Old 04-21-2011, 09:51 AM   #476
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Originally Posted by BigRigger View Post
Wait a sec... The TD05 18g and 20G TS they make are "smaller" then the VF37 Polka pickle?? Thats dosent make sence. A TD05 housing is bigger than a VF37 housing.
When you look at their page and compare the current single scroll TD05-18g/20g to the Dominator 2.5XT-R (Polka Pickle) you will see the pickle is a 49lb min turbo vs the 20g being 44lb. Now, the SC46 is the twin scroll version of the pickle but flows slightly less due to the housing, 47lb, which is still greater than the 18/20g flow.
LIQUIDSK8S is offline   Reply With Quote
Old 04-21-2011, 10:17 AM   #477
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
AFAIK SC46 is a 49lb turbo
Hyper is offline   Reply With Quote
Old 04-21-2011, 10:43 AM   #478
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
OP from Blouch has it as a 47lb
http://forums.nasioc.com/forums/show...98&postcount=1
Old 04-21-2011, 10:46 AM   #479
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
possibly they are different
I have the data from scoobyclinic
Old 04-21-2011, 10:54 AM   #480
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
I am not sure how this keeps being referenced to the 2.5XTR Polka Pickle. When in actuality it's more like the Blouch 1.5XTR as it uses a 56.5mm turbine just like the SC46 uses and then uses a 49 lb/min XTR compressor.
kayen is offline   Reply With Quote
Old 04-21-2011, 11:36 AM   #481
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
It's possible it was just a typo, but I've never seen it labeled as a 49lb, only basing the 47lb off of the OP. It is def the same turbo as the SC46, I confirmed that with scoobyclinic this morning.
That's just what I've always heard it referred too. Never received clarification on the issue. But the power levels are similar to the 2.5
Old 04-21-2011, 11:43 AM   #482
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Do you have any idea why ScoobyClinic is able to offer someone to purchase their SC46 without sending them your VF36/37, while if you contact Blouch you have to send them a VF36/37?
Just from reading the ScoobyClinic Billet Thread they say that they have their own housings and you can pay an extra fee of like $200 and you don't have to ship them your turbo...just seems weird that Blouch can't offer the same thing...
Old 04-21-2011, 12:58 PM   #483
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
My thoughts are that scoobyclinic bought up a bunch of old/broken vf37's or somehow got housings for cheap. They leave them with Blouch who holds the housings for them exclusively. I spoke with Kev from Scoobyclinic and he assured me that they developed the SC46 with Blouch and if I send my VF37 to Blouch it will be the same turbo.
If you look at Scoobyclinics site you will see the SC36 and SC40 are now available in twin scroll but without the need for a new housing. These must be the 18g and 20g Blouch twin scrolls. You will then see that the SC46 in twin scroll still requires the VF37 housing, BUT they can supply the VF37 housing for an additional $250 (150 british pounds).
Old 04-21-2011, 01:09 PM   #484
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Man I wish I had a VF37 just sitting around. There is no way I am going to subject my VF36 to having an SC46 created
Old 04-21-2011, 03:03 PM   #485
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I've seen them floating around for $500, prolly less if it's beat up.
Old 04-21-2011, 03:32 PM   #486
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Can you say what Blouch quoted you for the SC46?
Old 04-21-2011, 03:56 PM   #487
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I don't see why not. $1600 which requires me sending my VF37 in. P&P was like $180, thermal coating $150 (I think). Not cheap, but very few options out there.
Old 04-21-2011, 04:07 PM   #488
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Thats the same price as the 2.5XTR without P&P and Ceramic Coating. Thats not that bad considering, now if Blouch just had some extra Exhaust housings...
Well I am defintely really interested to see what you can get out of this setup yourself. Will you be running E85 by chance on this?
Old 04-21-2011, 04:32 PM   #489
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Yep E85 with a TMIC and other mods I'll list when done.
Old 04-21-2011, 09:47 PM   #490
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
That is going to be an awesome setup. What's even better is you have an EJ207 and we are finally going to see what a real upgraded stock location Twin Scroll will do on one here in the States.
Can't wait for your results
Old 04-22-2011, 03:59 PM   #491
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
In for those results as well. I was 20 minutes from purchasing a full rotated single scroll PERRIN kit before I came across this thread.
-Ver. 8 Ej207
-Functioning AVCS
-Light bolt ons
-Stock equip manifold/VF37/DP
blakjak00 is offline   Reply With Quote
Old 04-22-2011, 06:09 PM   #492
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Just started a new thread to compare the different twin scroll options. I'm having a tough time deciding.
http://forums.nasioc.com/forums/show...1#post33930491
Old 12-20-2011, 03:51 PM   #493
Tock
Member#: 292779
2011 STI
White is the new black
Sorry to bring up an old thread, but has there been any developments on this? There's nothing on blouch's site regarding subaru TS turbos in any form. Am I correct in assuming that I could order a TS 20G XT-R from them today, without having to supply a P25 turbine?
