Vancouver Impreza Club
Old 05-02-2011, 03:46 AM   #151
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
you can get dba 5000's for $619 shipped from a vendor on nasioc. the ones from girodisc are just a tiny bit more.
alcoolaid is offline   Reply With Quote
Old 05-11-2011, 03:25 AM   #152
alcoolaid
Member#: 134949
'07 SWP STi
Finally got more bushings done. Changed all the lateral link bushings and trailing arm bushings to the TiC bushings. What a huge difference omg! Time to get an alignment @ Dales along with more goodies up front.
Rear diff mount:
Old 05-11-2011, 09:34 PM   #153
ValleyRallySTi
Member#: 212561
Nice. We're all in the same boat... its crazy. We should have ganged up on the brake companies for a discount. Alcoolaid, have you ever thought of running Solosprint? There is a Lan-evo being built for Solosprint right now (racing greed) also a tube frame VW rabbit with a Quattro swap that should be stupid fast. Not sure what kind of bar you had built but you would need a 2.25 x .120 roll bar if I remember right.
I'm thinking of getting the Performance Friction 2 piece rotors. It's kind of a toss up with the other 2 brands you guys mention. I would prefer to get something like AP 6 pot / 2 pce up front and AP 4 pot / 2 pce rear, but I'm not saving up for that setup and need rotors last season so replacement 2pce it is.
Good luck boys, see ya out there.
ValleyRallySTi is offline   Reply With Quote
Old 05-12-2011, 03:27 AM   #154
alcoolaid
Member#: 134949
'07 SWP STi
Old 05-12-2011, 08:48 PM   #155
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Do you also run brake cooling ducts?
minifreak is offline   Reply With Quote
Old 05-13-2011, 02:26 AM   #156
alcoolaid
Member#: 134949
'07 SWP STi
^Nope. But I plan to later on.
Old 05-30-2011, 02:46 AM   #157
alcoolaid
Member#: 134949
'07 SWP STi
Finally got to put in some more goodies I picked up from Jason @ Dales Alignment.
Whiteline vs. Stock
Passenger side
Tool of champs
Driver side
Old 05-30-2011, 06:03 AM   #158
HRCboy
Member#: 167075
08 STI & 999R
Nice work Aurthur!
HRCboy is offline   Reply With Quote
Old 05-31-2011, 07:52 PM   #159
alcoolaid
Member#: 134949
'07 SWP STi
Put the track wheels on and doing some suspension tweaks to get make sure the inboard clearance is good between the strut and tire.
Hellaflush on the track yo
Old 06-01-2011, 12:54 AM   #160
(98)RSti
Member#: 266726
1998 RS Coupe
black
omg ur rears dont rub??? are the fenders rolled?
(98)RSti is offline   Reply With Quote
Old 06-01-2011, 02:14 AM   #161
alcoolaid
Member#: 134949
'07 SWP STi
rear fenders are pulled and cut
they rub every now and then if i'm turning super hard and i go over a bump at the same time. but i'd say they don't rub. about 2" bump travel before it will hit inside the fender
Old 03-09-2012, 12:48 AM   #162
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
bump.
007WRX is offline   Reply With Quote
Old 03-09-2012, 01:26 AM   #163
alcoolaid
Member#: 134949
'07 SWP STi
Might work on car tomorrow, i'll put some pics up
Old 03-09-2012, 01:34 AM   #164
alcoolaid
Member#: 134949
'07 SWP STi
Re-loomed some wire a few days ago
Changed the intake air temp sensor (faulty readings)
Got tires removed from track wheels at The Speed Syndicate
... and saw this beast there. new paint job ftw!
Old 03-09-2012, 11:17 AM   #165
ShiftGear
Member#: 130493
1999 v5 STi
Wow! What color is that? Blue-ish dark gun metal? Beautiful STi dude!
ShiftGear is offline   Reply With Quote
Old 03-09-2012, 02:46 PM   #166
alcoolaid
Member#: 134949
'07 SWP STi
It's a grey color from Lamborghini
Old 03-09-2012, 11:14 PM   #167
i_eat_r1ce
Member#: 303366
1998 Impreza 2.5 rs
the fender flares look so nice!
i_eat_r1ce is offline   Reply With Quote
Old 03-10-2012, 04:14 AM   #168
alcoolaid
Member#: 134949
'07 SWP STi
Removed the factory oil cooler today... what a freggin' pain in the ass. Got coolant all over my arms and body when I was trying to connect the new patch hose.
7ft of -10an earls performa-flex line courtesy of anplumbing.com and of course the key subaru part to make it all happen... the NA impreza oil union.
Got a blister on my hand doing the first one of the night
Ditching the original -10an aeroquip socketless hose
Removing stock oil cooler/warmer
Another hose done.. got the second blister on the other hand now... lol
And all done finally.... you can see all the coolant evaporating haha
Old 03-11-2012, 09:58 PM   #169
alcoolaid
Member#: 134949
'07 SWP STi
Trying out the new zeitronix fluid temp sensor
Don't forget the teflon tape!
Done!
Reacts pretty quickly and it's accurate.
Engine bay as of now:
Old 03-11-2012, 10:36 PM   #170
Awais
Member#: 295663
2004 V7 STI swap WRX
looks dank!
Awais is offline   Reply With Quote
Old 03-22-2012, 08:53 PM   #171
alcoolaid
Member#: 134949
'07 SWP STi
Got some new rubber today for my new wheels. $170/each from discount tire direct. Beat everyone out there for 255/35/18 Hankook v12 evo's
Missing some hood scoop nuts... has this happened to anyone before?
Fixed! M5x0.8 nut
And finally new hood scoop block off plate courtesy of Matt @ KSTech.
Old 03-22-2012, 08:55 PM   #172
alcoolaid
Member#: 134949
'07 SWP STi
Going to build my splitter soon. Just need to wait for the cheap mig welder I ordered to arrive so I can weld up an aluminum frame for it and tack on some stainless steel mounts to my chassis. Probably will have adjustable height in the front and back so I can change the pitch of it.
Old 03-26-2012, 10:53 PM   #173
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
The splitter is a killer project, downforce FTW.
2010 WRX Limited is offline   Reply With Quote
Old 03-26-2012, 11:13 PM   #174
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Would you reuse the factory underbody panel mount at all?
I have the v12 Evo as well. Pretty good street tires but the review is not very good for track etc.
Old 03-27-2012, 12:07 AM   #175
alcoolaid
Member#: 134949
'07 SWP STi
Nope. Going to be welding 2 support brackets up front and 2 in the rear. Should be strong enough to have 2 people standing on it and can have it on and off independent of the bumper in about 2 mins once the car is jacked up.
I'll probably work on it the next few days
My very slow build thread 05BluePearlGT South West Impreza Club Forum -- SWIC 17 08-14-2007 04:41 PM
Jutboy's EJ22(T) Build Thread Jutboy Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-07-2007 07:52 PM
A check-my-PC-build thread, with extra cookies. gongzero Off-Topic 13 01-29-2007 12:23 PM
Wh'appen to Tai Chih left the building thread? blaster88 Mid Atlantic Impreza Club -- MAIC 12 11-09-2001 04:26 PM
