Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 02-17-2010, 12:06 AM   #1
taosracer
Member#: 131108
2002 TS/WRX wagon
Blue ridge pearl
Default STI steering rack on bug-eye wagon ?
I guess my search skills suck, because I'm sure the answer to this is here somewhere.....
I've been putting off replacing my leaking steering rack for long enough now. Just wondering if anyone has put an STI PS rack on a wagon. Seems like there's no reason it shouldn't work, but has anyone actually done it ? Any tricks to fitment ?
My thinking is that if I'm going to have to replace it anyway, I might as well go with the quicker ratio rack, since the wagon is getting back to seeing track time again this year
Thanks for the responses
taosracer is offline   Reply With Quote
Old 02-17-2010, 01:19 AM   #2
subaru3169
Member#: 55252
* pullup bar *
i believe the only sti rack that can be put on is from an 04
subaru3169 is offline   Reply With Quote
Old 02-17-2010, 01:29 AM   #3
relliMmoT
Member#: 206931
2004 WRX Wagon
6MT JBP 318WHP//300WTQ
If it helps, I know Saab 9-2x have STi steering racks and theyre all wagon. Yes I realize you have a bugeye and they started making Saabarus in like 04' or something.. But hey its an STi rack in a wagon so thats a step.
You and I both know it can be done. Yes, it can be done. Any swap can be done in these cars, what youll have to mod to do it is up in the air. Ive pulled off what has been thought to be the impossible swap multiple times by the forum by simply grinding down this and that or using this bolt and thicker bearing sleeve in this and that or whatnot the other thing.
relliMmoT is offline   Reply With Quote
Old 02-17-2010, 06:31 AM   #4
boostinmx5
Member#: 158937
02 vf30 wrx 6speed
the only rack that can easily be swapped in is an 04, to put an 05 in you would need to swap in the cross member as well, as the mounting points are different. i just did this in my bugeye with my swap
boostinmx5 is offline   Reply With Quote
Old 02-17-2010, 12:41 PM   #5
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
I recently installed an 07 STi steering rack and crossmember into my bugeye wagon. It was pretty straightforward, just very time consuming since so much has to be disconnected (struts, control arms, cross member, rack, engine raised,etc.)
the only thing that didn't really line up were the lines. The hard lines coming off the rack are bent at a wee bit different angle. I had to carefully bend them a bit by hand to get them to line up with the lines/couplings coming off the PS pump/reservoir.
just take your time and have a buddy with you for help positioning stuff and a second opinion.
Its worth it, feels great and its much cheaper than a q-rack. Though I'd love to have one of those.
Arnie is offline   Reply With Quote
Old 02-17-2010, 08:41 PM   #6
taosracer
Member#: 131108
2002 TS/WRX wagon
Blue ridge pearl
Thanks for the responses. I'm looking at a re-manufactured '04 STI rack, sounds pretty straight forward. I've been rebuilding an FX16 GTS and can't wait to start working on my Suby again. So much easier !!
Old 02-17-2010, 10:50 PM   #7
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Going the 04 sti route is certainly easier but the 05+ racks are a bit faster and the rack is more securely mounted. Whichever way you go make sure you install Whiteline heavy duty steering rack bushings while you're in there.
Old 02-18-2010, 05:42 AM   #8
relliMmoT
Member#: 206931
2004 WRX Wagon
do they really make that much a difference? i dont see to much talk about them. desribe your experience will ya?
-tom
Old 02-18-2010, 05:51 AM   #9
subaru3169
Member#: 55252
* pullup bar *
-tom
the whiteline bushing won't slide like the oem does while turning the wheel
Old 02-18-2010, 05:53 AM   #10
subaru3169
Member#: 55252
* pullup bar *
i thought all stis had the same ratio
personally, i'd choose the 04 to drop in.. sooooo much easier.. that is, if i can find one lol
Old 02-18-2010, 05:59 AM   #11
relliMmoT
Member#: 206931
2004 WRX Wagon
hmm.. never realized it was sliding. whats the change in feeling?? im trying to set it up for this seasons autox, everythings torn apart right now so i may do this mod while im in there... if this makes a big change in steering thats a pretty important thing to mod then yeah?
