Old 02-19-2010, 07:08 PM   #1
Cobb Tuning
Member#: 4803
Default COBB Tuning Surgeline Weekly Tunes! GTRs, WRXs, E85, 2700WHP Oh My!
COBB Tuning Surgeline weekly tunes for 2/13 to 2/19! Feel free to ask any questions or make any comments.
2.5L w/VF52 tuned with AccessPORT
Ambient Temp: 51 F Daily Average
Elevation: Approximately Sea Level
Weather: Indoor
2009 Subaru WRX
Tuner: Tim Bailey
Dyno Info: Mustang AWD-500
Baseline hp/tq for a stock on same dyno: 2010 STi: 239 WTQ, 228 WHP
Engine/Power Modifications:
- COBB Tuning AccessPORT
- SPT Catback
- COBB Tuning Downpipe
- Deatschwerks 1000cc Injectors
- Walbro Fuel Pump
- K&N Typhoon Intake
- Perrin TMIC
Peak HP at RPM: 316 [email protected]
Peak Torque at RPM: 320 [email protected]
Target Boost: 17 PSI
Target AFR: 11.2:1
Fuel: Pump 92 Octane
Peak HP at RPM: 340 [email protected]
Peak Torque at RPM: 365 [email protected]
Target Boost: 18.5 PSI
Target AFR: 7.9:1
Fuel: E85
Old 02-19-2010, 07:09 PM   #2
Cobb Tuning
Member#: 4803
Default 2.5L w/VF52 tuned with AccessPORT
Weather: Indoor
2009 Subaru WRX
Tuner: Tim Bailey
Peak HP at RPM: 280 [email protected]
Peak Torque at RPM:315 [email protected]
Target Boost: 17.5 PSI
Target AFR: 11.3:1
Old 02-19-2010, 07:10 PM   #3
Cobb Tuning
Member#: 4803
Default 2.0L w/TD04 tuned with AccessPORT
Weather: Indoor
2004 Subaru WRX
Tuner: Tim Bailey
Peak HP at RPM: 233 [email protected]
Peak Torque at RPM:236 [email protected]
Target Boost: 16 PSI
Target AFR: 11.5:1
- COBB Tuning Turboback
- Catless Up Pipe
Old 02-19-2010, 07:11 PM   #4
Cobb Tuning
Member#: 4803
Default 3.8L (VR38DETT) w/Stock Turbos tuned with AccessPORT
Weather: Indoor
2010 Nissan GT-R
Tuner: Tim Bailey
Peak HP at RPM: 514 [email protected]
Peak Torque at RPM:544 [email protected]
Target AFR: 11.5:1
- Catless Turboback Exhaust
Old 02-19-2010, 07:14 PM   #5
Cobb Tuning
Member#: 4803
Default 2.0L w/VF22 tuned with AccessPORT
Weather: Indoor
2003 Subaru WRX
Tuner: Tim Bailey
Peak HP at RPM: 275 [email protected]
Peak Torque at RPM:257 [email protected]
Target Boost: 18 PSI
Target AFR: 11.6:1
- VF22
- Upgraded TMIC
- 550cc Pink Injectors
- Walbro Fuel Pump
- AEM Intake
- Greddy EBC
- 3" Catless TBE
- Agency Power Exhaust Manifold & Up Pipe
Old 02-19-2010, 07:15 PM   #6
Cobb Tuning
Member#: 4803
Ambient Temp: 49 F Daily Average
Weather: Indoor
2009 Nissan GT-R
Tuner: Tim Bailey
Peak HP at RPM: 536 [email protected]
Peak Torque at RPM:534 [email protected]
Target Boost: 16.5 PSI
Target AFR: 11.8:1
- Deatschwerks 950cc Injectors
- Dual Walbro Fuel Pumps
Old 02-19-2010, 07:52 PM   #7
Cobb Tuning
Member#: 4803
Weather: Indoor
2009 Nissan GT-R
Tuner: Tim Bailey
Peak HP at RPM: 553 [email protected]
Peak Torque at RPM:552 [email protected]
Target AFR: 11.8:1
- Custom COBB Tuning Surgeline Intakes
- ID 1000cc Fuel Injectors
- Catless Y-Pipe
- Catback Exhaust
Old 02-19-2010, 08:53 PM   #8
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I started to call bull**** on some of those 550 whp tunes with those tiny 950 injectors...... Then I looked up and saw it was a GT-R!
Old 02-20-2010, 12:22 AM   #9
06f250sd
Member#: 217667
2009 WRX
Ok, I have to ask. You dyno'd two 09 wrx; basically the same fuel, boost and AFR's. Why is there only a 5 WTQ difference with the given mods? Obviously the bottom one made more WHP but why not any more torque?
One has 315 WTQ with these mods:
The other made 320 WTQ with these:
SPT Catback
Walbro Pump
K&N Typhoon Intake
Perrin TMIC
06f250sd is offline   Reply With Quote
Old 02-20-2010, 12:47 AM   #10
jpjester
Member#: 153624
2009 WRX Hatchback
Weather: Indoor
2009 Subaru WRX
Tuner: Tim Bailey
- SPT Catback
- Walbro Fuel Pump
- Perrin TMIC
Target AFR: 11.2:1
I am currently in a similiar modification boat and wanted to know if you would recommend that Walbro Fuel Pump vs the AVO 245ltr/h High Flow Fuel Pump?
