Old 05-28-2002, 03:20 PM   #1
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Question How long should I wait?
I just got my WRX and I have heard that removing the silencer from the intake will allow you to hear the turbo and BOV beter. My question is would it be too soon to remover the silencer since I only have close to 300 miles on the car? Or should I just wait till the breakin period is over? Thanks in advance for the replys!!!
ShaggyGT is offline   Reply With Quote
Old 05-28-2002, 04:02 PM   #2
chmoorewrx
Member#: 17546
2002 WRX Wagon
WR Blue
I did mine right away. It won't have any effect on break-in.
chmoorewrx is offline   Reply With Quote
Old 05-28-2002, 06:07 PM   #3
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
Yeah dude hack away at the silencer. I removed mine the first week I had it. Plus, you don't have to baby your car so much that you don't have fun during the break in period. If you want to take 1st and 2nd to redline, go ahead. Just don't go blazing down the expressway with your foot to the floor in third. For real though 1st and 2nd don't have that much load. You won't hurt anything. Just don't do it too much. But doing it a couple times during break in is OK.
kenshiro is offline   Reply With Quote
Old 05-28-2002, 06:47 PM   #4
ShaggyGT
Member#: 19221
Well I took out the silencer!! Man that has to be the easiest thing I have done to a car!!! Thanks for the replys guys. It is sooo hard not to let it go past 6000 rpms in any gear. I am being really careful because I warped the cylinders in my Si when I got it and it began to burn oil. I would love to open her open to see what she has but I am to afraid of messing her up in the long run for a few seconds of fun.
Old 05-28-2002, 11:13 PM   #5
Weedy
Member#: 12340
2002 WRX 2.5L Hybrid
I have a suggestion for you. Check your owner's manual about your break in period. That will explain to you the proper way to break in your engine. Just FYI...
Weedy is offline   Reply With Quote
Old 05-28-2002, 11:21 PM   #6
ShaggyGT
Member#: 19221
Yeah I read through that and I have been taking it pretty easy on the engine. I drove the car tonite after taking out the silencer and after driving it for a little while I could really start hearing the turbo alot beter. Everyday that I drive it and sit inside the car I begin to love it even more. I couldnt have purchased a beter car!!!!
Old 05-28-2002, 11:41 PM   #7
xxsive25
Member#: 16669
my02 rex
blue
Default drive it.............................
i got my rex w/ 125 miles on it......
then i went home and made a cad,
and have driven it like a stole it since i
got it. i build race engines and let them
idle 4 about 1/2 an hour. then all balls
from there. u wont hurt her unless
ur under extream loads for long periods of time.
so just keep the r's movin
i was always taught break her in the way u drive
xxsive25 is offline   Reply With Quote
Old 05-28-2002, 11:44 PM   #8
Weedy
Member#: 12340
Thumbs up
I must admit that I was amazed at the difference that taking out that silencer made. You can definitely hear the turbo and the BOV after that. I don't really know if it has any effect on performance, although by looking at the stock airbox and all the plumbing, I don't see how removing it can't contribute to something. Glad to hear that you enjoy your car. I enjoy mine more, and more every day. It works both ways, you show her love, and she will show you plenty right back! Did you get a MT or auto? If you got a MT, don't be scared of all the things that you hear on this forum about the tranny being weak. If you treat the tranny properly, you shouldn't have any problems with it. Don't drop the clutch, and make sure you just let the shifter glide into gear every shift. I'll stop rambling now...
Old 05-28-2002, 11:57 PM   #9
ShaggyGT
Member#: 19221
I got a MT of course!! When I took out the silencer I couldnt believe that thing even flowed enough air for the turbo!!! That small hole is what is supposed to flow air to the intake???? Since I took it out so soon it is hard for me to say wether or not I noticed a gain because the car is still blowing my mind!!!
xxsive25, what you say about how you drove your car makes me feel beter about the couple of times I took mine to around 5500. I know I could probably drive it a little bit harder now that I have 500 miles on the odometer, but like I said I had a bad experience with driving my Si hard when I first got it so I am a bit scared to screew up the engine in this car. I plan to let the ecu know how I like to drive after the break-in period, trust me!!!
Old 05-29-2002, 12:18 AM   #10
Weedy
Member#: 12340
Yeah don't forget that you have forced induction now. A little different from a NA engine. If you would theoretically figure out the compression ratio for a forced induction engine under boost, you would be stunned at the result. A friend of mine with a turboed Integra GSR, figured that his approximate compression at 7PSI was around 34:1! Keep in mind this is theoretical, not something to base anything off of.
Old 05-29-2002, 08:36 PM   #11
Ponm
Member#: 17321
2002 wrx wagon
blue
Default Where is it...
Where exactly is the silencer. I haven't heard anything about this, I just might have to try it out.
Ponm is offline   Reply With Quote
Old 05-29-2002, 09:32 PM   #12
Dayf
Member#: 14348
06 Evo MR
Graphite Grey
It's in the passenger-side fender. FWIW please don't "hack away" at anything because you might want to put it back later. I was told by vishnu that it doesn't cause any real performance gains, so it's more of a sound mod. I did this mod and got really tired of the hiss, so I put the silencer back on.
Dayf is offline   Reply With Quote
How long should you wait to put a coat of wax on a repainted door? mrtrex Interior & Exterior Modification 15 07-27-2003 05:32 PM
new car, how long should I wait before getting reflased ? samh22a Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 04-25-2003 10:57 AM
freshly painted side skirts, how long should i wait to install them? Tobey Interior & Exterior Modification 1 04-16-2003 02:41 PM
how long should i wait djrocker666 Car Care & Detailing 4 08-30-2002 11:30 PM
How long should i wait to wax juztin180 Newbies & FAQs 12 03-12-2002 01:26 AM
