Old 02-17-2010, 04:48 AM   #1
WhiteRu
Member#: 186763
2004 Expedition
Default Help with divorceing apV1
I have a 2004 wrx, and Everytime I try to revert back to stock it says, error check cable low voltage or something of that sort.
How do I go about fixing this? Im trading the car in here soon, and I would rather sell the AP to someone on Nosiac or something..
the cable looks good and seems to have a good connection. I connected those two green test plugs or whatever they are. Still no luck...
Please help!
WhiteRu is offline   Reply With Quote
Old 02-17-2010, 11:55 AM   #2
Member#: 238659
Make sure that the Initialization Connectors are plugged in, that will send the proper voltage to the ECU which will allow to flash the vehicle. Also try hooking up a battery charger.
Cheers
Dan@COBB Tuning is offline   Reply With Quote
Old 02-17-2010, 02:11 PM   #3
WhiteRu
Member#: 186763
2004 Expedition
the two green connectors in the manual they are called test connectors?
Old 02-18-2010, 08:28 PM   #4
WhiteRu
Member#: 186763
2004 Expedition
help please....
Old 02-18-2010, 09:31 PM   #5
2w0r0x4
Member#: 56759
2004 WRX
WR Blue
You should also have another white jumper connector that came with the AP This needs to be connected to the matching whitish factory connector under the dash. (should be right next to the green ones you already plugged in)
2w0r0x4 is offline   Reply With Quote
Old 02-18-2010, 09:39 PM   #6
2w0r0x4
Member#: 56759
2004 WRX
WR Blue
If you can't find that connector you can buy it here...
http://www.cobbtuning.com/products/?id=3307
Old 02-19-2010, 03:45 AM   #7
WhiteRu
Member#: 186763
2004 Expedition
okay. I think I have that. I'll try again today thanks guys!!
Need help with VAGCOM, "Not trying to flash, just log" realitycheck3907 Open Source Reflashes 7 06-05-2010 09:12 PM
Columbus, OH: Need help with TMIC install.. taketurns Mid West Subaru Owners Club Forum -- MWSOC 0 06-04-2010 05:15 PM
need help with a/c compressor replacement sen7inel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-04-2010 08:53 AM
EvoScan/StiScan with Cobb APv1 cable SSLegacyGT Open Source Reflashes 16 08-21-2009 06:53 PM
Help! Need Cobb APV1 power adaptor spec! ImpreziveWRX Southern California Impreza Club Forum -- SCIC 5 03-12-2009 11:54 PM