There is this now though, http://www.tomiokaracing.com/index.p...or-subaru.html. Almost certainly a journal bearing unit, but I wonder if blouch could modify that with a BB CHRA and possibly a 3" inlet compressor. All the kit parts are available serperately as well.
Tock is offline   Reply With Quote
Old 12-20-2011, 04:53 PM   #494
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
Personally, I would order that kit without the turbo. I'm running that turbo right now and it's a dog. The Blouch counterpart would have have made 40 more whp on the same dyno on the same day as mine. Check out the stock location twinscroll option thread, a bunch of us have compiled the choices there with results. Can't link to it on my phone, sorry
Edit: I'm not speculating on the Blouch unit's performance, my tuner has tuned 3 Tomiokaracing turbos and probably 30 Blouch 20G's in the last two months. He is confident that my car, unchanged except for turbo manufacturer, would have made 20% more power
Old 01-19-2012, 08:49 PM   #495
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Hey guys -
I'm bumping this back from the dead as I have some updates on things.
Car is still running fine, yet eats oil. Motor is still bone stock and now has almost 108,000 miles on it.
I have always felt bad that I never really got to put this thing through it's true paces due to the age of the motor.
Over the next few months that is going to change as I will FINALLY be refreshing it.*
Current plans are:
ej257
forged pistons
+2 mm rod setup
stock crank
cams
valve springs
TGV deletes
850cc injectors
We will be putting it together with this same JDM TS header, up, and down.
Turbo will stay the same but I may shoot it over to Blouch for a refresh while the car is down.
I MIGHT do some mild port work on the heads. MIGHT. It depends on time.
*Those of you who think owning a shop means you'll have a totally kick ass car and have all the time in the world to work on it will find that you would be very sorely disappointed. There is no time during the day to work on your own stuff, and IF you are lucky enough to make it back in at night or on the weekend chances are you're going to get there, and do something like "I'll just take a few minutes to answer emails" or "I should really get this done on this customer's car quick so we can get it back to him early." Next thing you know you're wife is calling asking where you are, and you haven't even touched your own car yet.
Old 01-19-2012, 08:57 PM   #496
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
Busy with the top scoob track car
Old 01-19-2012, 09:07 PM   #497
Turn in Concepts
Member#: 93646
Many Track Records
Even that one has been put on the back burner lately as we're still working through supporting changes to the main changes coming up.
Cryptic? Yes. Absolutely.
Old 01-20-2012, 11:19 AM   #498
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
Originally Posted by Turn in Concepts View Post
Hey guys -
Thanks for updating the thread. This is a setup I've got some interest in. I'm sure it's back in the thread someplace, but which turbo do you have again? Is it the 18g-XTR-TS? That's the one I've got the most interest in.
What is the best (IYO) first step on the heads? Port the dog-leg?
My primary interest in TS turbo is not spool, but rather removing the weak link #4 piston problems. It's been said elsewhere that the JDM TS cars have the per-cylinder compensation zeroed out, and that the TS header (and maybe TGV-less intake) are the reason. I don't recall whether it was the injector trim, spark trim or both which was zeroed.
Also, the JDM header looks like the best option by far. It doesn't crack and has the best set of heat shields available. The fact that Crawford uses it on Block's 500hp drift car tells me it won't be any kind of limiting factor in a ~350hp street car.
At any rate your car looks like a great test bed, so I'm waiting in anticipation. Thanks for sharing!
gpshumway is offline   Reply With Quote
Old 01-20-2012, 11:32 AM   #499
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Hey check out the Stock Location Twin Scroll Thread A lot of information in there for you.
Also Turn In Concepts has the Blouch 2.5XTR Twin Scroll, but it's really a 1.5XTR as the trims are 49lb/min Compressor with a 56.5mm Turbine Wheel.
Old 01-20-2012, 12:14 PM   #500
Schister66
Member#: 271648
2015 STi
Billet, ball-bearing and twin-scroll....the marketing trifecta of words people dont understand.
Buzzwords ftw (if only it had a Gamma-Ti turbine )
Schister66 is offline   Reply With Quote
APS twin scroll rotated turbo kit TSR-70 who would buy it or not? 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 237 02-07-2010 12:16 PM
my new gp moto twin scroll rotated turbo! 06redsuby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 02-15-2008 12:30 AM
Twin Scroll BB Info needed . discopotato03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-10-2007 11:41 AM
New APS twin-scroll BB rotated turbo FOR USDM STI's!!! keaniegenie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 191 01-10-2007 01:12 PM
Will the new STI use a twin-scroll IHI turbo? bsix STi Forum Archive 0 01-09-2003 01:54 PM
