Old 11-04-2010, 12:11 PM   #426
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
Originally Posted by DigitalPunk View Post
my gas mileage with a regular vf37 is horrific! close to 10/g. anyone else having this issue? i wonder if the blouch will increase it. even if by a margin
i avg about 20mpg w/ej207 and usdm 5spd. You should be 17-18mpg w/TS and 2.5L.
Is it possible that your tune is setup to clear your CL delays and enter open loop at very low throttle inputs like 20-25%. I looked at my stock usdm 03' rom and its setup to enter open loop at 4K and 69.8% throttle input amongst other things like @78mph, while my current rom clears all delays and enters open loop at 3K, about 23% throttle, 32mph, there are alot of different variables in the OL/CL transition table that will cause you to enter the "richer" a/f targets.
Its just a possibility i guess.
btw, my delay is zeroed so there is no real "delay" once over those limiting figures, its just enters open loop, so check your A/F primary target table and make sure you like the A/F that is being targeted during cruising around. Basically it should target around stoich up to about 1 g/rev of load.
scoobystas is offline   Reply With Quote
Old 11-04-2010, 12:38 PM   #427
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Very nice guys! keep up the good work!
jnorth85 is offline   Reply With Quote
Old 11-04-2010, 01:16 PM   #428
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
wow dude even on e85 driving as aggresive as i can all the time i still get around 14-15mpg mt friends dom3 sti gets 17-18 and he does alot of spirtited driving i think you have a leak or something man
seanathanq83 is offline   Reply With Quote
Old 11-04-2010, 09:50 PM   #429
DigitalPunk
Member#: 124236
2006 WRX Built EJ257
Version 8 Twinscroll
i guess i'd better look into that. not much time these days
DigitalPunk is offline   Reply With Quote
Old 11-15-2010, 10:16 PM   #430
Mortal2None
Member#: 190077
2006 Subaru LGT BP
I would love to see a pick of the turbine side of the Blouch modded VF37. Anyone else other then TIC taken the plunge yet?
Mortal2None is offline   Reply With Quote
Old 11-16-2010, 03:02 AM   #431
Krang
Member#: 134272
Chapter/Region: HIIC
2007 Sti, DGM
Rotated EFR 6758
Figured some peeps in here could use this information. I have compiled methods/companies that produce solutions to twinscroll downpipes for stock location turbos HERE
Krang is offline   Reply With Quote
Old 11-16-2010, 04:48 AM   #432
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Originally Posted by Krang View Post
Figured some peeps in here could use this information. I have compiled methods/companies that produce solutions to twinscroll downpipes for stock location turbos here: http://forums.nasioc.com/forums/show...5#post32472175
Here's a link to the thread I think you were trying to link to that actually works:
http://forums.nasioc.com/forums/show....php?t=2088279
Concillian is offline   Reply With Quote
Old 11-16-2010, 05:27 AM   #433
Krang
Member#: 134272
2007 Sti, DGM
Rotated EFR 6758
I don't know why it wasn't working, the first couple times I clicked on the link it worked
Old 11-21-2010, 11:00 PM   #434
Moore Performance
Member#: 231489
Very good info and we're also working on getting a DP together soon. The pricing I'm seeing sounds about right, but we hope to offer some new options and new a design to this market. I hope to have updates soon, but we have a few other projects on our plate right now that we're working on finishing up first. I'll post updates when I can!
Moore Performance is offline   Reply With Quote
Old 11-22-2010, 01:35 PM   #435
HASTIhatch
Member#: 172694
2011 WRX STi
Very nice- excited. Subscribed
HASTIhatch is offline   Reply With Quote
Old 11-23-2010, 11:50 AM   #436
trick3d
Member#: 202146
2010 evoru
GG
Originally Posted by LittleBlueGT View Post
3. Sorry, but that info is incorrect.
Numerous shops have done dynos back to back of cars with heavier wheels and noticed essentially 0% difference in whp.
1.Lighter components do not lower the whp of a car, 2.they take more time to accelerate, yes. If you did a dyno run in 1st gear that lasted 1.5 seconds, you would notice a difference, but when you do runs that take 10+ seconds the difference is negligible.
I must quote this for its semi-fail.
1. He was saying they would increase them not lower them.
2. No they dont, lighter means they accelerate quicker.
3. How can he be incorrect if you are seeing change, regardless of impact.
Please dont jump to disprove something when your argument has not been thought out.
trick3d is offline   Reply With Quote
Old 11-23-2010, 12:57 PM   #437
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I believe he made a typo and meant heavier not lighter.
