Welcome to the North American Subaru Impreza Owners Club Saturday September 5, 2015
Vancouver Impreza Club
Old 03-20-2013, 06:45 PM   #401
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Originally Posted by blackhawk07 View Post
got any videos of you on a track??
also whats your reliability like with all that power?? been looking at going to an evo for motor reliability but, then i suppose if its built properly i shouldnt have problems..
Yes. www.youtube.com/alcoolaid
Reliability? High HP and reliability don't really go together with Subaru's haha. Well it can if you do the right maintenance. But high power will definitely need good cooling, built heads, and a sleeved block for sure.
alcoolaid is offline   Reply With Quote
Old 03-20-2013, 06:45 PM   #402
alcoolaid
Member#: 134949
'07 SWP STi
Not Subaru related but a truck I bought was delivered to my house today.
2001 F350 SD 7.3 Powerstroke Diesel
Has a 6.5" lift and 37" BFGoodrich 37" A/T's on it right now. 4" exhaust, etc.
Needs some work right now. Oil cooler o-rings, rear diff pinion seal, new glow plug relay and glow plugs, etc. Maybe new injector o-rings.
Transmission was completely rebuilt just a year ago. Needs some body work too but I got it really cheap
Old 03-20-2013, 07:38 PM   #403
Drakar
Member#: 68402
Koolaid went redneck or is the sti going full trailer queen and this is the tow vehicle?
Drakar is offline   Reply With Quote
Old 03-20-2013, 09:32 PM   #404
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
I've heard different things about the diesel injectors and how much of a pain they are to work with. If its an injector you need to replace all of them because of the high pressure or something. Will try and find the info I was reading up on...
Glow plugs aren't too hard, but I think the harness is buried deep if it needs to e replaced. relay should be relatively easy to swap
Sweet truck tho! Don't even need to jack it up to work under it!
rs420 is offline   Reply With Quote
Old 03-21-2013, 04:31 AM   #405
alcoolaid
Member#: 134949
'07 SWP STi
Only time will tell
Yup, oil fired injectors. Runs at like 3000 psi oil pressure. The o-rings wear out on the injectors over time so you get reduced oil pressure at the injector = less fuel = run rough / bad.
Glow plugs are easy. Valve cover comes off, 10mm 1/4" deep socket and it's done. Harness inside might need to be changed but we'll see. Previous owner didn't stress it out a lot so not a lot of heat.
Yeah it's so tall I'm 6ft tall and barely see the engine standing. I need a chair to stand on then stand on the front bumper to work on it. Basically twice as tall as the subie haha
Not to mention doing an oil change on this thing takes over 4 gallons! 16 ish quarts.
8 gallons of coolant too. jesus.
Old 03-21-2013, 10:17 AM   #406
blackhawk07
Member#: 246919
2007 WRX STI
haha thats why i figured id ask, cuz the track bug has infected me badly and eventually will do a build bigger than stage 2 lol...i know high hp in any car esp subarus throw reliability out the window, but relatively how track reliable is your build, as in you not like other subarus i know that going 1-2 events on a motor.
blackhawk07 is offline   Reply With Quote
Old 03-21-2013, 04:03 PM   #407
FIDS
Member#: 185128
2005 Stage 2 STI
Only time will tell
After investing a bunch of cash in our Ford, you don't have to do all injectors at once unless you plan to up the injectors to like 80hp+. Then you will need to do them all. PDR is my diesel shop and you can test \ buzz then once they are out. If they aren't gone yet, do what I do and order a product called Hot Shots stiction eliminator. It goes in the oil and helps to clean injectors.
FIDS is offline   Reply With Quote
Old 03-22-2013, 02:39 AM   #408
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Only time will tell
lol ^^ above is white guy problems! ^^^
Wait till you fill the tanks with fuel!
There is an injector rebuilder/flow tester in Richmond can't remember the name but they do flow testing before and after, o rings, new filter baskets etc for 4 was a bout 100-120.
dasnowman is offline   Reply With Quote
Old 03-25-2013, 03:06 PM   #409
alcoolaid
Member#: 134949
'07 SWP STi
I had a friend with a scanner do a buzz test for me. Injectors are good. I did a coolant flush as well. Looked ugly.
