Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 02-16-2010, 11:03 AM   #1
integroid
Member#: 49222
2005 Legacy GT Wagon
Limited 5MT 580whpQ16
Default Topspeed Tuned - Precision 6262 in Built LegacyGT
Event: dyno pull
city and state: Alpharetta, GA
Ambient Temp: ~45*
Elevation: ????
Weather: sunny
Track and Conditions: N/A
slightly up or downhill: N/A
Tires: RE-01r
Car: 2005, LegacyGT Wagon 2.5 liter
Tuner: Doug at topspeed
Dyno Info: dynojet
Peak HP at RPM: 580hp 6.2-6.5k rpm uncorrected
Peak Torque at RPM: 518tq ~5.25k rpm uncorrected
Baseline hp/tq for a stock on same dyno: 230hp for stock Legacy
Target Boost: 30psi
Target AFR: n/a
Fuel: VP Q16
Tune: Cobb AP V2
Engine/Power Modifications: See Below
Driveline Modifications: See Below
Suspension Modifications: See Below
Other Modifications: See Below
I was told I sould post this here as well as the other boards.
2005 Legacy GT Limited WAGON!
The Build list is below. Please remember this is on the STOCK 5MT Tranny and it didnt blow
Ported/Polished Fully Worked AVCS Heads
Supertech SS +1MM Intake Valves
Supertech Inconel +1MM Exhaust Vavles
BC Valve Springs
BC Ti Retainers
BC 272 AVCS Cams
EJ255 Shortblock
Eagle Rods
Mahle 100MM Pistons
ACL Race Bearings
ARP Studs
11MM Oil Pump
Oil Passage Mods
Gates Racing Timing Belt
JDM TGV Housings
Bosch 1000CC Injectors
TurboXS Fuel Rails
Fuel Labs FPR
TSPmotorsports EL Header (importimage brand header)
Ball Racing Rotated Kit
Precision 6262 V-band turbo
Greddy SPII Exhaust
Tial BOV
Tial 44MM EWG
Cobb APv2
KillerBee Oil Pickup
Custom 3.5 Inlet and MAF housing
Custom EBAY FMIC (and proud of it!)
BC Racing Coil-Overs (F-8K, R-10k)
Whiteline F&R Sway Bars
Perrin End Links
Perrin PSRS
STI Brembo Front Calipers
Stoptech STI Slotted Front Rotors
DBA 4000 Rear Rotors
Hawk HP+ F&R Pads
SS Brake Lines
ACT 6Puck Sprung Clutch
ACT Streetlite FW
Rota Tarmac 2 18X8
235/40/18 Bridgestone RE01r
and the end result on Q16
integroid is offline   Reply With Quote
Old 02-16-2010, 11:11 AM   #2
fourmicah
Member#: 128760
2015 STI
WOW!, and on a stock tranny! I'm sure the race gas helped. Plans on a 93 tune
fourmicah is offline   Reply With Quote
Old 02-16-2010, 11:14 AM   #3
integroid
Member#: 49222
Oh, yeah it made 465 whp @21psi on 93 octane pump. That is my daily driving conservative tune
Old 02-16-2010, 12:43 PM   #4
Blown95ImpalaSS
Member#: 87629
ssiiiicckkk, a serious battlewagon
Blown95ImpalaSS is offline   Reply With Quote
Old 02-16-2010, 01:24 PM   #5
blackrex13
Member#: 194884
2002 vf-29'd
WRB WRX
Very nice, i think we met saturday
Plastic intake manifolds FTW!!
blackrex13 is offline   Reply With Quote
Old 02-16-2010, 01:50 PM   #6
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Sweet setup, what is the the AR of the 6262?
Where is ball racing located?
you need more boost
Old 02-16-2010, 02:10 PM   #7
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Nice work Doug!
