Old 02-16-2010, 09:48 AM   #1
the Stryder
Member#: 170685
2013 Crosstrek DGM
1999 Forester battle tank
Default Stage 2 and valet mode question
Has anyone ran into a problem being stage 2 and using valet mode? I am about to valet my car for a few days and I'm kinda nervous about it so I want to use my valet mode but the map notes say it's only for a stock vehicle...
My car: 2007 WRX: SPT intake, invidia catless DP, HKS catback (restrictor pill has been swapped for the 07 catless boost spiking issue).
Any help would be appreciated
the Stryder is offline   Reply With Quote
Old 02-16-2010, 11:03 AM   #2
Pearl04
Member#: 178913
06 STI
The way the valet map works is it just moves the rev limiter to 2.5K RPM. Other than that it is just like using a stock map. Using it for a few days wouldn't be too bad, especially if they just park it and bring it back to you. Don't stress it too much. People use the stock map with those same parts and their cars don't explode after three days.
The easy fix: Just run it. It won't blow up.
The good fix: use access tuner or romraider to build your own valet map. Just move the rev limiter down. I want to know if there is a way to rescale the throttle position sensor. I doubt it.
The best fix: If you feel uncomfortable dooing that, have cobb or any tuner build you a valet map taylored to your car.
Pearl04 is offline   Reply With Quote
Old 02-16-2010, 11:07 AM   #3
the Stryder
Member#: 170685
2013 Crosstrek DGM
Thanks Pearl. It's only for a couple of nights and I think I will just put it into Valet mode and not stress it. It should only be going a few hundred feet from the front of the hotel into their garage that is under the building. I just don't trust anyone with my car.
Old 02-16-2010, 11:12 AM   #4
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
Yea, you'll be fine. I run an aggressive protuned map and I flash the valet mode anytime I drop the car off to the body shop or to get an alignment. No problems at all.
AlxSti is offline   Reply With Quote
Enginuity and valet mode wrxsti.l Open Source Reflashes 16 02-02-2008 06:21 PM
Question about CEL and Valet Mode ( AP ) Dragonbreak North West Impreza Club Forum -- NWIC 2 08-15-2007 05:22 PM
Stage 2 and D.P question jflexe99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-24-2007 09:10 PM
BASE MAP: Valet Mode Questions ruski AccessPort 2 03-11-2006 04:38 AM
Valet mode question WR-REX Engine Management & Tuning 7 05-07-2004 06:34 PM
