Old 02-21-2010, 02:34 PM   #1
stwang314
Member#: 170474
2002 wrx
white
Exclamation Torn steering rack boot....
Hey guys and gals. So me and my buddy were putting whiteline steering rack bushings on last night and discovered that the passenger side steering rack boot is torn. Im third hand owner and the car has 141k+ miles on it. its an 02 wrx. i have no idea how long the boot has been torn. Ive owned the car for 3 years now. it doesnt really feel like there is any grease in it, yet, the steering has always felt the same, there are no odd noises that i can hear or anything. I know that it needs replacing but money is tight. does anyone know a DIY or a link on how to replace it? I tried searching on here and scoobymods but no luck. Thanks for your time.
-seth
stwang314 is offline   Reply With Quote
Old 02-21-2010, 04:09 PM   #2
stwang314
Member#: 170474
2002 wrx
white
Bump
Bump
Old 02-21-2010, 06:21 PM   #3
Ramon_12345
Member#: 72021
1999 JDM GC1 IMPREZA
WHITE
Ramon_12345 is offline   Reply With Quote
Old 02-21-2010, 06:23 PM   #4
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
Its not supposed to have grease in it. The boot keeps the shaft clean so it doesn't pull crap into the seal and wear it out which would cause fluid to leak out.
Pop the tie rod end out of the knuckle. Unscrew the end from the rod. Take the clamps/bands off the boot and slide off.
I've never done it on a subie but all racks are basically the same.
GDR is offline   Reply With Quote
Old 02-21-2010, 06:51 PM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
yea but new boots are like $51 each at the dealer.
Old 02-21-2010, 07:19 PM   #6
stwang314
Member#: 170474
2002 wrx
white
screw it, ill just use duct tape..... KIDDING KIDDING KIDDING i love my car waaaaaayyyy more than that(it gets me around in the snow). Im sure i can pick one up at a car parts store for cheap. A boot is a boot imo.
thanks a bunch (i really need to practice using that search bar. i can find everything im not looking for)
Old 02-21-2010, 08:18 PM   #7
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
I just replaced mine a few months ago. Dealer charges like $36, don't buy the worthless clip they try selling to you for another $5. No autoparts stores sell them either. And you are going to need a really big hose clamp, or something to fit around the wider side of the boot. Also, it helps to put a little grease on the inside of the boot to slide it onto the rack, its a tight fit. Other than that, might be a good time to replace your inner and outer tie rods
happs subi is offline   Reply With Quote
Old 02-23-2010, 05:42 PM   #8
2xJeff
Member#: 217568
02 WRX wagon
Thanks Ramon, and happs subi, just found out the same issue, was concerned about repair, not now!!! and will do it myself.
2xJeff is offline   Reply With Quote
Old 03-07-2010, 02:04 PM   #9
mherman
Member#: 240323
1997 Legacy L 2.2L
I also have torn boots on the steering rack (both sides, and I don't know for how long) (97 Legacy, 160K). I just discovered them while trying to find the cause of a rubbing/creaking sound I get when turning at slow speeds after the car is warmed up. Now that I see the boots (both are completely detached from the tie-rod end side clamp, but still attached to the rack side clamp), I suspect the creaking sound is from the rack. Now, I am wondering if I should replace the rack (can't really afford it), or just replace the boots and inspect the seals underneath . Any ideas? Thanks for all the nice tips, here!
mherman is offline   Reply With Quote
Old 03-07-2010, 03:38 PM   #10
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Don't replace the rack, just the boots
Old 04-03-2010, 10:44 PM   #11
mherman
Member#: 240323
1997 Legacy L 2.2L
Thanks for the advice. I replaced the boots and cleaned the ball joints on the inner tie rod (they had a light coat of rust or dust, not sure). Added a bit of grease and put new boots on. The sound is not really happening, so maybe the grease did something. The boots went on ok, except getting the wide end of the boot over the side of the steering rack was pretty difficult. A little patience came in handy there.
FS : OEM CV Boots & Steering Rack Boot, BNIB kpluiten Drivetrain 15 08-17-2010 10:53 AM
Torn steering rack boot frixion Brakes, Steering & Suspension 2 09-07-2007 09:53 PM
PA: steering rack boots scoobyimprza Private 'For Sale' Classifieds 1 05-08-2006 08:13 AM
Steering rack boots (pair) 93-04? Impreza scoobyimprza MAIC Private Classifieds 0 05-04-2006 11:01 AM
HELP! I need to install my replacement steering rack boot before monday!!! DoomEquation Southern California Impreza Club Forum -- SCIC 2 03-21-2004 07:44 AM
