Vancouver Impreza Club
Old 02-19-2010, 03:28 AM   #1
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Default Alcoolaid's Build thread
Member car gallery thread that is more up to date: http://forums.nasioc.com/forums/show....php?t=2190223
Updated: Jan 7, 2015: New head gaskets arrived for 2015 engine refresh!
2007 Satin White Pearl Subaru Impreza WRX STI
587WHP/513WTQ @ 26psi
Quickest ET: 11.24 @ 127mph (On 18" rims + 265/35/18 street tires) - Only made one pass at time (no roll bar)
Home Built by Me
Tuned by John Reed
My YouTube Channel for Videos! http://www.youtube.com/alcoolaid
Instagram: http://instagram.com/arthurlam89
How she looks like:
2014:
2013:
2012
2011
2010
2009
Mod List:
Engine:
JE 925SD Custom Forged Pistons 101.6mm w/coated crowns and anodized ring lands
Nascar piston rings
MPS Super H-Beam +2mm Long Rods
Factory STI 79mm Crankshaft
Dan Benson Racing Darton Sleeved Block
Engine Fully Blueprinted and Balanced
ACL Race Rod and Main Bearings
Kelford 276/272 AVCS Cams
JE Proseal Head Gaskets
NGK BKR7EIX Spark Plugs
5-Angle Intake Valve Job
3-Angle & Radiused Exhaust Valve Job
Ferrea +1mm SS Intake Valves
Ferrea +1mm Super Alloy Exhaust Valves
Supertech Dual Valve Springs
Supertech Titanium Retainers
ARP Custom Age 625+ Head Studs
ARP Case Bolts
STI 10mm Oil Pump
OEM STI Timing Belt
Gates Racing Alternator/PS Belt
Mocal 915 Oil Cooler -10AN Fittings
Mocal Sandwich Adapter w/ Thermostat
Koyo R2704 53mm Racing Radiator
Custom Twin-Scroll Header and T4 Up-pipe
Custom 3.5" Catless Downpipe
Borgwarner S300sx 83-75 .91AR T4 TS Turbo
Dual Tial 38mm V-band Wastegates w/ external dump tubes
MAC 3-Port Boost Solenoid
OMNI Power 4 Bar MAP Sensor
Custom 4" Aluminum Intake w/ Green filter
Boost Logic Turbo Blanket
Fujitsubo Titanium Exhaust
APS DR725 FMIC with Custom Pipes
Tial Q BOV
TGV Port and Delete
Ported Intake Manifold
Ported Throttle Body
Rotated Intake Manifold
Crawford Performance V2 Air/Oil Separator
GrimmSpeed 8mm Phenolic Spacers
KS Tech 1/2" Throttle Body Spacer
Walbro 255LPH Fuel Pump Intank
Dual Bosch 044 External Fuel Pumps
Canton Racing 1 micron Fuel Filter
AI Industries 2.6L Race Fuel Surge Tank
Goodridge 825 PTFE -8AN Feed and -6AN Return Fuel Lines
Injector Dynamics 1300cc Fuel Injectors
Aeromotive Top Feed Fuel Rails
Aeromotive A1000-6 Fuel Pressure Regulator
GM Flex Fuel Sensor
Vi-Pec V88 Standalone ECU with Anti-Lag and Launch Control
Odyssey PC680 Battery
Drivetrain:
ACT XT-SS Clutch
STI Group N 6spd Short Shifter
STI Group-N Tranny Mount
STI Group-N Engine Mounts
STI Group-N Pitch Stop Mount
ACPT Carbon Fiber Driveshaft
Street: Volk TE37SL 18x10.5 +22 Special Color Diamond Black Hankook Ventus Evo v12 295/30/18
Track: Rota DPT 18x10 +35 Yokohama A005 280/650/18
ARP Extended Wheel Studs
Muteki Extended Open End Black Lug Nuts
Stoptech ST60 Trophy Big Brake Kit
Street: Stoptech Street Performance Brake Pads F+R
Track: PFC08 Front Brake Pads, PFC01 Rear Brake Pads
Centric Premium Rear Rotors
Motul RBF600 Brake Fluid
Quantum Motorsports Brake Ducts
RPW 3" Ducting Hose
Suspension:
RCE Tarmac 2 Coilovers
Hyperco Springs 600/500lb
Corner Balanced
