#1 |
Member#: 239847
Vehicle:2011 sti sedan swp |
just seeing if there is a location in either of the 2 fuse boxes either under the drivers side dash or under the hood in that box where there is a fuse for the o2 sensor. i've read that you should check the fuse before going out and buying a new sensor
#2 |
Member#: 198418
Vehicle:2009 WRX Hatch OBP |
anybody
#3 |
Member#: 193628
E. Canada
Vehicle:2010 STI SSM |
Just test all the fuses with a test light and see if one of them is blown. If the o2 sensor has 12 volts going to it for the heater or whatever then it would be fused somewhere.. but its probally on the same system as other things as well and would not have its own dedicated fuse.
Your car is a 09.. and your oxygen sensor is gone allready? Warranty should cover that.. |
#4 |
Member#: 239847
no i dont know if my sensor is gone already...i had another thread b ut got no response. my rear o2 sensor rubbed on the drive shaft and it wore away the green cover and 2 of the wires ripped..maybe this shorted something. i keep getting codes for the front and rear o2 sensors i think they are 0031 and 0037. i can clear the rear but it comes back, the ap will not let you clear the front. my car has 12000 miles on it so i doubt my o2 sensor went even tho i know i will need a new rear since it tore. i am st 2 so i doubt the dealership would cover this under warranty. any help would be great
#5 |
Member#: 236677
The O2 sensor generates its own current based on the difference in 02 concentration on both sides of the element. There is an atmospheric side and the exhaust side, there is also a heater element but it's only used when the O2 sensor is cold. Rich A/F ratios will generate current because of the difference in O2 concentration (Oxygen present in the atmosphere versus the lack of oxygen in your exhaust). I would imagine that there may be a fuse for the heater element present in the O2 sensor, but if the fuse was blown it would only affect the O2 sensor when the car is cold. the current generated by the O2 sensor itself is very small and I'm pretty sure that it isn't hooked up to a fuse, but I'm not 100%.
#6 |
Member#: 338507
Ive been looking for the same fuse box...ive read some cars have it. the STI for example i read its under and behind the glove box. would it be the same for the WRX? I also have an 08
| Thread Tools | |
| Display Modes | |
| Electrical fix for rear o2 sensor 05 wrx | boostin AWD | Newbies & FAQs | 2 | 06-30-2007 02:22 AM |
| wire color for o2 sensor | potholessuk | Electrical & Lighting | 3 | 01-26-2004 04:35 PM |
| CEL fix fr rear o2 sensor 04 WRX/STi ?? | jagcars26 | Factory 2.0L Turbo Powertrain | 3 | 09-02-2003 05:22 PM |
| FYI - Special Socket for O2 Sensor | MNbiker | Factory 2.0L Turbo Powertrain | 12 | 03-03-2003 10:33 AM |
| THERE IS A RECALL FOR MY00 RS FOR O2 SENSOR PROBLEM CALL YOUR DEALER | CHACHI | Normally Aspirated Powertrain | 12 | 04-07-2001 03:07 PM |