LIQUIDSK8S is offline   Reply With Quote
Old 11-23-2010, 10:13 PM   #438
sumfoo1
Member#: 82146
2005 Legacy GT
Wheel/tire hell even brake moment of inertia directly effects hp (not exactly weight but close) look it up on Sean hyland's dyno they lost 5 whp on a mustang (dyno and car) by putting on lighter brakes that were larger diameter thus had a higher moment of inertia. Being that tires on on the outside of the wheel package 1lb lighter tires gain more hp than 1lb lighter wheels. It's not just the weight of the wheels but the distribution of that weight. Hypothetically if a wheel had a 10lb rim 5lb hub and 4 lb spokes and another wheel had a 5 lb rim 10lb hub and 5 lb spokes the heavier wheel would actually yield more wheel horsepower but these are bs examples and rarely does a heavier wheel have a lighter rim than a light wheel. Just trying to teach some physics and say rotational weight has a direct effect on whp but where that weight is located on the rotating object has a huge effect too ( closer to the center the better)
sumfoo1 is offline   Reply With Quote
Old 11-29-2010, 01:01 AM   #439
MilesToEmpty
Member#: 129031
1998 Impreza RSTi
JBP
That cant be right.
My v8 swapped RSTI tuned safely at 305whp on the vf37 I can easily get 27 out of during the summer.
And are these in production yet?
I want to upgrade to something larger then the vf37 but stay with the twin scroll setup since everything on my car is setup for it... Plus I love the response and constant power.
MilesToEmpty is offline   Reply With Quote
Old 11-30-2010, 09:53 PM   #440
MilesToEmpty
Member#: 129031
1998 Impreza RSTi
JBP
Originally Posted by WMP View Post
MilesToEmpty,
Did TXS notch their off-the-shelf bell-mouth with a plasma cutter etc then cut a smaller diameter pipe lengthwise for the extended piece, if that makes sense? Or did they bend the extended piece from a flat piece of steel?
Sorry, I just dug back a few pages and saw this.
I honestly couldnt tell you how they made it. The next time Im up there I'll ask Brandon or Jermaine. Brandon did an incredible job on it. I think I remember Brandon saying he used another piece of piping and bent it to the correct shape. Sadly he works at another shop though
If I ever take it out Ill take photos of it for sure... But thats not going to happen till I figure which turbo to upgrade my VF37 from lol.
Old 12-02-2010, 04:53 AM   #441
Prevent
Member#: 149114
Besides the posted linked above, anyone else have an easy but successful twin-scroll downpipe solution ?
Prevent is offline   Reply With Quote
Old 12-02-2010, 11:14 AM   #442
seanathanq83
Member#: 173241
im sure it was already posted, but i just welded the twinscroll flange onto my stock down pipe, if you lay it on top two holes lines up, then just cut off one of the other tabs and weld her up, works wonders, dont have any problems, just need a little bit longer bolts
Old 12-02-2010, 11:50 AM   #443
Prevent
Member#: 149114
ANy pics ?
Old 12-02-2010, 11:08 PM   #444
seanathanq83
Member#: 173241
i can get some i will post them tomorrow
Old 01-10-2011, 05:08 PM   #445
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Any updates to the testing???
Old 02-05-2011, 10:46 PM   #446
Mortal2None
Member#: 190077
2006 Subaru LGT BP
He's dead Jim!!!
Old 02-06-2011, 12:14 PM   #447
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Updates?
none to really report. Car runs fine. Been daily driving it. Bone stock motor has 94k on it so need to refresh soon. I have some plans and ideas. especially for the breathing on the top end that was pointed out.
we've been crazy busy so our own cars get pushed aside to take care of cars for customers (and also why I'm at the shop on a Sunday replacing the steering rack on the wife's outback).
Old 02-06-2011, 12:25 PM   #448
Sinister_kid
Member#: 230988
2006 WRX
SGM
Originally Posted by Turn in Concepts View Post
Updates?
And superbowl sunday. Damn she is lucky.
Sinister_kid is offline   Reply With Quote
Old 03-01-2011, 02:15 AM   #449
chudlo
Member#: 15505
2002 JDMV8 STI Wagon
Any updates/progress on getting a twin scroll downpipe manufactured? I need to buy one soon and would love to just order a pipe already welded up, ready to go.
chudlo is offline   Reply With Quote
Old 03-01-2011, 03:14 AM   #450
Prevent
Member#: 149114
i wish there were more 42" long twinscroll downpipes
im currently fabbing up my own with an ebay usdm downpipe and cutting the bellmouth off OEM, getting it aligned is a bitch :/
APS twin scroll rotated turbo kit TSR-70 who would buy it or not? 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 237 02-07-2010 12:16 PM
my new gp moto twin scroll rotated turbo! 06redsuby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 02-15-2008 12:30 AM
Twin Scroll BB Info needed . discopotato03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-10-2007 11:41 AM
New APS twin-scroll BB rotated turbo FOR USDM STI's!!! keaniegenie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 191 01-10-2007 01:12 PM
Will the new STI use a twin-scroll IHI turbo? bsix STi Forum Archive 0 01-09-2003 01:54 PM
