Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 09-14-2010, 05:52 PM   #251
DigitalPunk
Member#: 124236
2006 WRX Built EJ257
Version 8 Twinscroll
Originally Posted by Turn in Concepts View Post
Car is back together (sort of). Going up to be dropped off for tuning. I'm just going to leave it there and they'll try and squeeze it in when they have time. That gives them some flexibility as they won't have me looking over their shoulder.
As for the car - the center diff is still flipping out. gotta take a look at that. I suspect I know what's going on there.
The old tune was on an apv1 and AVCS was not touched. The new tune will have avcs tuned.
Other than that nothing else will have changed on the car from the VF37 to the Blouch setup.
Stock bottom end
Stock cams
Stock heads
walbro 255
660cc injectors
~85K miles
Nothing special on the motor for this one. Based on the miles, and how much we'll be pushing into it I wholly expect it to pop sometime. When? Not sure. Won't hurt my feelings when it does happen.
At that point we'll look into doing some trick stuff with the motor.
i'm going to lose sleep waiting for results!
DigitalPunk is offline   Reply With Quote
Old 09-14-2010, 06:10 PM   #252
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Originally Posted by DigitalPunk View Post
He also mentioned some details about a car in Europe with the same turbo, minus the 2.5l i think, and it made around 466whp on e85. that is awesome power.
So wait..... was the blouch turbo they used on a 2.5 STi? 10psi at 3500rpms sounds pretty slow to me. At what point did they get full boost?
466whp with E85 on the blouch TS???? I REALLY want to find out more on this. If it spools better than mine right now count me in
LIQUIDSK8S is offline   Reply With Quote
Old 09-14-2010, 06:25 PM   #253
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Stock bottom end
Stock cams
Stock heads
walbro 255
660cc injectors
~85K miles
I hope you didn't burn out your center diff, if that sucker because purple, prepare to cash out $1k for a rebuild kit
also, can you specify if you are testing this on a 257/207/205 motor?
Hyper is offline   Reply With Quote
Old 09-15-2010, 04:12 AM   #254
Salmacis
Member#: 134496
I believe that's 465.5BHP UK standard and not WHP.
Have a look at the dyno graph:
http://bbs.scoobynet.com/showpost.ph...&postcount=318
Here are all the results of the SC/Blouch billet range:
http://bbs.scoobynet.com/799025-scoo...better-32.html
Salmacis is offline   Reply With Quote
Old 09-15-2010, 02:28 PM   #255
DigitalPunk
Member#: 124236
i must have miss understood. anyhow, i still like that number! those sc/blouch billet turbos fit the jdm uppipe flange?
edit: i see that these turbos are very different from what i imagine a modded vf37 will be like. still waiting anxiously for TiC's results!
Old 09-15-2010, 06:56 PM   #256
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Yeah 460bhp is more like 370whp........ which with E85 is not impressive at all. If you're going to go through the trouble of upgrading the VF37 and running E85..... you shouldn't settle for less than 400whp.
Old 09-16-2010, 03:35 AM   #257
Salmacis
Member#: 134496
As far as know, SC makes both single scroll billet and twin scroll billet versions (to fit JDM spec c / v8-9 TS dp/uppipe/header flanges) of their turbo's. I am not sure if Blouch is involved in the casting of the TS exhaust housing, but in the UK you do not need to supply a VF37 exhaust housing anymore. They cast it them selves and that's good news
On a side note....
I am going to get a Litchfield LM450-S60 for my TS converted v.7 Wrx STi. The turbo makes consistently 450BHP on 99RON pump fuel and spools fast on a AVCS 2.0l. That's enough for me as I am still on a stock bottom end. It is however a bit more expensive than Blouch. Rumors have it Litchfield are working on a billet version You can read about them on bbs.scoobynet.com/forum.php
Old 09-16-2010, 03:05 PM   #258
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i agree, i can make 340whp on my vf37 on e85, running 24 psi,thats only ~30whp more on more psi and about 400rpms slower spool, if i upgrade to something else i would like either more power with the same spool, or more than 30whp with slower spool, also i am running a stock 205 at 138k, on a fresh sti 2.0 i would expect faster spool, and maybe a little more power
seanathanq83 is offline   Reply With Quote
Old 09-16-2010, 06:05 PM   #259
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Yeah on a 207/257 with a vf37/e85 you should be see over 360whp depending on the mods.
