Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 02-18-2010, 09:06 PM   #1
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
Default EJ22 Still misfires badly
So I replaced my plugs twice, got new NGK blue wires, new MAF, new coilpack yet my engine still misfires badly to the point it stalls quickly!
I'm out of ideas, can anyone help me?
Zac86 is offline   Reply With Quote
Old 02-18-2010, 09:11 PM   #2
GrundleJuice
Member#: 165749
ahh, the shotgun approach. Shoot parts at it and see if they fix it.
I would take it somewhere and tell them not to call you until they figure it out
Old 02-18-2010, 09:21 PM   #3
Zac86
Member#: 136919
ABP
I dont have money for that and the nearest dealer is 4hours away
Old 02-19-2010, 12:10 AM   #4
afviper
Member#: 89493
2001 330ci
Is the check engine light on? If it is go to Autozone and have the codes pulled.
When you checked the spark plugs were any of them black and oily?
I had a misfire that turned out to be a burnt valve, a big chunk was missing out of the valve and the cylinder had no compression at all. Easy way to check for a burnt valve is to put a piece of paper up to the exhaust pipe. If the paper flutters like the exhaust pipe is trying to suck it in you have a burnt valve.
afviper is offline   Reply With Quote
Old 02-19-2010, 12:30 AM   #5
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
MMM more info is needed.
When did the problem start? Did it ever run right? How many miles?
sooooo many questions.
DHRDAN is offline   Reply With Quote
Old 02-19-2010, 01:24 AM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
injectors? we need more info.
Old 02-19-2010, 06:49 AM   #7
Zac86
Member#: 136919
ABP
it just started happening, my car used to run perfect.
Old 02-19-2010, 06:20 PM   #8
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
typically issues that have a sudden onset are electrical related. Is the alternator putting out enough juice? is the battery ok? does this happen when warmed up? cold?
have you checked all the grounds?
Old 02-19-2010, 07:49 PM   #9
Zac86
Member#: 136919
ABP
yes charging system is running fine.
Which grounds should I be looking at specifically?
Old 02-19-2010, 08:43 PM   #10
subi400
Member#: 216984
1996 Impreza outback
Green
Have you checked the O2 sensors on the both of the cats? Maybe one of them or both of them are bad? I have heard that if just one of these are bad it can cause this type of problem or at least be part of the problem. So I would have those checked if you haven't already
subi400 is offline   Reply With Quote
Old 02-19-2010, 09:26 PM   #11
Zac86
Member#: 136919
ABP
I will be replacing my O2 Sensor tomorow with a brand new OEM one.
ok there are a few things that are confusing me.
My new wires are all 4K ohms resistance where as subaru spec calls for 6-12K, is this bad?
Also for my plugs are the proper ones BKR6E or BKR6E-11?
Old 02-19-2010, 10:17 PM   #12
afviper
Member#: 89493
2001 330ci
I'll ask again. Any check engine lights? Have you had them read? You should probably stop replacing parts semi randomly, thats a good way of wasting money.
Why do you think it has a misfire? What are the symptoms?
Old 02-20-2010, 12:38 AM   #13
Zac86
Member#: 136919
ABP
no check engine lights.
why does it misfire? if I knew I would have fixed it....
symptoms? its misfires? lol
Old 02-20-2010, 03:54 PM   #14
Zac86
Member#: 136919
ABP
Theres a white solenoid by my intake manifold thats humming really loud, what is that and could it be causing problems?
Old 02-21-2010, 10:37 AM   #15
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
unplug it and see if it does anything. Also, your PCV looks pretty dirty, you might consider cleaning/changing that.
Old 02-21-2010, 04:11 PM   #16
Zac86
Member#: 136919
ABP
ok so I took out my PCV valve and it was completely gummed up, tried shaking it and I couldnt hear anything so I guess its toast.
Also the vaccum line that goes from the PCV valve onto some black pplastic thing that then goes into the rear of the block, should I try and take that off and clean it out too?
Old 02-21-2010, 04:20 PM   #17
hella_sti
Member#: 139289
2003 WRX Wagon
check your crank position sensor and the cam position sensor, sounds like an issue I had when I brought my car to subaru and they forgot to plug the cas back in.
hella_sti is offline   Reply With Quote
Old 02-21-2010, 04:47 PM   #18
Zac86
Member#: 136919
ABP
I just took off the conectors and cleaned them, should I try and take the actual sensors out as well?
Old 02-21-2010, 05:15 PM   #19
Zac86
Member#: 136919
ABP
just did a compression test, all cylinders are around 175psi, is that normal?
Old 02-22-2010, 02:20 PM   #20
afviper
Member#: 89493
2001 330ci
That sounds fine. Its more important that the cylinders all have similar compression (within 5-10%) than the actual PSI number. You can search around but I know that things like cold or hot engine, and open or closed throttle affect the number.
Have you checked the fuel system yet? Pump, filter, injectors. I don't know the actual checkout procedures, but I am sure someone else does.
Old 02-22-2010, 09:16 PM   #21
Zac86
Member#: 136919
ABP
my MAF was a used one from a forester.
so I threw in new plugs and it ran ok for like 5min, I even drove it around the block and did a couple of WOT pulls in 2nd gear. Parked it back and it started sputtering and died, started it again and it died, started again and still it died. so I started it once more and kept the revs up but it was misfiring like crazy.
Pulled out the plug for cyl #1 and heres what it looks like.
Also saw a little coolant here, my coolant resevoir hasnt gone down and its nowhere near the headgasket so i'm guessing its not causing any problems?
Old 02-23-2010, 11:10 AM   #22
clydesdale
Member#: 239219
My brother in law is having a similar problem on a 2003 legacy with a 4 cyl. When he pulled the spark plugs they had oil on them. He changed them and the car ran much better, but it is now back to running like junk again and he says now it won't start.
clydesdale is offline   Reply With Quote
Old 02-23-2010, 07:52 PM   #23
Zac86
Member#: 136919
ABP
pretty much same symptom as me
Old 02-24-2010, 06:57 PM   #24
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
get that coolant leak fixed. looks like it's from the crossover pipe(or throttle body).
Is that oil on the spark plug? It's hard to tell. If so, there are only a couple of places to come from. Rings, head gasket, valve seals. Since you have good compression, that rules out rings and head gasket. Which leaves valve seals.
I'm stumped on just one cylinder causing the whole engine to not want to idle. Whatever happened with that white solenoid?
Old 02-24-2010, 09:49 PM   #25
Zac86
Member#: 136919
ABP
pulled all the plugs and they all looked teh same.
That white solenoid was the IAC motor and its working fine.
I'm about to scrap this car cause I really cannot find whats wrong
Still Misfiring on all cylinders?! crazycanasian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-16-2009 04:33 AM
cylinder 3 and 4 still misfire joshua olean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-24-2008 08:24 AM
Cobb STG 2 Misfire, bad plugs (pics) mvitic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-16-2006 10:05 PM
help, still misfiring **merged threads** snowmachine Normally Aspirated Powertrain 15 08-25-2005 07:21 PM
Still misfiring...HELP! Mr. Bungle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 08-05-2005 01:01 PM
