Old 02-18-2010, 08:08 AM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default 655 Hp Package Bmw M3 From Manhart
What Paul Rosche was for BMW in formula 1 in the 1980s, that’s what Günter Manhart is for the BMW tuning scene now, namely the undisputed motor pope. For decades he developed the BMW power trains for many renowned tuners, but remained completely incognito. But that has come to an end because for a few months now, Manhart is storming the tuning charts with sensational compressor and V10 reconstructions and even successfully competed in the high speed circuit at Nardo, Italy, with his M3 E91 Touring with V10 motor (an absolute unique).
3x compressor power!
For the current M3 generation Manhart offers a 3 stage power package, which strengthens the eight cylinder high speed motor to up to 655 HP. Of course with the standard 420 HP you are not exactly under-motorised, but a car fan can never have too much power. The first power stage starts with a small compressor and a supercharging pressure of 0.35 bar, which gives you 515 HP. In stage II the supercharging pressure is increased to 0.50 bar, whereby 585 HP is straining on the rear axle. In the third and largest build-up stage a large compressor from ASA with a supercharging pressure of 0.67 bar is combined with a specially developed exhaust system with 70 millimeter pipe diameter and two 200 cell race catalytic convertors – and the whole thing is made from TITANIUM. With this, a full 655 HP are at the start which catapult the Bavarian power athlete from 0 to 100km/h in just 3.7 seconds. The top speed is just over 350km/h.
Classic BBS wheels!
However, power alone is not everything, because so much power wants to and must be converted into propulsion. In order to do this without too much loss, Manhart Racing used a Bilstein PSS10 threaded suspension into the vehicle shown here, on the end of which turn classic BBS challenge rims in black. With 9Jx20 ET20 with 245/30ZR20 at the front and 10.5Jx20 ET20 with 295/25ZR20 continental tyres at t he rear they ensure grandiose grip at all times. In order that this power can be kept perfectly in check, 365mm brake discs are used on the front axle with floating callipers from the BMW M5 E60 and the braking system from the M3 E92 with 345mm discs are used on the rear axle.
BMW Performance!
The interior is a nice mix of sportiness and luxurious ambience, thanks to full leather fittings in Alcantara/leather combination, the wonderful performance seats with seat heating and an exclusive performance steering wheel with LED display which shows temperature, transverse acceleration and ¼ mile times. And of course there is a real switch guide plate with six channels to be inserted manually, which is how racing drivers like it.
Power for X6 M and X5 M & high end exhaust technology
Also new to Manhart Racing are increased performances for the new offroad steam hammers X6 M and X5 M. Manhart Racing endows their 4.4 litre V8 with BI turbo supercharging optionally with 600 HP (€5,900), 650 HP (€9,900) or even 700 HP (€14,900). A stainless steel exhaust from the turbocharger with 90mm pipe diameter as well as square or round, 86 or 90mm diameter end pipes are obligatory for all three power stages, at the price of €4,900.
For the M3 E92 Manhart Racing also has high quality exhaust technology at hand. The in-house exhaust system from the heaers has a constant diameter of 70mm and ends with four 82mm end pieces. In the “stainless steel” version (€2,490) it produces extra power of around 18 HP and a booming sound. Even more luxurious: the “TITANIUM” version which not only generates 25 additional HP but also has a weight advantage of 50% compared to the standard technology.
Technical data
Vehicle type: BMW M3 E92
Motor: 4 litre V8 with ASA compressor, 655 HP
Exhaust: 70mm titanium complete system from header incl. modified catalytic convertors (2×200 cells)
Empty weight: 1,550kg
Body: carbon mirror, carbon roof
Undercarriage: Bilstein PSS10 threaded suspension
Wheels/tyres: BBS Challenge R Black rims, front in 9Jx20 ET20 with 245/30ZR20, rear in 10.5Jx20 ET20 with 295/25ZR20
Brakes: front BMW M5 E60-365mm discs with floating calliper, rear BMW M3 345mm discs with floating calliper.
Interior:
performance seats with seat heating, performance steering wheel with digital display, full leather fittings with Alcantara/leather combination, carbon hand brake grip.
Source: Manhart
Old 02-18-2010, 09:29 AM   #2
Chiketkd
Member#: 71634
In hibernation...
I'd rock it!
If only I had the money...
Chiketkd is offline   Reply With Quote
Old 02-18-2010, 10:30 AM   #3
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Is it just me or does the intake look tacky?
Not-EWRX is offline   Reply With Quote
Old 02-18-2010, 10:37 AM   #4
themarxist
Member#: 104555
1996 VW Passat Wagon
TDi White
Not just you, the plenum is pretty crappy looking. Mostly it just needs a flat or wrinkle finish I think, the gloss doesn't work well when it's not very smooth. Make no mistake, I would still rock the living **** out of that.
themarxist is offline   Reply With Quote
Old 02-18-2010, 10:50 AM   #5
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Sick.
Old 02-18-2010, 11:43 AM   #6
sasquatch95
Member#: 17163
2006 Legacy
Non-GT white
those are the most awesome seats ever. I'm sure they cost more than what my car is worth.
sasquatch95 is offline   Reply With Quote
Old 02-18-2010, 01:19 PM   #7
Iegav05
Member#: 231526
2005 LGT AVO380
2011 E90 M3 ZCP
Not much boost.
