-2010, 10:49 PM   #2
wagonryan
Member#: 163756
1996 R/RA
what do you need a kit for?
the timing belt is like 60 bucks you don't necessarily need that other stuff yet.
wagonryan is offline   Reply With Quote
Old 02-15-2010, 10:56 PM   #3
BlackFighter
Member#: 193940
2004 WRX STI Black
Well i'm already over 70k and will be putting on a FP Green and since its time for a timing belt change y not change everything. Don't know how hard the Green will be on 70k mile pullys. Or will the pullys be fine, hell if they will then i'll just get the belt, tensioner, and water pump.
Old 02-16-2010, 06:58 AM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
70k is NOT the change interval for that belt, it's way too soon to change it. A turbo has zero to do with belt life. When it's time, get a timing belt from NAPA, they are super cheap and are Gates. Then get a new tensioner from either NAPA or your dealer. Take the money you saved, send half to me and buy porn with the other half.
Old 02-16-2010, 11:51 AM   #5
rkramer
Member#: 118209
2015 WRX Limitec
its always amazing why people want to change the timing belt at 60k, on an engine platform that doesn't have a history of breaking belts.
Old 02-16-2010, 12:20 PM   #6
BlackFighter
Member#: 193940
2004 WRX STI Black
Unabomber we have a deal :-) Thanks, i didn't know that the subis don't have a prob with timing belt taring, thats good news. When do you think is a good time to do it?
How do i know when it is time? When it wrips? Hope not cuz then it will too late.
Old 02-16-2010, 12:31 PM   #7
ritky
Member#: 72285
2005 STi Wingless
FLA Turnpike > I-95
Change interval on late model subarus is 105K for the timing belt.
You won't know if your bearings are going bad until you remove the belt and check each bearing. If the bearings spin freely, have any rough spot in rotation or the belt guide surface is mared, then they need replacement.
With that being said the smallest bearing on mine seemed to be in the worst shape. I probably could have gotten away without replacing the other 3 larger bearings.
ritky is offline   Reply With Quote
Old 02-16-2010, 04:50 PM   #8
madmax718
Member#: 172501
hard to say- I just replace the rollers- think about all the extra time you waste already getting to that timing belt- all that- just to... have to do rollers again in 30-40k?
madmax718 is offline   Reply With Quote
Old 02-16-2010, 05:50 PM   #9
BlackFighter
Member#: 193940
2004 WRX STI Black
Thats how i'm seeing it, but i will be paying some one to do it so while there you know
Old 02-20-2010, 07:36 PM   #10
flwrx
Member#: 35944
'03 v7/6mt/30r wrx
MBP
On Napa's site it looks like the gates belt is $124.00 which is hardly super cheap; it's actually more costly than OEM. They have the tensioner listed for $172.99. Seems like the kits importimage ($335) and others sell are worth it. $296 for just those two items from napa or for additional $39 get 4 pulleys and waterpump too.
flwrx is online now   Reply With Quote
Old 03-03-2010, 06:07 PM   #11
Buggn' Out
Member#: 173971
02 /05 WRX
Aspen White, facelifted
I looked on NAPA's website also but saw nothing close to a $124 timing belt. They offer 4 different options (atleast for the 02-03 Imprezas) that ranged from $71.30 to $92.77. My question is which one (part #) is the Gates brand? They show 2 belts as being NAPA brand and 2 other belts as Altrom brand....so which is mfgd. by Gates??
Buggn' Out is offline   Reply With Quote
Old 03-03-2010, 11:43 PM   #12
BlkTS02
Member#: 50142
2002 2.5TS
MBP
I changed my timing belt the other day. I replaced all the pulleys (they were still smooth and without play but they were spinning too easily), waterpump, thermostat, radiator hoses, coolant. I decided against replacing the cam and crank seals, hopefully that won't come back to bite me.
Since you'll have everything accessible, replace it before you have a catastrophic failure.
70k miles is too soon, 105k is the recommended life.
BlkTS02 is offline   Reply With Quote
Old 03-03-2010, 11:44 PM   #13
BlkTS02
Member#: 50142
2002 2.5TS
MBP
The expensive version is the gates blue belt, similar to the STi kevlar reinforced belt.
Old 03-06-2010, 09:55 AM   #14
Buggn' Out
Member#: 173971
02 /05 WRX
Gotcha, thanks.
Old 03-08-2010, 05:59 PM   #15
wrxpaul
Member#: 83600
03 wrx wagon
I just picked up an 03 wagon with 130k. Got it cheap the previous owner thought the engine was knocking but in reality it was the tensioner that was bad. You could move it by hand, the idler with teeth's center bearing was completely gone. Timing belt had a tear in the middle it was ready to go.
wrxpaul is offline   Reply With Quote
Old 03-11-2010, 08:03 PM   #16
DerrickRH
Member#: 75078
2000 Legacy GT
Black Granite Pearl
i was under the impression the Napa brand belts were manufactured by Gates. is that right?
DerrickRH is offline   Reply With Quote
Old 03-11-2010, 08:40 PM   #17
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
NAPA brand belts and CarQuest brand belts are made by Gates.
Gates Timing Belt Kit (Pulleys) The difference ritky Service & Maintenance 21 10-25-2015 04:39 PM
GReddy, STi, or Gates Timing Belt caliREXSTI Service & Maintenance 5 04-05-2008 09:46 PM
SOHC 2.5L (EJ25) Gates timing belt for sale Atwood Private 'For Sale' Classifieds 0 09-03-2005 01:08 AM