What oil are you running? I bought a 5 gallon pail of rotella 15w40 from Canadian tire this weekend for $57 on sale from $80. Might go back to buy some more for future use since an oil change is like 4 gallons haha.
Are you using a tuner as well? Looking at a dp tuner f6 because that's what everyone likes to use.
Also where are you getting oil filters? Ford dealer? Everyone says use oem motorcraft filter.
Old 03-26-2013, 12:24 AM   #410
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Holy Sheet that's a big truck! I like the colour, it will match your car.
2010 WRX Limited is offline   Reply With Quote
Old 03-29-2013, 05:41 PM   #411
alcoolaid
Member#: 134949
'07 SWP STi
Haha ya it's pretty big. Drove Subaru yesterday for the first time in a while and it felt like I was in a go kart compared to the truck haha.
Old 03-29-2013, 06:10 PM   #412
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
since i cant drive ur subie can i play with ur truck?
ps when u gonna have a redneck tow off? ur subie vs ur truck? lol
RX Renesis is offline   Reply With Quote
Old 03-29-2013, 10:40 PM   #413
alcoolaid
Member#: 134949
'07 SWP STi
Haha truck would rip the car apart. Has like 700wtq haha
Old 03-30-2013, 12:37 AM   #414
FIDS
Member#: 185128
2005 Stage 2 STI
I use the Castrol 15 40w from Costco. As for a tuner I'm using an SCT because that is the one programmer that will tell my 6.0L that the EGR had been deleted.
Old 04-28-2013, 05:25 AM   #415
rwNbear
Member#: 210406
Seen you on granville st a few hrs ago!
Didn't think I'd see this car while visiting Vancouver. Looks amazing!!
rwNbear is offline   Reply With Quote
Old 04-28-2013, 10:33 AM   #416
KootenayWRX
Member#: 119134
04 Fxt
02 wrxwgn
The 7.3l are great engines, International made them.
KootenayWRX is offline   Reply With Quote
Old 05-02-2013, 08:14 PM   #417
alcoolaid
Member#: 134949
'07 SWP STi
Thanks! Where were you visiting from?
Yes. They are very good.
Old 05-02-2013, 08:14 PM   #418
alcoolaid
Member#: 134949
'07 SWP STi
Small photo shoot we had yesterday. Just all the car friends I grew up with. Some of them are selling their rides so we decided to get everyone together one last time.
Old 05-03-2013, 11:17 AM   #419
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
That's a great picture. Is that Barry's M3 way at the back?
Old 05-03-2013, 11:34 AM   #420
alcoolaid
Member#: 134949
'07 SWP STi
Ya it is
Old 05-03-2013, 01:25 PM   #421
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
looks like an STI spoiler on that blue BMW middle left
danny_d19 is offline   Reply With Quote
Old 05-03-2013, 07:15 PM   #422
alcoolaid
Member#: 134949
'07 SWP STi
Haha looks kinda like it from that angle.
It's actually an ltw spoiler
Old 05-07-2013, 07:23 PM   #423
alcoolaid
Member#: 134949
'07 SWP STi
More boost buggies!
Old 05-07-2013, 07:36 PM   #424
clou
Member#: 271562
2016 370z
PW
Is that Brendan's ix with the Weds?
clou is offline   Reply With Quote
Old 05-07-2013, 08:06 PM   #425
alcoolaid
Member#: 134949
'07 SWP STi
Yes it is
My very slow build thread 05BluePearlGT South West Impreza Club Forum -- SWIC 17 08-14-2007 04:41 PM
Jutboy's EJ22(T) Build Thread Jutboy Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-07-2007 07:52 PM
A check-my-PC-build thread, with extra cookies. gongzero Off-Topic 13 01-29-2007 12:23 PM
Wh'appen to Tai Chih left the building thread? blaster88 Mid Atlantic Impreza Club -- MAIC 12 11-09-2001 04:26 PM
