South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 02-20-2010, 02:32 PM   #1
Jettin2Class
Member#: 196670
Default Where to find a 2L turbo WRX motor?
I have a 914 with a tired motor that I want to punt in favor of the Subaru motor. Any input on what motors to get/not to get or where to get/not to get them would be appreciated. Thanks guys.
(in Tucson)
Function first, "pretty" later.
Jettin2Class is offline   Reply With Quote
Old 02-20-2010, 03:12 PM   #2
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
I would recommend any motor out of a 90-95 subaru. Specifically the legacys, because they are so many of them out there. Imprezas are probably a little more work as the harness runs across to the drivers side fender for the motor, but at the same time the harness will be longer so you have more options in placing everything.
I've done a few conversions into sandrails with SVX motors and 2.0-2.2 amd they run jsut fine using the stock harness (stripped down of course) and the stock ecu.
You might be able to find a donor car on craigslist that needs a trans or something stupid, pull all the parts and sell or trash the rest.
I've seen plenty of legacys at the salvage yards in phx, that would make good donor cars, specially at the "U-pull it" yards. I would call around and see what you can find, also check "www.car-part.com" that will search most of hte inventory of the higher-end yards, some of the smaller yards won't have the software, so you'll just have to call them.
Try to use a harness and ecu that both came from the same car, the motor doesn't really matter as long as the ecu supports all the sensors, EGR is probably one of the only concerns.
bobturismo is offline   Reply With Quote
Old 02-20-2010, 03:17 PM   #3
acrobatix
Member#: 44537
acrobatix is offline   Reply With Quote
Old 02-20-2010, 09:33 PM   #4
Jettin2Class
Member#: 196670
Are the Legacy motors turbo? I've seen very few donor cars around here that are worth jack. I've seen places like Outfront Motorsports that make adapter harnesses/ECUs for these applications, but those are ~$1500.
I've come across some SVX motors but I've heard they're heavy and parts are sometimes expensive. Keeping my little bucket light would be nice.
If you should see a suitable donor in your harvesting (assuming you don't need it), if you could let me know that would be awesome. I'm in Tucson, but would come up to Phoenix for the right bits.
Old 02-21-2010, 11:32 AM   #5
racingfish
Member#: 60976
1969 LGT
FATURBO
talk to japcarrealgood.
racingfish is offline   Reply With Quote
Old 02-23-2010, 03:37 AM   #6
speed_raca7
Member#: 151702
Chapter/Region: HIIC
04 STI
i have a motor.. its from an 03wrx wagon
speed_raca7 is offline   Reply With Quote
Old 02-27-2010, 10:55 PM   #7
bobturismo
Member#: 42145
6-4 jockin da bish-
i forgot to mention that if you use a obdii setp, you run into the problem of not having a speedometer sensorto bfeed the ecu if you are using a vw transmission, you would have to get a hydra probablyor you might be able to tune it out with open ecu. you might be able to use an older ecu to run a obdii motor, just have to repin the ecu plugs.
Old 02-27-2010, 11:22 PM   #8
NAZSTI
Member#: 164516
2004 STI
if you decide to go 2.5......here is a 2.5 cheap!!!
http://prescott.craigslist.org/pts/1620847210.html
NAZSTI is offline   Reply With Quote
Old 02-28-2010, 09:56 AM   #9
Jettin2Class
Member#: 196670
Yeah, on the 901 trans (Porsche --> VW is 091?) the speedometer sensor is in it. Hydra? And Open ECU: Is that a Subaru tuning utility for a laptop I assume?
I may have a line on a WRX motor with an STI turbo and injectors. We'll see.
Old 02-28-2010, 10:03 AM   #10
shwoop_soobie
Member#: 102323
99 power poles
beware
http://phoenix.craigslist.org/evl/rvs/1617172392.html
its an older motor with waercooled intercooler...
shwoop_soobie is offline   Reply With Quote
Old 02-28-2010, 10:17 AM   #11
Jettin2Class
Member#: 196670
Thanks for the CL ads guys. I need an ECU and harness at least though unless people have those or I can source them from elsewhere relatively inexpensively. It's making the $1800 WRX motor (complete) sound better and better since that's also a price shipped to me.
Old 03-01-2010, 12:44 PM   #12
bobturismo
Member#: 42145
6-4 jockin da bish-
i forgot to ask, is that WRX motor obd i or ii?
hydra is a standalone ecu, it will alow you to run without the spedometer sensor hooked up. I think they're $1500 ish
openecu allows you to tune a factory ecu, not sure if you'll be able to get it running properly without the speedo. basically free, you just need someone with teh cable
Maybe the porsche sensor will work for ecu, im sure google will yield the answer. Best thing to do is search people that all ready have done conversions.
also keep in my ind you have to get the bell housing adapter and the flywheel, that **** is pricey, but sometimes you can find a good deal on a used one.
Old 03-01-2010, 02:53 PM   #13
Jettin2Class
Member#: 196670
I've seen those Hydra pieces (Outfront motorsports). I was hoping I could do without one. I believe all motors after '96 are OBD II, so this one being a 2003 0r 04 should be OBD II as well.
I know about the bellhousing/flywheel bit and it's in the plans. I think for a comparatively rare piece (how many Suby 914s are really running around anyway?) the odds of finding a used one are slim to none. The whole setup through KEP or Smallcar is ~$450.
Old 03-01-2010, 02:58 PM   #14
bobturismo
Member#: 42145
6-4 jockin da bish-
should be the same piece as the vw
there's plenty of those around from people doing sandrail/vw bus/vanagon conversions.
You'd be surprised how many people buy a lot of the stuff and abandon the project becasue they need the cash.
Old 03-01-2010, 03:18 PM   #15
bobturismo
Member#: 42145
6-4 jockin da bish-
ignore that link that was here, I read taht wrong
The guy that I built teh rails for says that the adapters pop up on craigs every once in a while
I bet if you put a wanted ad for subaru VW adapter conversion parts, you'll get some calls
Where to find a blown 2.5L motor? Justaguy General Community 8 03-15-2006 02:53 PM
where to find second hand leather WRX driver's seat? bigpaulo New England Impreza Club Forum -- NESIC 4 12-24-2005 12:05 PM
where to find 02/03 PSM WRX fromt bumper skin??? 516_WRX_V2 Tri-State Area Forum 1 10-24-2003 10:13 AM
where to find my TO4R turbo exhaust inlet flange. Please read STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-06-2003 07:53 PM
Where to find forged rims for wrx? rex n effect Brakes, Steering & Suspension 15 03-05-2002 12:18 AM