Whiteline Anti-lift Kit
Whiteline Rollcenter Kit
Whiteline Max-C Motorsport Camber/Caster Plates
GTWorx Rear Camber Plates
SPC Front and Rear Camber Bolts
STI S204 Carbon Fiber Front Strut
Cusco Carbon Fiber Rear Strut Bar
Kartboy Rear Diff Outrigger Bushings (Black)
Kartboy Rear Subframe Bolts
Turn in Concepts Rear Diff Mount Bushings - RACE
Turn in Concepts Lateral Link Bushings
Turn in Concepts Forward Trailing Arm Bushings
Turn in Concepts Rear Trailing Arm Bushings
RaceQuip Tow Hook Loop Strap
Interior:
Compustar Pro 2W9000FM-AS
Defi Amber BF Boost, Oil Pressure, EGT
Innovate MTX-L Wideband
Subtle Solutions Ashtray Gauge Bezel
Gruppe-S CF Triple Gauge Pod
STI Titanium Shift Knob
STI Limited Hazard Button
Pioneer AVH-4300DVD
Stripped Interior
Sound Deadening and Heat Shields Removed
Airbag System Removed
Valentine 1 Radar Detector
Beatrush Rear Firewall Division Plate
Recaro Profi SPG Seats
Buddy Club Seat Rails
Amerex 2.5lb Fire Extinguisher x 2
Autopower 4pt Race Rollbar
G-Force Camlock SFI 6pt Harnesses
Works Bell Short Hub
NRG 2.5 Carbon Fiber Quick Release
Nardi Deep Corn 350mm Leather Wheel w/ Red Stitching
Exterior:
STI Limited Front Lip
STI Badging Removed
Headlight Blackouts
40% Front Tint
20% Rear Tint
LED License Plate/Daytime Running Lights
Seibon Carbon Fiber Trunk painted White
Rolled/Pulled/Cut Fenders
04-05 STI Rear Tail Lights
WRX Side Skirts
KS Tech Hood Scoop Block Off Plate
LIC Motorsport Dry Carbon Fender Flares
Custom 6mm splitter with 100mm extension
Kognition Design 71" Chassis Mount Wing
alcoolaid is offline   Reply With Quote
Old 02-19-2010, 03:29 AM   #2
alcoolaid
Member#: 134949
'07 SWP STi
Some pictures of the motor pull and ECU wiring :S
45 mins in
3 hours in
8 hours in
done
Old 02-19-2010, 03:52 AM   #3
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
BALLER ALERT!!!!!!!!!!!!!!!!!!!!!
alvinli217 is offline   Reply With Quote
Old 02-19-2010, 04:05 AM   #4
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Wow you need to get some quick release bolts for making it faster to re & re ... How long does it take you now!
Baller I don't think so I think of a Baller that just goes out and pays for people to do the best with the most expensive parts. Arthur buys the best parts possible at a good rate then installs everything himself.
I would say he is an extreme car hobbyist that know his **** and built(ing) a monster.
When you talk to DOMinic next tell him I say Hi! ;-)
dasnowman is offline   Reply With Quote
Old 02-19-2010, 04:10 AM   #5
alcoolaid
Member#: 134949
'07 SWP STi
Quick release bolts... like QR20 front axles for bikes?
I actually have it down pretty quick now. From popping the hood to having the motor on the engine stand it's about 3.5 hours?
Yeah, I've probably saved thousands of dollars by doing everything myself. When I first started off I was like most people... how to do an oil change, how to change brake pads, bleed brakes, exhaust, intake, etc... Then you slowly start to build confidence, take chances and learn to do things by yourself. You have to have the time too I guess... and not a lot of people have time.
