Welcome to the North American Subaru Impreza Owners Club Tuesday September 2, 2014
Old 02-19-2010, 03:18 AM   #1
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Default Alcoolaid's New 2010 Build
2009 Build Details: http://forums.nasioc.com/forums/show....php?t=1749917
Last motor was basically a built bottom end with a turbo kit and stock heads running on the stock ecu and using a Cobb APV2 for engine management. Got it tuned by Dominic @ Maxwell Power and made 511whp/444wtq with 28psi boost on 94 octane and 70/30 meth/water injection.
Ever since the tune I've always wanted to run a standalone ecu just to have better drivability since the MAF was so big it wasn't that great for daily driving. Also, a lot of people kept bugging me to build the heads since obviously this was hindering my top end power.
So, after picking up a Vi-Pec V88 standalone ECU and purchasing some built heads from a close friend, I decided it was time to quickly pull the motor out again before the track season season starts in March.
Ever since my tune in October I've put about 5,000 hard miles on the car and everything is still great!
Heads are currently at Maxwell Power getting cleaned up so once I get those back I'll assemble the motor back up and wait for my new clutch disk to arrive before I drop it back in. Then it's back down to Maxwell to let Dom work his magic Can't wait to see the top-end gains @ the same boost level. Also it should be fun playing with the anti-lag
Engine specifications:
EJ257 703 Casting
CP Pistons 99.75mm w/ Ceramic Crown and Molybdenum Disulfide Skirt Coating
Carrillo Forged H-Beam Rods
Engine Fully Balanced
Stock STI Crank – Lightened a little bit
Calico Coated ACL Race Bearings
OEM Head Gaskets
ARP Head studs
11mm Oil Pump w/2 shims
B25 Heads
Kelford 276/272 AVCS Cams
5-Angle Intake Valve Job
3-Angle & Radiused Exhaust Valve Job
Supertech +1mm IN/EX Valves
Valves Lapped
Supertech Dual Valve Springs
Titanium Retainers
Other stuff:
Gates Racing Timing Belt
TGV Port and Delete
Ported Intake Manifold
BW S300sx 83-75 0.91AR
Custom TS-T4 header/up-pipe
Dual Tial 38mm MV-S WG’s
Mocal 25 Row Oil Cooler
Mocal Sandwich Adapter w/ Thermostat
MAC 3 Port Boost Solenoid
AEM/Zeitronix 3.5Bar MAP Sensor
APS DR725 FMIC with Custom Upper Pipes
GrimmSpeed 8mm Phenolic Spacers
Walbro 255LPH Fuel Pump Intank
Bosch 044 External Fuel Pump
Canton Racing 8 micron Fuel Filter
Covert Performance Fuel Surge tank
-8AN Feed and -6AN Return Fuel Lines
Injector Dynamics Bosch 1000cc Injectors
Aeromotive Top Feed Fuel Rails
Aeromotive A1000-6 FPR
Aquamist HFS-5 Meth Injection System 2x 1.0mm nozzles
Spec C STI 12L Intercooler Spray Tank
Vi-Pec V88 Standalone ECU
ACT Xtreme 6 Puck Sprung Clutch
ACPT Carbon Fiber Driveshaft
alcoolaid is offline   Reply With Quote
Old 02-19-2010, 03:23 AM   #2
alcoolaid
Member#: 134949
'07 SWP STi
Some pictures of the motor pull and ECU wiring :S
Old 02-19-2010, 07:26 AM   #3
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
That harness pic gave me a headache!
It will be cool to see the gains from the headwork.
CKxx is offline   Reply With Quote
Old 02-19-2010, 08:30 AM   #4
GHK
Member#: 103886
2005 WRX
Hope you have a great success on this project!
GHK is offline   Reply With Quote
Old 02-19-2010, 11:12 AM   #5
alcoolaid
Member#: 134949
'07 SWP STi
Me too. I'm going to have to have the dyno plots put together on the same sheet. Hope my power doesn't shift too far to the right....
Old 02-19-2010, 11:24 AM   #6
modaddict
Member#: 95840
sold to a good bud
awaiting next car
holy turbo.
I love it.
modaddict is offline   Reply With Quote
Old 02-19-2010, 04:11 PM   #7
dmross
Member#: 2818
2000 2.5RS
Awesome! Good luck with the ViPEC!
Are those dual-avcs heads that you picked up?
dmross is offline   Reply With Quote
Old 02-19-2010, 04:37 PM   #8
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
Wow looks fun... Your only changing the heads, correct?
rexworx is offline   Reply With Quote
Old 02-19-2010, 05:29 PM   #9
alcoolaid
Member#: 134949
'07 SWP STi
I'm sending you a pm right now regarding the ecu!