Iegav05 is offline   Reply With Quote
Old 02-18-2010, 01:29 PM   #8
Masterauto
Member#: 198376
STI E30 M3
Nissan GT-R 15
The GT-R traps better and a much lower cost. Would be an interesting race around the ring.
Masterauto is offline   Reply With Quote
Old 02-18-2010, 01:49 PM   #9
Chiketkd
Member#: 71634
In hibernation...
FWIW, if I had the money to buy that M3, I wouldn't care about whether the GT-R was faster or not. Heck, I'd buy them both along with a Porsche Cayenne Turbo S as my daily driver!
Old 02-18-2010, 06:46 PM   #10
hondahata
Member#: 64905
2004 WRX/STi
Rally Blue
For me and my money, give me a used E46 (S54) and one of these....
http://www.horsepowerfreaks.com/part...s/E46_M3/11037
Also, I would have to refer to my BMW aficionados, but can this really be done with so little PSI,12.0 compression, and stock internals? Is the E92 that bad ass??
hondahata is offline   Reply With Quote
Old 02-18-2010, 08:53 PM   #11
Obsessive
Member#: 77302
damn well better
bail me out of this ****
Is it just me or does the whole ****ing thing look tacky?
Fixed.
And, yes.
Obsessive is offline   Reply With Quote
Old 02-18-2010, 11:12 PM   #12
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
can stock engine hold that much of power reliably?
Old 02-18-2010, 11:15 PM   #13
4wdwrx
Member#: 72042
2002 V7 Impreza
"Blue Mammoth" Returns
Not everyone want to buy a GTR and no one drives around the Nurburgring all the time.
4wdwrx is offline   Reply With Quote
Old 02-18-2010, 11:56 PM   #14
skywaffles
Member#: 82470
I am more humble
than you can understand.
One would think they could come up with a better finish than rattle can black for that intake manifold.
skywaffles is offline   Reply With Quote
Old 02-19-2010, 12:18 AM   #15
Dragicon
Member#: 112323
those CH-R's are just about the best rims ever.... if they made them in 18's I would own a set.
Dragicon is offline   Reply With Quote
Old 02-19-2010, 12:56 AM   #16
doylfish
Member#: 88099
2004 Audi S4
2003 Suzuki SV1000S
the exhaust alone is like $3500 USD, but i bet it sounds great
doylfish is offline   Reply With Quote
Old 02-19-2010, 01:28 AM   #17
Sticky2
Member#: 238835
Yes, the E92 M3 is that badass and I would rather have this than a GTR (well, I do ) :
130 mph trap speed, roughly ~700 hp stock internals 12.0:1 compression with water meth, custom headers, 3 inch exhaust (getting dynojet numbers this weekend) :
Video:
More details: http://bimmerboost.com/showthread.ph...rd-Fastest-E9X
BTW: The supercharger posted in this thread is re-branded G-power, they have blown 5 motors, stay away.
Sticky2 is offline   Reply With Quote
Old 02-19-2010, 01:31 AM   #18
Sticky2
Member#: 238835
A twin turbo V6 with more hp better trap better, not at lower cost though.
However, you boost a motor as efficient as the M3's... you get some real magic. Just takes $
Old 02-19-2010, 02:06 AM   #19
E. Nick
Member#: 8489
1978 Plymouth Volare
Maroon / White Vinyl
Sticky - your car sounds awesome! I read about some ESS cars blowing up as well... I guess it's all in the tuning.
E. Nick is offline   Reply With Quote
Old 02-19-2010, 02:32 AM   #20
Sticky2
Member#: 238835
Thank you!
Absolutely, at that compression on 91 octane and with a car not designed for boost, all about tuning.
Where did you read about ESS blowing motors btw?
Old 02-19-2010, 08:05 AM   #21
E. Nick
Member#: 8489
Originally Posted by Sticky2 View Post
Thank you!
Saw it on M5Board
Old 02-19-2010, 06:42 PM   #22
nhat
Member#: 140163
03 STi
hellaflunctional
sticky2 your car sounds amazing. got some serious bark to it. and the throttle response is ridiculous.
that's all.
Old 02-19-2010, 06:46 PM   #23
Badler
Member#: 133597
:jackoff.gif:
Badler is online now   Reply With Quote
Old 02-19-2010, 08:29 PM   #24
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
That black M3 looks nice minus taillights.
Old 02-19-2010, 09:01 PM   #25
Sticky2
Member#: 238835
Nah, tailights give it that extra aggression and make the white portion stand out in greater contrast. At least that is the way I feel
Possible 2011 BMW M3 Competition Package - Spied AVANTI R5 Non-Subaru News & Rumors 20 10-26-2009 11:13 PM
Manhart Racing’s BMW M3 E92 5.0 V10 SMG hits 208 mph AVANTI R5 Non-Subaru News & Rumors 28 09-16-2009 03:54 PM
BMW Sibling Shootout- Stock E92 BMW M3 vs Dinan Performance 335i teamjordan23 Non-Subaru News & Rumors 8 06-02-2008 01:29 PM
Comparison Test: 2002 BMW M3 vs. 2008 BMW 135i vs. 2008 BMW 335i AVANTI R5 Non-Subaru News & Rumors 26 04-29-2008 11:50 PM
Next year, expect a faster, more expensive BMW M3 (Concept @ Geneva?) from Autoweek NYCshopper Non-Subaru News & Rumors 33 02-04-2007 10:17 PM
