Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 05-28-2002, 09:27 PM   #1
thejean
Member#: 17763
Question Boost, Wastegates, Bleed and EGT's
Can someone with some good experience explain to me how the following interact with respect to manifold pressures, back pressures, exhaust flowability and turbo spool up times:
1. boost level
2. Wastegates
3. Bleed valves
4. BOV's
5. ECU
I know this is a bit open-ended but I'm looking to get a back-to-basics walk-through of how all this works. Perhaps you'll just refer me to a textbook which is fine. Just recommend a good one is all I ask. If you choose to take a crack at it then I thank you greatly.
JC
thejean is offline   Reply With Quote
Old 05-30-2002, 12:51 PM   #2
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Maximum Boost by Corky Bell
That is a pretty decent book, a bit outdated, but it covers almost all of the fundamentals.
wcbjr is offline   Reply With Quote
Old 05-30-2002, 05:31 PM   #3
thejean
Member#: 17763
Thank you - appreciate the recommendation.
JC
Wastegate Arm and boost creep jeeps1998 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 02-10-2007 02:14 PM
very Slow boost response, swapped wastegate diaphram and arm! GregBolby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-21-2006 07:21 AM
understanding boost, wastegates, and solenoids boostaddict Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 09-12-2003 05:09 PM
Upipe and A/F and EGT's dachoe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-28-2002 03:04 AM
Wastegate Actuators and Boost Controllers mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-20-2002 06:47 PM
