Old 02-22-2010, 11:33 PM   #1
dao
Member#: 134360
2006 WRX
I've had my 06 wrx for a few months now. It's bone stock, and it has 56,000 miles. Today I picked up my car from service after getting the O2 sensor replaced, and a "Valve Air Suction."
In first gear, at WOT between 3K - 5K RPM, the car performs fine. But right after I shift into 2nd and 3rd gear at 3K - 5K RPM, the car feels like its hesitating. Then I decided to reset the ECU by disconnecting the negative cable on the battery, and holding the brake down for about 10 seconds to drain any residual charge and placed the cable back on afterwards. Next, I warmed the car up for 3 minutes and took another test run.
I drove normally to the nearest Shell gas station, about two miles from my house. Pumped gas, and took off and repeated the steps as above stated. The results are the same as in stuttering and hesitation. I'm bringing it to the dealership since it's still under warranty. Thank goodness there's no mods on the vehicle yet.
Are there any ideas of what may be the problem?
Thanks!
dao is offline   Reply With Quote
Old 02-22-2010, 11:58 PM   #2
GripS
Member#: 229152
2007 WRX TR
Seeing as how you are coming up on 60K you are due for plug replacements. Hesitation can be caused by any number of things. It's a good thing you are still under warranty.
GripS is offline   Reply With Quote
Old 02-23-2010, 12:08 AM   #3
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
1980 Porsche 911SC 3.6L
ya plugs would be a good thing to check...
also any check engine codes at all?
fl4tsc is offline   Reply With Quote
Old 02-23-2010, 12:24 AM   #4
dao
Member#: 134360
2006 WRX
P2442 = Secondary Air Injection System Switching Valve Stuck Open Bank 2 --> O2 Sensor = Replaced
P0137 = Valve Air Suction...service said that they had to also replace a valve while replacing the O2 sensor.
Old 02-23-2010, 12:49 AM   #5
spinningcain
Member#: 176490
2005 STI
Clean you maf
spinningcain is offline   Reply With Quote
Old 02-23-2010, 01:41 AM   #6
vinxH
Member#: 159796
2006 WRX
hear any leaks?
vinxH is offline   Reply With Quote
Old 02-23-2010, 03:09 AM   #7
dao
Member#: 134360
2006 WRX
Originally Posted by spinningcain View Post
Clean you maf
will do
Originally Posted by vinxH View Post
hear any leaks?
not sure...what should i listen for?
Old 02-23-2010, 04:08 AM   #8
Soobie22
Member#: 71118
2007 WRX TR 07'
Do a boost leak test, more than likely it may not be one, but it wont hurt to try. Pain in the ass in a subaru tho.
Soobie22 is offline   Reply With Quote
Old 02-23-2010, 09:18 AM   #9
BoostinChick
Member#: 218971
2007 WRX
You can either try spraying soapy water and see where it bubbles, spraying carb cleaner and see if the engine RPM's rise, or a boost leak test with an actual tester + bike pump/compressor. A couple methods to try. I am sure YouTube will have a DIY for them.
I would go the spark plug route first though. Usually with boost leaks it may idle funky as well.
BoostinChick is offline   Reply With Quote
Old 02-23-2010, 01:42 PM   #10
SupersayianNeo
Member#: 49804
2222 WRXSpecV-Type-R
DICK
So the hesitation only existed after the dealership serviced your car?
Gary, come by and ill take a look at it...
SupersayianNeo is offline   Reply With Quote
Old 02-23-2010, 02:04 PM   #11
dao
Member#: 134360
2006 WRX
Yeah, it happened after it was serviced. I did hear a hissing sound though underneath the exhaust area when I turned off my car. A possible exhaust leak maybe the issue itself or part of the problem.
Old 01-19-2012, 12:56 PM   #12
mosley570
Member#: 307410
2004 baja turbo
black
Check for leaks near the turbo and around the new o2 sensor if its the one before the cat. Could have knocked something loose at the dealer and ****ed up a vacuum somewhere. Funny how a small air leak can cause a car to run like complete ****. Also 60k is a good time for plugs and wires.
mosley570 is offline   Reply With Quote
Hesitation at 5000 rpms? 02blueru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 112 04-03-2008 02:45 PM
Small blip of hesitation at 3000 rpms? breathinez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-01-2005 07:13 PM
02 WRX - Hesitation at 5000 RPM tellravi Engine Management & Tuning 4 04-27-2005 11:34 PM
Hesitation at 5000 rpm feropont Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-24-2004 01:33 PM
WRX hesitation between 5-7000 rpm? 996Cabby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-04-2002 11:11 PM
