Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 02-23-2010, 09:44 PM   #1
iraj
Member#: 164256
Default 06 wrx vf34
Just got tuned --need nasiocs input Engine mods miles on vehicle 40k
First off i wanted to thank Hill and everyone at Agile for there great customer service and Hill for all his help and guidance. I also wanted to get nasiocs input on what the issue with this setup may be. Hill said i should easily be getting another 30 hp and more torque out of my setup. He looked over everything, there are no leaks, oil needed to be changed but was fine for the moment. everything was installed right. Please give me some input on what i should look towards so i can find out what is causing me to lose this 30hp somewhere.
-We noted that the spt is restrictive but would only be causing little hp but the dp may be the cause of this.
Event: dyno pull
Ambient Temp: in degrees Fahrenheit
Elevation: n/a
Weather: cloudy, wet
Track and Conditions:n/a
Tires: n/a dynapack
Car: 2006 wrx tr
Tuner: Agile Automotive (Hill)
Dyno Info: Dynopack
Peak HP at RPM: 269.5 at 5600
Peak Torque at RPM: 285.5 at 3800
Baseline hp/tq for a stock on same dyno:2.5L wrx n/a baseline on cobb vf39 map ran 223tq 233hp
Target Boost: 19 psi
Target AFR: 11.5
Fuel: sunoco 93
Engine/Power Modifications:
-vf34
-sti tmic with samco y pipe
-spt intake (cone needs to be changed)
-helix 3' catted dp
-spt 3' catback
-walbro fp
-cobb ap
Driveline Modifications: stock 5 speed
Suspension Modifications:n/a
iraj is offline   Reply With Quote
Old 02-23-2010, 09:51 PM   #2
clkoontziii
Member#: 128389
2006 impreza wrx
steel gray
catted DP it sounds Like but im no expert
clkoontziii is offline   Reply With Quote
Old 02-23-2010, 10:54 PM   #3
MattPersman
Member#: 139385
try making a pull with the catback off
MattPersman is offline   Reply With Quote
Old 02-23-2010, 11:25 PM   #4
iraj
Member#: 164256
that wouldnt make much of a difference; the downpipe if clogged would be the difference in the dyno
Old 02-23-2010, 11:32 PM   #5
Tut4u2
Member#: 40424
05 STi
Would make a difference up top but not 30hp worth; not an a VF34 anyways.
Tut4u2 is offline   Reply With Quote
Old 02-24-2010, 07:00 AM   #6
MattPersman
Member#: 139385
sounds like you already know your answer then. Are you just asking people to agree with you about your cat being clogged on your downpipe?
Post should have been "I made X hp but I am going to change my clogged catted downpipe for a catless and Hill thinks I will make 30/30 more"
Old 02-24-2010, 12:13 PM   #7
iraj
Member#: 164256
Nope not 100% sure and not only thst tue dp was fairly new; i wanna see if others ran into this issue themselves n figured out the problem
Old 02-24-2010, 05:14 PM   #8
wrxtacular
Member#: 181711
2004 278whpVF34wagon
Jorge Tuned
my vf34 on a 2L make more HP (less torque), but I'm boosting 22lb. Why stop at 19lb?
wrxtacular is offline   Reply With Quote
Old 02-24-2010, 06:43 PM   #9
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
I see nothing wrong with your numbers. maybe your tuner knows betterbut your making 250whp at redline. Maybe this isn't a heartbreaker dyno but if an OTS map makes 230hp and a protuned map makes 270, those are legit numbers and i'm sure that thing is in the 12s.
scoobystas is offline   Reply With Quote
Old 02-25-2010, 02:14 PM   #10
stimobetta
Member#: 110287
My setup is just about the same as yours, except I'm running crap 91 and a catless turboback. I made 275whp and 290wtq.
stimobetta is offline   Reply With Quote
Old 02-25-2010, 02:23 PM   #11
fourmicah
Member#: 128760
2015 STI
You could gut the DP and see, It's not like they are going to take it off and check to make sure the cat material is there.
fourmicah is offline   Reply With Quote
Old 02-25-2010, 11:16 PM   #12
wrxtacular
Member#: 181711
Jorge Tuned
Who really cares about the numbers game? I bet its a blast to drive.
Old 02-26-2010, 09:42 PM   #13
iraj
Member#: 164256
its deff fun to drive; i can tell you this my gas mileage is better than when i had the td04; i think thats mainly because my boost isnt instant anymore but iono; but yea its deff a whole lot funner to drive especially since i just installed the cusco ff and rr swaybars/kartboy endlinks those with rce black springs and 04 sti struts wow made such a big difference i cant explain
Bought my 06 WRX TR today! balls2dawalls Newbies & FAQs 18 06-08-2010 09:57 PM
07 wrx vf34 tim bailey tuned Jbskate1002 Proven Power Bragging 0 06-04-2010 05:32 PM
VF34 and other 06 WRX parts rpolloc9 Engine/Power/Exhaust 12 01-15-2007 09:03 PM
VF34 on 06 WRX finally installed & tuned! ChrisCJ99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 52 11-29-2006 11:01 PM
Run VF34 on 06 WRX without tune? ChrisCJ99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-09-2006 11:01 AM
