Old 02-20-2010, 11:25 PM   #1
jtmarsh
Member#: 214967
Default Under target boost and lean afr
After installing my cobb dp on my 07 wrx, I wasn't hitting target boost. I checked and saw that maybe my wastegate arm was hitting the heat shield so I bent back the heat shield and now there is a little jump and then boost drops to 13 psi till redline. I have three logs, all of them are 3rd gear pulls...
First link is for pre heat shield bend
http://www.mediafire.com/file/ojz5ijiwgmn/datalog8.csv
Next two are after and a reset of the ecu
http://www.mediafire.com/file/dye4tmluyut/datalog9.csv
http://www.mediafire.com/file/y1zgqwm1njm/datalog10.csv
jtmarsh is offline   Reply With Quote
Old 02-21-2010, 12:07 AM   #2
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo;Fun CRZ
try tightening the wastegate arm by half a turn and post up some datalogs. This is what most people do.
Its probably due to the need to adjust the wgdc/wgdc temp compensation table.this, you'll need to sign up for tuner race software. keep reading and when you're comfortable, these people will guide you.
Ysidro is offline   Reply With Quote
Old 02-23-2010, 07:43 PM   #3
jtmarsh
Member#: 214967
Okay so... after preloading the wastegate (shortening the acuator arm by a turn). I am now spiking in 4th and 5th getting 17 psi and tapering to low 15s high 14s and underboosting in 3rd getting 14s no idea how this is even possible. I checked all the lines running from the wastegate acuator all seem pretty snug so I'm thinking that my intercooler hoses might be leaking or something. But on a good note, my afr seems to have gotten significantly richer. It's within the map specs so thats solved I believe.
FS : Defi Racer Boost and EGT gauges Faster_Gun Interior/Dressup/Audio & Security 7 06-09-2010 09:37 PM
vf39 installed - car misfires and hesitates >3000rpm + lean afr anarchyburger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 11-06-2008 12:21 AM
V6 RA with Ecutec flash99, boost and lean questions! Sylvain b Commercial ECU Reflashes 8 05-01-2007 12:03 AM
V6 RA with Ecutec flash99, boost and lean questions! Sylvain b Pre-2002 Factory Turbo Powertrain 0 04-27-2007 09:00 AM
2006 WRX Target Boost and Altitude verdee AccessPort 3 03-16-2007 05:33 PM
