Old 02-19-2010, 02:16 PM   #1
desmo750
Member#: 111256
1992 Legacy Turbo
don't call me white...
Default 92 Legacy turbo intercooler problems
Ok, I have a 92 legacy ss (ej22t). I have a td05 16g turbo, manual boost controller, fuel cut defender, and it had an 02 wrx tmic which worked great except for the fact that it was smashed in there and didn't fit well. Never had a problem with the car when it was installed. I decided to buy a new 06 wrx intercooler since they fit so much better. Had problems with what I figured to be a boost leak somewhere yesterday and got it resolved and the thing ran great. Drove it home 30 miles ran like a speed demon. This morning I'm on my way to work and it's doing the same thing: boosts up to about 5 lbs then falls on it's face, almost dies, then runs ok after a second if I don't give it too much throttle. Get to work, double check everything, give all hose clamps a double tightening, am dumb founded, go drive it runs great. On the way back, same thing. I cannot find a boost leak but there must be one since it's running like this . Anyone run into this problem? Like I said, when I had the 02 intercooler I never had a problem. Everything with this new one fits tight, hose clamps tightened down, and I cannot find the problem.
desmo750 is offline   Reply With Quote
Old 02-19-2010, 02:45 PM   #2
94EJ22TImpreza
Member#: 237375
2002 Impreza WRX
Blaze yellow
I have the same set up in my 94 Impreza and the same problem.
nothing so far has worked i would love to see some new suggestions.
hope you fix it...Good luck!
94EJ22TImpreza is offline   Reply With Quote
Old 02-19-2010, 04:11 PM   #3
curt
Member#: 165657
fast wagon, toyota
4x4, & a supermoto bike
if you're in snohomish can i take a look at how the 06 wrx intercooler fits on the older motors? im in lake stevens on my days off, in shoreline for school. i'd like to take a look at your setup.
curt is offline   Reply With Quote
Old 02-19-2010, 04:57 PM   #4
desmo750
Member#: 111256
1992 Legacy Turbo
Alright just checked the codes. Ecu has 3:
24: By pass air control valve
31:Throttle postion sensor
22:Knock sensor
Strange that the car always ran fine until I did the intercooler swap then these three codes turn up
Old 02-19-2010, 09:27 PM   #5
klin7757
Member#: 167101
1994 Legacy
clear the codes and see which ones reappear. my guess, knock sensor comes back and a new sensor is in order.
klin7757 is offline   Reply With Quote
Old 02-20-2010, 04:36 AM   #6
94EJ22TImpreza
Member#: 237375
2002 Impreza WRX
Blaze yellow
Sure pm me a day you have off and we can set up a time to meet.
im in Lake Stevens a lot so just about any day would work.
Old 02-20-2010, 04:43 PM   #7
desmo750
Member#: 111256
1992 Legacy Turbo
Cleared codes, they all came back
Old 02-20-2010, 07:41 PM   #8
MikeyMeyagi
Member#: 231209
1994 Legacy Wagon Mi
Matador Red Mica
check the knock sensor wiring, may be shorted
MikeyMeyagi is offline   Reply With Quote
Old 02-20-2010, 08:34 PM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
Thats a lot of codes for just a bad knock sensor. Maybe you broke or left off a ground wire.
Old 02-21-2010, 04:07 PM   #10
desmo750
Member#: 111256
1992 Legacy Turbo
I'll check that tomorrow, anything else I should look for?
Old 02-22-2010, 07:59 AM   #11
ncarn8
Member#: 71419
its not happy that the afm and the iacv arent reporting the same information maybe. I would still be sniffing around for air leaks that may only happen when positive pressure opens them like small gaps in the hoses etc. . At idle doesnt mean squat really. Also remove and clean the iacv, replace the knock sensor and reset the throttle position sensor to where the marks are on it. should be some white paint. after all that it should be better
ncarn8 is offline   Reply With Quote
Old 02-23-2010, 02:20 PM   #12
desmo750
Member#: 111256
1992 Legacy Turbo
Found the problem The wiring in the throttle position sensor plug was exposed in a few places and touching. Looks like someone had tried to repair it before and didn't do a very good job. Insulated them and car runs great! It was right in front of me the whole time but since it happened when I replaced the intercooler I thought I had a major boost leak.
92 legacy hill assist problem. mckenzee Legacy Forum 3 12-20-2006 12:33 PM
93 impreza + 92 legacy turbo = ??? Ru fan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-26-2001 05:19 PM
0-60MPH time on 92 Legacy turbo!! Ben Legacy Forum 1 04-02-2001 07:20 PM
0-60mph time on 92 Legacy turbo!!! Ben Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-02-2001 05:55 PM
G-tech Pro Result on 92 Legacy Turbo!! Ben Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-02-2001 09:31 AM