Old 02-18-2010, 07:26 AM   #12
subaru3169
Member#: 55252
* pullup bar *
basically gives a better response while turning instead of the sloshiness.. i'm not sure how else to say it.. but ya, definitely worth swapping out the bushings=)
Old 02-18-2010, 02:00 PM   #13
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
I believe the 05+ went a wee bit quicker than the 04. I think standard 05+ WRX with new rack has same ratio as 04 STi. Could be mistaken.
The heavy duty steering rack bushings make a subtle but noticeable improvement in steering feel and response. Especially with the older style racks. Lots os squidge with the soft stock bushings. The newer racks can benefit from them as well. its a cheap upgrade for 35 bucks or so. Worth doing and a no brainer, IMHO.
Old 02-18-2010, 03:44 PM   #14
relliMmoT
Member#: 206931
2004 WRX Wagon
aside i hear the drivers side one is a complete bitch, but those may have been noob posts... who knows.
Old 02-18-2010, 03:54 PM   #15
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
driver's side on the 02-04 can be a pain. sometimes i've been able to get it on in 30sec, sometimes 30 min! but its super easy with the rack out of the car.
Old 02-18-2010, 03:56 PM   #16
RES_22
Member#: 162318
2003 WRX 'OLS'
(On Life Support)
I've done this on a couple of cars.
The 05+ rack + the new front x-member is the way to go.
As Arnie said, the 05+ rack is a bit quicker AND it is located
far more rigidly in the x-member than the 04 rack.
And the WL bushings make a noticeable difference in feel -
especially on the track.
Good luck,
Rob
RES_22 is offline   Reply With Quote
Old 02-18-2010, 06:20 PM   #17
taosracer
Member#: 131108
2002 TS/WRX wagon
Blue ridge pearl
I probably won't go as far as doing the crossmember and '05 rack. The '04 is easy to find anyway. I will definitely do the bushings, because the OEMs are like mush. You might as well just jam a styrofoam coffee cup in there !!
I may see how the car feels with the original rack converted to manual, just for fun and it's shot anyway. I did my '95 L like this http://www.flyinmiata.com/tech/depower.php?x=1 and enjoyed it. I think the wagon is a little too heavy, but we'll see. Eliminating that power steering pulley must be worth at least 3.5-4 HP
Old 02-19-2010, 02:59 PM   #18
password:ej20
Member#: 178729
1999 ver6 sti
rally blue
Swapped an 04 sti rack on my bugeye with the whiteline bushings
it's easy I'f u get a 04 sti rack
actually took me 2 hrs to do the swap!!!
Easiest if you remove the inner tie rods off the rack with the inner tie rod removal tool
then drop the rack
it's a pain if u have the inner tie rods hanging on the side
great upgrade tho
my steering is soo much responsive and it has a quicker turn ratio
well worth the hassle!
password:ej20 is online now   Reply With Quote
Old 02-19-2010, 04:55 PM   #19
sti337
Member#: 199032
04 UMS Tuned sti
Turns out it's Black!
I have a spare 04 sti rack in great condition and I have a couple of extra new boots laying around that I can throw in too. Are you interested????
I Installed a RevLabs quick rack, It might be my fav. mod ever!!! the car is awesome to drive now... I just watch who I let drive it now, it's a bit more sensitive ;-)
sti337 is offline   Reply With Quote
Old 02-19-2010, 05:52 PM   #20
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
i agree, i drove a 2.0 turns L2L car at an autox. First time in it driving in anger and I don't know how many times I almost spun over correcting and over steering! But I loved the steering. Unfortunately, don't have the $$$ for that rack.
04 STi Steering Rack on 04 WRX wagon? STi Canada Brakes, Steering & Suspension 0 01-29-2009 02:31 PM
Prodrive lip on bug eye wagon? GC8drifter86 Interior & Exterior Modification 9 01-17-2006 11:14 PM
How to swap 2004 STi steering rack into 2002 WRX wagon colby Subaru Conversions 2 12-27-2004 10:39 AM
Impreza STI steering rack on legacy? czo79 Legacy Forum 5 07-07-2003 05:51 PM
STI steering rack ... fit "03 WRX Wagon? makofoto STi Forum Archive 9 05-27-2003 12:10 PM
