Old 02-23-2010, 04:52 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Is there an aluminum radiator available for the GD 2.5RS?
Does anyone know of an aluminum radiator that will fit a 2005 2.5RS? Koyo doesn't have one. Mishimoto doesn't have one. eBay does, but **** that noise.
Old 02-23-2010, 05:21 PM   #2
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
I imagine Griffin makes one.
XanRules is offline   Reply With Quote
Old 02-23-2010, 05:35 PM   #3
Mishimoto
NASIOC Manufacturer
Member#: 207954
Maybe we can get you set up with a universal radiator? You would only need posts welded onto it to fit into the radiator support.
Send me a PM if you have any questions.
Mishimoto is offline   Reply With Quote
Old 02-23-2010, 05:42 PM   #4
funky monk
Member#: 143094
08 LGT
DBM
I'm surprised Koyo doesn't, I thought they did.
funky monk is offline   Reply With Quote
Old 02-23-2010, 06:25 PM   #5
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Use a WRX/STi one and put a cap in your upper radiator hose. Summit has the adapter for ~$30.
BAN SUVS is offline   Reply With Quote
Old 02-23-2010, 08:04 PM   #6
rougeben83
Member#: 115154
2005 Outback XT
White on grey
If my Legacy can use a wrx/sti radiator, I'm willing to bet that you can too.
rougeben83 is offline   Reply With Quote
Old 02-23-2010, 11:52 PM   #7
GrundleJuice
Member#: 165749
what is the factory crap made of if it's not aluminum? Or aluminium if you're a limey.
GrundleJuice is online now   Reply With Quote
Old 02-24-2010, 12:02 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Bronze and something or the other. I'm not really sure that aluminum racing radiators are better at cooling because they're aluminum or because of some other design change that just happens to be sold along with the aluminum.
Old 02-24-2010, 12:09 AM   #9
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Usually they're better because of the greater capacity, not so much better conductance. They do have more transfer area too typically, so I suppose mostly they do have a greater capacity for heat transfer.
Old 02-24-2010, 10:53 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Really? I haven't seen a non-aluminum OEM radiator in any car in years. All the Subaru radiators I've ever seen are aluminum with plastic end tanks. Strange that Subaru would have "regressed" to the cheaper style in later years.
Actually, aluminum is not as good at transferring heat as copper/brass. But aluminum is lighter and stronger, so the entire (empty) radiator should weight noticeably less and use larger tubes, which allow for more contact between the fins and the tubes. I'm honestly not sure how that ends up balancing out - copper/brass' better heat conductivity vs. aluminum's better efficiency in construction. As BAN SUVS said, aluminum aftermarket radiators are often better because they have a thicker core, so it's not a particularly even comparison. (That greater capacity also tends to wipe out the weight savings, since your radiator is now carrying that much more fluid.)
Pat Olsen
Patrick Olsen is online now   Reply With Quote
Old 02-25-2010, 02:34 AM   #11
rougeben83
Member#: 115154
2005 Outback XT
White on grey
The other thing that people switch to aluminum radiators is that they don't have to deal with plastic endtanks anymore. That's usually where the stock rads crack/leak at.
is there a metal piece available for the exhaust cutout? will667 Interior & Exterior Modification 10 04-17-2005 04:22 PM
Is there a rear LSD available for my car? d4d4d4d4 Transmission (AT/MT) & Driveline 0 12-20-2003 10:02 PM
Is there a MOMO HUB available for 92 Legacy? Dealer Xing Legacy Forum 2 04-21-2003 01:37 PM
Is there a sequential shifter available for the AT Imprezas? RSarte Normally Aspirated Powertrain 0 04-17-2001 10:52 AM
Is there a turbo/supercharger kit for the 2.2? KaZ General Forum Archive 7 02-23-2001 01:41 AM