Old 09-16-2010, 10:02 PM   #260
seanathanq83
Member#: 173241
im not to worried about power i want mid range and low end, i do alot of city driving and my goal is only 400, if i can get 350-360 i am more than happy, i will be running a ver8 207 with 9:1-9.3:1 i think with the better flowing heads, and the e85 i shouldnt have to worry about knock, i just want drivability
Old 09-17-2010, 02:29 AM   #261
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
nice
I actually regret I went for 8.5:1 in my build and not 9:1
Old 09-21-2010, 06:49 PM   #262
DigitalPunk
Member#: 124236
bump for TiC! =)
Old 09-21-2010, 09:55 PM   #263
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Did TiC go with the Dom 2.5 TS? I'm really anxious to see the results as I'm deciding between the Blouch setup vs the Litchfield turbos.
Old 09-24-2010, 07:56 PM   #264
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Quick update -
Got a call from Applied Tuning today. I threw the car at them, and said call when it's done.
They called today. 325 and 325. The injectors were not the limiting factor, but the intake. It started stalling out at 4.65v on the MAF. Even with pushing the boost up, and ignoring the stall it yielded 345 tq, but only 10 more horses.
So.... A new intake is on the way to them that will hopefully not stall out on the upper RPMs.
Now, I know a lot of people are going to poo-poo this, but hold on before you do. I have asked them to post up the plots from today. From what I understand the area under the curve is very nice, and the torque hits and stays there to redline.
We'll then be able to see what happens with the new intake when it arrives.
Old 09-24-2010, 08:20 PM   #265
Prevent
Member#: 149114
wonder if a 70mm APS intake would be suffice... i has one, wouldnt care to replace though.
Prevent is offline   Reply With Quote
Old 09-24-2010, 08:29 PM   #266
seanathanq83
Member#: 173241
I don't see why the intake is limiting, why not just do the 400g hack, I run speed density on a 65mm also on my vf37 on e85 making 340/340 consistant on mustang and airboys that's at 26 tapering to 23 no restrictive wall, it really sounds like when I had my vf37 with a 20g wheel, and the compressor wheel overflowed the exhaust wheel. What goes in must come out.
Old 09-25-2010, 12:02 AM   #267
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Quick update -
Which intake setup were you running, and what are you replacing it with?
Old 09-25-2010, 12:22 AM   #268
Turn in Concepts
Member#: 93646
Many Track Records
k&N typhoon. replacing with kstech 73mm.
Old 09-25-2010, 12:33 AM   #269
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
what kind of dyno does applied use? I bet just driving the 2.5L with twin scroll must be really nice and torquey around town!
scoobystas is offline   Reply With Quote
Old 09-25-2010, 12:35 AM   #270
Turn in Concepts
Member#: 93646
Many Track Records
I don't remember. They should chime in soon with plots from today.
Old 09-25-2010, 12:27 PM   #271
Turn in Concepts
Member#: 93646
Many Track Records
That's what Eric felt was limiting it and his recommendation. I do not know about the 400g trick but then I don't tune cars. I leave that up to the guy tuning it.
Since he does this for a living I go with what he recommends. Kind of like when someone comes to us for suspension, which we do all day long, we hope the listen to what we recommend.
I'd like to one day do e85 but just don't have time to get into that project so it will be 93 for this. Since it won't be seeing all out racing I don't feel it needs anything with a higher octane. We already have a car that demands attention for that (which we have been thinking about e85 for).
Old 09-28-2010, 01:15 PM   #272
WMP
Member#: 30625
Anybody else try this TS header yet? A guy in Australia seems to have good results...
http://cgi.ebay.com.au/Turbo-Exhaust...ht_2085wt_1137
WMP is offline   Reply With Quote
Old 09-28-2010, 01:40 PM   #273
DigitalPunk
Member#: 124236
i'm curious to see this power curve. still the numbers are ok for the amount of mods on the car.
Old 09-28-2010, 09:07 PM   #274
WMP
Member#: 30625
Curious as to what most of you TS guys are doing for a downpipe. Custom based on a TS flange? This looks like a nice solution after looking at that Ebay TS header a bit more...
http://cgi.ebay.com.au/Turbo-Dump-Pi...ht_1869wt_1137
Old 09-28-2010, 10:07 PM   #275
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Take a look at the shape of the gasket and the shape of the opening on that bellmouth. If it was the right shape I would have already given it a shot.
OppositeLock is offline   Reply With Quote
APS twin scroll rotated turbo kit TSR-70 who would buy it or not? 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 237 02-07-2010 12:16 PM
my new gp moto twin scroll rotated turbo! 06redsuby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 02-15-2008 12:30 AM
Twin Scroll BB Info needed . discopotato03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-10-2007 11:41 AM
New APS twin-scroll BB rotated turbo FOR USDM STI's!!! keaniegenie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 191 01-10-2007 01:12 PM
Will the new STI use a twin-scroll IHI turbo? bsix STi Forum Archive 0 01-09-2003 01:54 PM