I'm also curious about the hot side A/R and how the precision v-band a/r's compare with Garrett T3 a/r's. Are they under-estimated like Tial v-band a/r's?
javid is offline   Reply With Quote
Old 02-16-2010, 02:51 PM   #8
integroid
Member#: 49222
It is a .82 Full V-Band hotside
Old 02-16-2010, 04:06 PM   #9
integroid
Member#: 49222
Originally Posted by juanmedina View Post
you need more boost
I have stock sleeves so I doubt they will handle much more boost. I am getting my 6 -speed in, then probably switching to an AEM and upgrading the fueling. Hopefully that will be enough to get me over the 600 whp barrier.
Old 02-16-2010, 04:20 PM   #10
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Wow, very nice man.
stretchedk7 is offline   Reply With Quote
Old 02-16-2010, 04:21 PM   #11
moorebl
Member#: 59238
gotta love the 6262 i had one in my old sti. loved it. loads of powa
moorebl is offline   Reply With Quote
Old 02-16-2010, 04:26 PM   #12
gotsol
Member#: 17346
08 Cayman S
damn! Are you running meth?
gotsol is offline   Reply With Quote
Old 02-16-2010, 04:29 PM   #13
integroid
Member#: 49222
Nope, that was on straight Q16.
Old 02-16-2010, 08:28 PM   #14
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
journal bearing or ball bearing?
ownnij is offline   Reply With Quote
Old 02-16-2010, 08:48 PM   #15
integroid
Member#: 49222
Journal Bearing...this was a budget build
Old 02-16-2010, 08:49 PM   #16
juanmedina
Member#: 133146
07 FPgreen 7.37@95
sweet, Where is ball racing located?
Old 02-16-2010, 08:56 PM   #17
integroid
Member#: 49222
Ball Racing is really just one local guy that does one off Rotated kits. Honestly, the only thing left of his original rotated kit was the downpipe. The rotated uppipe and some of the FMIC piping was made by Batlground in Atlanta and the intake was made by me and a friend at a huge VW/Audi/Porsche tuner. I cannot say who because they would rather not be kown for working on Subaru's They actually helped me a lot on other aspects of my car. The engine was built at Ball Engines (not the same as ball racing) in Lilburn, GA. They build the majority of the Subaru motors locally. I also had help from Sargent Performance. Basically I used all the TOP Local Subaru people in all aspects of my build. It was nice to see them all lend a hand where needed.
Old 02-16-2010, 09:01 PM   #18
ownnij
Member#: 70459
damn your numbers are fing sweett.... any plans for a pump gas tune?
Old 02-16-2010, 09:02 PM   #19
integroid
Member#: 49222
I posted above
Old 02-16-2010, 09:22 PM   #20
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Nice number delette was telling me about your car. beast for sure
robbieshonda is offline   Reply With Quote
Old 02-16-2010, 09:44 PM   #21
crashtke
Member#: 120912
Glad we could lend a hand here and there. The car really exceeded my expectations. Congrats man!
crashtke is offline   Reply With Quote
Old 02-16-2010, 10:02 PM   #22
MartinSTi05
Member#: 145145
2006 wrx STi
Care to elaborate on the "oil passage mods"?
MartinSTi05 is offline   Reply With Quote
Old 02-16-2010, 11:02 PM   #23
ownnij
Member#: 70459
damn this thing is a beast... i always wanted the pt6262.. but so broke.
Old 02-17-2010, 04:24 AM   #24
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Thats pretty sweet but you should see if the 5 speed will handle the power for some certain amount of time.
Great work by topspeed!
project_skyline is offline   Reply With Quote
Old 02-17-2010, 08:21 AM   #25
integroid
Member#: 49222
There were some oil passages in the block that Ball Engines opened up to help with better oil flow. Exactly what and where they were I have no clue. They asked if I wanted it done and said it would take another few hours so I said sure
precision 6262 built sti? who?? moorebl Proven Power Bragging 11 06-12-2010 06:50 PM
precision 6262 wont fit to my 3'' ultimate racing downpipe. moorebl Built Motor Discussion 11 05-17-2009 11:26 AM
WTB: precision 6262 t3 flanged moorebl Private 'Wanted' Classifieds 2 04-14-2009 07:43 PM
precision 6262 billet tubo????????thoughts moorebl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-11-2009 10:04 PM
