Old 02-22-2010, 01:26 PM   #1
drmichael
Member#: 68340
2006 WRX
SMG
Question Kamak Turbos
stumbled across these turbos' reading through the forums. Any one local has personal experience with them?
these are the two i would be interested in:
http://cgi.ebay.com/Turbocharger-SUB...item3ef7664137
http://cgi.ebay.com/Turbocharger-SUB...item3ef76640ea
do you guys have any good/bad reviews or advice concerning them? my 06 WRX is my DD, and i am not interested in a dyno queen.
Thanks.
drmichael is offline   Reply With Quote
Old 02-22-2010, 01:44 PM   #2
Frankenboost
Member#: 209766
2007 STI limited
UGM - 547WHP / 471TQ
I don't know anything specifically about the company offering the turbochargers however I will give you the info I can based upon what I know about the actual turbos you noted.
Recommendation between the two would be for the unit with the improved bearings. Turbo bearing failure is irritating and time consuming to fix. Also expensive due to labor.
The Mitsubishi TD05H turbine housing is moderate in size however has a lot more flow potential than the stock housing.
The 18G compressor wheel will flow a significant amount more air without causing a large amount of lag as well.
Should be able to produce solid HP all the way to redline at moderate boost without tapering too much.
You will of course want to get supporting mods as well.
I'm sure you already planned for that though.
Expect about 280 to 340 WHP depending on supporting mods and boost levels on our crappy gas of 92 octane.
Frankenboost is offline   Reply With Quote
Old 02-22-2010, 02:05 PM   #3
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
very interesting. they appear to be genuine turbos, not ebay knockoffs. it appears they have the same bearing (journaled) so neither would necessarily be better than the other in that regard. i would probably go for the subaru one for 800
elislider is offline   Reply With Quote
Old 02-22-2010, 03:01 PM   #4
drmichael
Member#: 68340
2006 WRX
SMG
They are both Subaru turbos. From the research i have done, most of the turbos sold in the states, are manufactured by the company who makes the the Kamak turbos. Many sites have confirmed that, but i'll never know for sure.
The first turbo is a TD05H 18G 8cm2 T518Z (Greddy T518Z compressor wheel)
the second is a TD05H-18G 8cm2 the descritption indicates:
Compressor wheel: 50.3 / 68mm ( Greddy T518Z 18G wheel )
Turbine Wheel : 49.1 / 55.8mm ( TD05H Turbine wheel)
any insight on the difference, or which would net better results (longevity, and overall performance characteristics)?
Thanks.
Old 02-22-2010, 06:33 PM   #5
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Try this...
http://forums.nasioc.com/forums/show...ighlight=kando
They are the same turbos as Kando, Kinugawa and a few others. I put their 18g into a legacy gt and its still running well after 6K or so miles, drives very nice. My BIL is hard on cars and if it was crap, it would have blown up by now. I'm surprised he hasn't fried the trans yet.
theotherguy is offline   Reply With Quote
Old 02-22-2010, 07:04 PM   #6
drmichael
Member#: 68340
2006 WRX
SMG
I've read the posts in that thread, and was wondering if someone can educate me on the 2, above listed turbos
Thanks
Kamak turbos gabedude Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 233 06-02-2013 02:59 PM
FS: NoVA: Draco Performance Turbo Blanket for Small Frame Turbo. adjasont Engine/Power/Exhaust 4 06-05-2010 03:15 PM
BNIB Kamak 18G 8cm and DW 650 sidefeeds badhogan Engine/Power/Exhaust 15 10-01-2009 07:34 PM
KAMAK Turbos? 98jdmwrx Pre-2002 Factory Turbo Powertrain 11 06-21-2009 01:10 AM
Kamak Turbos? somaguchi Newbies & FAQs 11 06-11-2009 03:37 PM