(I assume he was using the Walbro 255 Fuel Pump? I thought there was some customization needed to use the Walbro 255 in the 2008+ models?)
Would running a more wide open exhaust allow for more tuning room for him to get some more HP out of it? As I have heard from a little bird that the SPT Exhaust is more restrictive?
jpjester is offline   Reply With Quote
Old 02-20-2010, 12:55 AM   #11
jpjester
Member#: 153624
2009 WRX Hatchback
SPT Catback
Walbro Pump
K&N Typhoon Intake
Perrin TMIC
Could it be more aggressive tuning depending on the customers request? Or as so many say ... Every car is Unique, some cars to accept modifications and changes differently?
Old 02-20-2010, 01:41 AM   #12
ej25power
Member#: 14771
02 RS
All Silver!
SPT Catback
Walbro Pump
K&N Typhoon Intake
Perrin TMIC
Check out the graphs laid over each other.
You can see that even though the peak torque is fairly close, the more heavily modified car holds more torque further into the power band.
You can also see that boost pressure doesn't drop off as much.
If you just look at the peak numbers it can be a little deceiving.
ej25power is offline   Reply With Quote
Old 02-20-2010, 11:29 AM   #13
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Tim, why is the torque peak so late on this car?
-- Ed
Weather: Indoor
2009 Subaru WRX
Tuner: Tim Bailey
- SPT Catback
- Walbro Fuel Pump
- Perrin TMIC
Target AFR: 11.2:1
Target AFR: 7.9:1
Fuel: E85
Equilibrium Tuning is offline   Reply With Quote
Old 02-20-2010, 02:31 PM   #14
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
-- Ed
I don't know what Tim's reason will be, however just as a general asside, the 09's peak out (TQ) later then the earlier models partly because of the larger turbo.
Breezio is offline   Reply With Quote
Old 02-20-2010, 02:36 PM   #15
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
They're larger than the previous WRX turbos, but its about the same size as the STI turbos. STI's with stock turbos generally get torque peak before 4k RPM.
Thanks
-- Ed
Old 02-20-2010, 02:47 PM   #16
Breezio
Member#: 234357
2009 WRX
Hmm... I was told the 09's had a larger turbo then the 08's. I was unaware of the size on the earlier wrxs.
My stock 09' peaked out around the same RPMs as the one your asking about. Perhaps there is some other reason, or combination of reasons.
Old 02-20-2010, 02:48 PM   #17
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
I think he meant bigger not smaller.
renosubby is offline   Reply With Quote
Old 02-20-2010, 04:41 PM   #18
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
good catch. That's what I get for posting on my our in to work
-- Ed
Old 02-20-2010, 05:31 PM   #19
modaddict
Member#: 95840
sold to a good bud
awaiting next car
This thread confirms I bought the wrong car.
modaddict is offline   Reply With Quote
Old 02-20-2010, 05:36 PM   #20
Breezio
Member#: 234357
2009 WRX
-- Ed
Now that's funny right there, you read mine wrong, and then I read yours wrong...
Good times.
Old 02-20-2010, 09:14 PM   #21
toyjunkie
Member#: 177315
2004 sti
wrb
^^^^^if you had 75,000 to spend then yes^^^^^^^^^^^^^^^^^
toyjunkie is offline   Reply With Quote
Old 02-20-2010, 10:01 PM   #22
BoostbyU06
Member#: 156340
2007 STI
you guys tune a dom 3 xtr yet?
BoostbyU06 is offline   Reply With Quote
Old 02-22-2010, 04:12 PM   #23
SLOJOE
Member#: 163290
04 STI
PSM DOM 3XT-R
+1, i cant wait till the 6th to have mine tuned at the plano facility
SLOJOE is offline   Reply With Quote
Old 02-22-2010, 10:41 PM   #24
gkstar
Member#: 93378
[quote=Cobb Tuning;29811917]COBB Tuning Surgeline weekly tunes for 2/13 to 2/19! Feel free to ask any questions or make any comments.
Weather: Indoor
2009 Subaru WRX
Tuner: Tim Bailey
- SPT Catback
- Walbro Fuel Pump
- Perrin TMIC
Target AFR: 11.2:1
-What was the injector duty cycle for such large injectors and smallish turbo? They going E85 next? Curious to know about injector size for similar set-up but just 93oct. Thanks
gkstar is offline   Reply With Quote
Old 02-23-2010, 12:18 AM   #25
jstalford
Member#: 175819
2006 Rav4
I think he's already on e85.
jstalford is offline   Reply With Quote
COBB Tuning Surgeline Weekly Tunes! 4/26-4/30! 1 WRX, 4 STis and 1 GT-R! 2218WHP! Cobb Tuning Proven Power Bragging 11 05-04-2010 12:38 PM
COBB Tuning Surgeline Weekly Tunes! WRXs, STis and Evos! Cobb Tuning Proven Power Bragging 11 04-05-2010 12:59 PM
COBB Tuning Surgeline Weekly Tunes (3/22-3/25)! 1741WHP Redline Time Attack Edition! Cobb Tuning Proven Power Bragging 11 03-30-2010 05:45 AM
COBB Tuning Surgeline Weekly Tunes (3/6-3/15)! 1171WHP Subaru Power! Cobb Tuning Proven Power Bragging 5 03-17-2010 07:20 PM
COBB Tuning Surgeline Weekly Tunes! STis VS Evos! 1555WHP! Cobb Tuning Proven Power Bragging 8 02-28-2010 09:06 AM
