Old 02-23-2010, 09:41 PM   #1
Bakerbrdz
Member#: 132394
1.21 gigawatts?
Lighting bolt power bitch
Default not too many vf 22
Ambient Temp 76
Elevation: 0
Weather: clear
Tires: falken
2006 WRX tr
Tuner: keian
Dyno Info: Dynojet
Peak HP at RPM:293whp @ 4500
Peak TQ at RPM: 345wtq @ 3700
Baseline hp/tq for a stock on same dyno:~180whp
Target Boost: preferably in psi: 20
Fuel: 93 octane
Power Modifications: vf 22, CCS frontmount, perrin v2 short ram, fuel pump, perrin inlet hose, wrapped tbe, wrapped stock headers, wrapped hks uppipe, stock bpv.
urban grey with 18 x 8.5 bronze rota torques!!!
Bakerbrdz is offline   Reply With Quote
Old 02-23-2010, 09:52 PM   #2
clkoontziii
Member#: 128389
2006 impreza wrx
steel gray
sorry what is a VF22 from?
clkoontziii is offline   Reply With Quote
Old 02-23-2010, 09:55 PM   #3
Unrealgtx
Member#: 178853
2007 Sleeper Suby
i believe the 22b
Unrealgtx is online now   Reply With Quote
Old 02-23-2010, 09:56 PM   #4
clkoontziii
Member#: 128389
2006 impreza wrx
steel gray
nice thx
Old 02-23-2010, 10:47 PM   #5
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
it was used on some 22b, but the main 22b turbo was a VF23,
on another note numbers look good, do you have a dyno sheet
seanathanq83 is offline   Reply With Quote
Old 02-24-2010, 12:13 AM   #6
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
OP, you happen to have a dyno plot to add? Would be helpful.
To the others, AFAIK the VF22 was never used on the 22B. The VF23 was. They are quite a bit different in size. A VF22 will make quite a bit more power.
Scooby921 is offline   Reply With Quote
Old 02-24-2010, 12:15 AM   #7
seanathanq83
Member#: 173241
AFAIK there was said to be a few used because of lack of VF23 but thats just what i read, the VF22 is of the sti
Old 02-24-2010, 02:58 AM   #8
liljon350
Member#: 197068
2006 WRX evo316g'd
WRB 293whp/322tq [email protected]
good numbers, i almost went with this turbo
liljon350 is offline   Reply With Quote
Old 02-24-2010, 09:47 AM   #9
Defiantspaz
Member#: 101100
04 WRX STi
WR Blue Pearl
I remember reading that the VF22 was an option on the 22B, can't seem to find the site I saw it on as I read it 4 years ago when I had decided to go with a VF22 on my STI.
Defiantspaz is offline   Reply With Quote
Old 02-24-2010, 10:05 AM   #10
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
Go back to 2004 2005 the vf22 was very popular, seems like it faded out with all these large companies coming out with stock location turbos.
perrin247 is offline   Reply With Quote
Old 02-24-2010, 10:25 AM   #11
Ru fan
Member#: 1605
1997 1.8L Brighton
NESIC TrackH0z member#1
VF22= MY1997 Ver.3 WRX sedan turbo. Oddly, the STi's came with the smaller VF23. 22B=VF23
Ru fan is offline   Reply With Quote
Old 02-24-2010, 10:31 AM   #12
JoeTX
Member#: 83069
2007 STi 302/350
UGM Wingless
A plot would be nice. Where does it hit full boost?
JoeTX is offline   Reply With Quote
Old 02-24-2010, 10:01 PM   #13
Bakerbrdz
Member#: 132394
1.21 gigawatts?
full boost (20 psi) at 3250 - 3300. sorry havent uploaded dyno sheet.
boost starts to taper at 4500 and ends up being 16 psi at 6000. i had it tuned to stop at 6000.
thanks for the comments guys, its an older design for a turbo so heat is an enemy!
Old 02-24-2010, 10:07 PM   #14
JokerDMX
Member#: 175664
03 WRX
FP Green/Built&Cam'd 2.5L
20psi at 3300 on a VF22? I have to see a dyno plot to believe that Thats awesome if it spools that quick though! My old VF22 setup with water/meth and an aggressive tune wasnt at 20psi until around 3800. Makes me jealous of you sea level guys, altitude sucks
JokerDMX is offline   Reply With Quote
Old 02-24-2010, 10:11 PM   #15
Bakerbrdz
Member#: 132394
1.21 gigawatts?
its pretty sweet!!!! 3400 to like 4200, its stays at 21 22ish. i was thinkin about meth. my tuner said it would pick up 15 to 20 whp easy but you know how those nightmare stories about the tranny!!!