Old 02-19-2010, 04:24 AM   #6
neokasu
Member#: 158521
2007 Impreza 2.5i
Black - sold
you are effin crazy man too bad i didn't get a chance at feeling the 511hp. Remember to take me for a ride when your done this one!
neokasu is offline   Reply With Quote
Old 02-19-2010, 04:49 AM   #7
fujiwara_yingyu
Member#: 116351
2009 CFRP GR WRB STI
2006 EVO IX MR
I am glad to sit your ride for a test drive.
fujiwara_yingyu is offline   Reply With Quote
Old 02-19-2010, 08:20 AM   #8
Forged Performance
Member#: 227509
2015 Subaru STi
Galaxy Blue
I like where this is going...
Forged Performance is offline   Reply With Quote
Old 02-19-2010, 09:27 AM   #9
slowguy
Member#: 4326
you're a nut job man.
slowguy is offline   Reply With Quote
Old 02-19-2010, 11:17 AM   #10
alcoolaid
Member#: 134949
'07 SWP STi
Hey, someone has to keep up with those stage 2+ R35's
Old 02-19-2010, 11:30 AM   #11
slowguy
Member#: 4326
LOL. I'll just bring some nails, we'll be OK.
Old 02-19-2010, 11:35 AM   #12
alcoolaid
Member#: 134949
'07 SWP STi
HAHA. Are you going to spray some paint on them so we can dodge them? You know the stuff where you can only see it with those special glasses?
Old 02-19-2010, 11:46 AM   #13
slowguy
Member#: 4326
haha. that reminds of me light that shows semen on the walls. *ahem*
anyhow, you're gonna need a qrack as your next mod....
Old 02-19-2010, 11:47 AM   #14
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
your track season starts real early dude.. haha..
KIMUTAKU is offline   Reply With Quote
Old 02-19-2010, 12:09 PM   #15
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
nicely done Arthur.
No wonder you don't have time to bike anymore.
steve is offline   Reply With Quote
Old 02-19-2010, 12:38 PM   #16
tryallzee
Member#: 179947
1994 LS400
crazy ...
tryallzee is offline   Reply With Quote
Old 02-19-2010, 12:41 PM   #17
Scooby-King
Member#: 180499
2007 SRT8-Cherokee
2008 Sierra Denali
Pretty sure its the bed not the walls . . . . but if thats what your into
Scooby-King is offline   Reply With Quote
Old 02-19-2010, 01:02 PM   #18
slowguy
Member#: 4326
i'm glad that's the only thing you picked up from this thread.
Old 02-19-2010, 01:36 PM   #19
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
lol it's called painting the walls spiderman style
That reminds me anyone see the episode of of 2 1/2 man when they take the black light into charley Sheens bedroom and it's all over the roof and walls... He's like ya I remember that night I hit the fan!
Old 02-19-2010, 03:26 PM   #20
alcoolaid
Member#: 134949
'07 SWP STi
What? First PR track day is like March 17. Open lapping day on the 27th too I think.
Originally Posted by steve View Post
nicely done Arthur.
I do bike... sometimes
Old 02-19-2010, 04:32 PM   #21
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
haha yea proformance actually has a lapping day next sat.. i'm just saying march is still kinda early and cold for a lot of folks out there..
mine will kick off in may hopefully..
Old 02-19-2010, 04:33 PM   #22
slowguy
Member#: 4326
See you sucka's out there!
Old 02-19-2010, 07:30 PM   #23
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
That turbo is seriously huge
Maybe bring the car out to AutoX on a rainy day again?
minifreak is offline   Reply With Quote
Old 02-19-2010, 07:44 PM   #24
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
ur cars gonna go up in flames soon by the look of that firewall lol.
RX Renesis is offline   Reply With Quote
Old 02-20-2010, 01:44 AM   #25
Scooby-King
Member#: 180499
2007 SRT8-Cherokee
2008 Sierra Denali
looks like the 2nd tial is venting w/o a dump tube but rather directly into the firewall
My very slow build thread 05BluePearlGT South West Impreza Club Forum -- SWIC 17 08-14-2007 04:41 PM
Jutboy's EJ22(T) Build Thread Jutboy Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-07-2007 07:52 PM
A check-my-PC-build thread, with extra cookies. gongzero Off-Topic 13 01-29-2007 12:23 PM
Wh'appen to Tai Chih left the building thread? blaster88 Mid Atlantic Impreza Club -- MAIC 12 11-09-2001 04:26 PM