And nope, intake AVCS only.
Yup, heads only. New clutch disk too
Old 02-19-2010, 06:17 PM   #10
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
I saw you at MPS on saturday while I was working on my car. I am interested to see the gains from your built heads.
Good Luck
hustleshark206 is offline   Reply With Quote
Old 02-19-2010, 07:06 PM   #11
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Why is the firewall all black?
Have you had any exhaust leaks any where?
"Supertech Dual Valve Springs" you going for 9k rpm?
Bariga is offline   Reply With Quote
Old 02-24-2010, 12:11 AM   #12
alcoolaid
Member#: 134949
'07 SWP STi
Good Luck
When is your car done? I see it's still there.
The turbo -> dp v-band was leaking and was too lazy to fix it for a while so it got black. All is good now
Probably going to have soft cut at 8000 and hard-cut at 8200.
Old 02-24-2010, 12:11 AM   #13
alcoolaid
Member#: 134949
'07 SWP STi
Some photos for you guys. Swapped the heads. Got it all timed up. Just have to take the flywheel off, get it resurfaced, change the rear main seal, put the oil pan back on, put the turbo stuff on, intake manifold stuff and wiring harness then put the motor back in.
Also finally got the Vi-Pec working... 2 wires were mis-labeled on their wiring diagram so the DBW throttle plate wouldn't calibrate properly...
Old 02-24-2010, 10:45 AM   #14
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Nice job as usual. I know it may be too late now but did you refresh the engine bearings while you had the motor out? 5000 miles at your power level is hard on the bearings so I was wondering if you inspected them?
mick_the_ginge is offline   Reply With Quote
Old 02-24-2010, 12:50 PM   #15
alcoolaid
Member#: 134949
'07 SWP STi
I was kind of lazy and don't have much free time left once the Olympics are over so I didn't feel like splitting the case.
I'm sure they should be fine but just wore as usual.... oh well!
Old 02-26-2010, 07:58 AM   #16
alcoolaid
Member#: 134949
'07 SWP STi
Video > pictures.
A friend of mine did a quick time-lapse of me dropping the motor in a few days ago.
Here it is!
Old 02-26-2010, 08:41 AM   #17
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
cool vid,thats awesome to watch.
good luck with the rest of the build
jsnm is offline   Reply With Quote
Old 02-26-2010, 10:45 AM   #18
MartinSTi05
Member#: 145145
2006 wrx STi
Good vid, Good work, Oontz Oontz...
MartinSTi05 is offline   Reply With Quote
Old 02-26-2010, 07:28 PM   #19
suberdave
Member#: 101865
88 GL-10 STi
i run a ViPEC ECU. you will love it... easy to tune, and awesome for daily driving...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 02-26-2010, 08:47 PM   #20
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
hey I just noticed looking at your pics of the empty engine bay---what the hell is all over the paasenger side firewall? is your exhaust leaking at the v-band or was there a fire back there on the track?
john 1badSTI is offline   Reply With Quote
Old 02-26-2010, 09:07 PM   #21
sense of nature
Member#: 112759
?? pending....
sale....
Maybe no dump tube for the waste gates ?
sense of nature is offline   Reply With Quote
Old 02-26-2010, 09:25 PM   #22
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
no with the motor hanging on the engine hoist you can see the dump tubes on the wg's.I was just wondering if v-bands on dp's usually leak or not.
Old 02-26-2010, 09:35 PM   #23
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Did you guys read the thread?
morrocco88 is offline   Reply With Quote
Old 02-26-2010, 09:36 PM   #24
Wintershredder
Member#: 160089
2004 STi,330xi,328xi
WRB, Black, White
Read the damn thread... its all there
Wintershredder is offline   Reply With Quote
Old 02-26-2010, 09:55 PM   #25
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
hey hey hey guys my bad I missed it----no reason to get all jumpy about missing a little info.I read the thread cause I respect the work that dom does.
Alcoolaid's Build thread alcoolaid Vancouver Impreza Club Forum -- VIC 467 10-14-2013 03:03 PM
SP00L's 2006 Impreza WRX. 2010 Build/Update Thread!! Sp00L Member's Car Gallery 169 05-31-2012 08:31 PM
Register for the 2010 Build The Track! Motorsports Show! June 19th, 2010! ArchangelX Hawaii Impreza Club Forum -- HIIC 4 07-09-2010 07:47 PM
New Member, New 2010 WRX, First Subaru hieu1004 Newbies & FAQs 11 03-14-2010 10:51 PM
Porsche unveils new 2010 GT3RS AKA I need a new pair of pants PitwrkzZ1 Off-Topic 64 08-19-2009 12:34 PM
