Old 02-18-2010, 08:16 PM   #1
brian30tw
Member#: 171900
2006 STI
Steel Grey Metallic
Default Benchmark Tuning + Grimmspeed on VF-39
Event: Dyno Tune
Ambient Temp: 40 degrees
Tires: Stock
Car: 2006 STi
Tuner: Matt of Benchmark Tuning
Dyno Info: Dyno Tune on Mustang Dyno
Peak HP at RPM: 255 whp @ 5100 RPM
Peak Torque at RPM: 328 wtq @ 3400 RPM
Baseline hp/tq for a stock on same dyno: SAME CAR WITH EVERYTHING STOCK!!
-212 WHP - 6800RPM
-207 WTQ - 3900RPM
Target Boost: 21 PSI Peak - 14.5 PSI Redline
Target AFR: 11.1
Fuel: 93 Octane
Engine/Power Modifications:
-Invidia catless TBE
-Grimmspeed PnP Exhaust Manifold w/ high-flow cross section
-Grimmspeed Up-pipe
-Grimmspeed EBCS
-Grimmspeed TGV Deletes
-Grimmspeed Ported Intake Manifold
-Grimmspeed Ported VF39
-SPT intake
-AP Hard Inlet
-WitchHuneter 800cc Modified Injectors
-Walbro 255
Driveline Modifications: Stock
Suspension Modifications: Stock
Other Modifications: Stock
Here is a blurry cell-phone pic of the dyno chart. Completely stock vs. all mods above:
I am very happy with the extra 120 foot-pounds!
brian30tw is offline   Reply With Quote
Old 02-18-2010, 08:17 PM   #2
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
awesome! now go external wastegate!
grimmspeed is good stuff
All4bSpinnin is offline   Reply With Quote
Old 02-18-2010, 11:00 PM   #3
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
so you have ALL those mods and only made 43whp more?....i know its a mustange but that that still sounds weak.
Paul is online now   Reply With Quote
Old 02-19-2010, 12:02 AM   #4
pooster.online
Member#: 120461
2004 WRX STi JBP
hit around 260 on a unmodified mustang with tbe and tune. truly a heartbreaker.
pooster.online is offline   Reply With Quote
Old 02-19-2010, 04:09 AM   #5
'05Limited
Member#: 102236
2006 Legacy Spec B
355whp/360wtq
Amen - but doing the drivetrain loss from 300/300 to baseline numbers, using the same percentage with the new numbers yields ~361/475 at the crank - pretty damn impressive for a ~35 lb/min turbo.
'05Limited is offline   Reply With Quote
Old 02-20-2010, 08:20 PM   #6
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
the car made great tq with the set-up, but it is his daily so we didnt want to go too aggressive.
Benchmark Tuning is offline   Reply With Quote
Dyno'd: Garage Tuning tuned 2.5L vf-39 91+Meth - 348awhp/419awtq @21psi STidub Proven Power Bragging 20 01-04-2010 08:49 PM
Question on Tuning WRX w/ VF-39 Sp00L AccessPort 7 01-23-2008 07:42 PM
20G Compressor Upgrade on VF-39 matix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 09-12-2007 08:44 PM
VF-34 on VF-39 map jamesg602 AccessPort 6 12-16-2006 08:06 PM