Old 02-24-2010, 10:11 PM   #16
'05Limited
Member#: 102236
2006 Legacy Spec B
355whp/360wtq
Extra .5l of displacement doesn't hurt.
'05Limited is offline   Reply With Quote
Old 02-24-2010, 11:39 PM   #17
Defiantspaz
Member#: 101100
04 WRX STi
WR Blue Pearl
My STI tuned with UTEC and a VF22. The VF22 seems to spool really fast and fall on it's face, it doesn't have the same topend that it does on a 2.0L.
Sorry the plot was auto scaled from this Dynapack.
Old 02-24-2010, 11:49 PM   #18
xsnapshot
Member#: 170973
2004 WRX 4EAT
wow there is definitely something wrong with your tune. Below 220whp by redline? I know there will be SOME drop off, but your loosing ~ 60whp in a 1000 RPM window. Just saying. If your happy that's cool, but either your tune is very mild above 6000 RPM or there is something else going on.
I'm diggin the 360 lb-ft @ 3200 though!
xsnapshot is offline   Reply With Quote
Old 02-24-2010, 11:56 PM   #19
seanathanq83
Member#: 173241
wow your worried about horsepower??? he is at less than 80whp at 6750 i hope you just let off at 5750 or something, can we get a dyno from the OP to compare he has a 2.5 wrx
Old 02-25-2010, 12:10 AM   #20
Audioexcels
Member#: 104824
1996 EJ20G OBS
Originally Posted by Bakerbrdz View Post
Ambient Temp 76
Elevation: 0
Weather: clear
Tires: falken
2006 WRX tr
Tuner: keian
Dyno Info: Dynojet
Peak HP at RPM:291whp @ 4500
Fuel: 93 octane
Not wanting to kill your engine, but I'd love to see what that is doing at 24psi. VF22 makes more power as you apply more boost. Will say having that much more power over stock on that dyno is absolutely tremendous. The car must be a sheer brute.
Audioexcels is offline   Reply With Quote
Old 02-25-2010, 02:20 AM   #21
wrxSLEEPER03
Member#: 189820
2009 STI
makes me happy I just bought a vf22
wrxSLEEPER03 is offline   Reply With Quote
Old 02-25-2010, 07:49 PM   #22
Defiantspaz
Member#: 101100
04 WRX STi
WR Blue Pearl
The big issues were the stock TMIC, TXS catted exhaust with a 2.5" rear section, the Perrin SRI and the UTEC.
Car pulled hard then fell flat, just like the dyno plot shows. I am sure if I was running Cobb AP instead of the UTEC that I would have made more power and held it to redline.
I stepped up to an SR55 setup with everything needed to make good power. I stayed with the UTEC at first. Wasn't happy so I switched to Cobb AP version 1.
Thin blue lines are the UTEC, thick blue lines are the Cobb AP. Both runs are with the exact same supporting mods with the same boost, 22 PSI. The car just responded better to the Cobb AP. The UTEC just wouldn't make power up top.
Old 02-25-2010, 09:04 PM   #23
JokerDMX
Member#: 175664
03 WRX
haha, i didnt even notice that. I wish i had a 2.5
Old 08-20-2010, 01:44 PM   #24
Bakerbrdz
Member#: 132394
1.21 gigawatts?
i like cheese burgers!
Old 08-20-2010, 01:45 PM   #25
Bakerbrdz
Member#: 132394
1.21 gigawatts?
thanks man! makes my tummy happy when im flooring it!!!!
Where to send vf-22 to get fixed? jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-22-2006 12:11 PM
vf-22 bolts to vf-34... interchangeable? LatentWagen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-24-2005 02:09 AM
Not to many GF4 pics here MGXsport Member's Car Gallery 11 06-22-2005 01:54 PM
vf 34 up to vf 22 Antonios Kintos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-10-2005 11:32 AM
Where to rebuild VF-22? Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 37 08-23-2001 02:47 AM
