Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 02-23-2010, 11:12 PM   #1
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Default Road Tune: 2.5L + Dom4-XTR Makes 470whp on 91+meth
Event: Road Dyno
Ambient Temp: 55*
Elevation: 2700 ft
Weather: dry and mildly cold
Track and Conditions: CA 178
Tires: bridgestone RE01's
Car: 2006 STi
Tuner: Phatron using Romraider & Ecuflash
Dyno Info: Airboy
Peak HP at RPM: 470 whp @ 6400 rpm
Peak Torque at RPM: 438 wtq @ 5200 rpm
Baseline hp/tq for a stock on same dyno: 220 whp / 235 tq (sti)
Target Boost: 31-32 psi
Target AFR: 11:1
Fuel: 91 octane + VP M3 methanol
Engine/Power Modifications: sleeved ej257 w/ rods n pistons, tbe, perrin headers, ur up-pipe with tial 38mm ext gate, dom4xtr, tgv deletes, aquamist hfs5 dual meth, spearco tmic, hallman mbc+perrin ebcs, KSTech 83mm CAI, aps inlet
Driveline Modifications: act street clutch, gruppes flywheel
Suspension Modifications: sti pink springs, beatrush engine tranny and pitchstop
Other Modifications: Audio integrations sub box and amp rack. spec-c 12L meth tank, stri gauges, lc-1
I installed the turbo a couple weeks back but couldnt get over 26psi. Figured it was the stock bpv leaking so i got a Forge Race BPV & installed the Forge BPV with the blue spring and 3 shims last night.
Didnt touch the tune from my OG Green.....did a pull and the boost was hitting 32 psi and vacuum lines were popping off. Went by home depot and got some small worms clamps and put em on. Turned the mbc down 2 turns for the first pull, then back up 2 turns for the second pull.
Suck on that mikey
Time to turn your boost up.
mind you this is on 91+meth too.....no vp109 here
Code:
Time	LOAD 	RPM	FBKC	FLKC	IAM	IGN	MRP	MAF	MAFv	LC-1
0	0.65	2966	0	0	1	47	-8.77	34.98	2.02	13.29
252	1.28	3034	0	0	1	38.5	-2.77	69.54	2.52	13.47
564	1.46	3078	0	0	1	33.5	-1.51	75.15	2.68	13.66
796	1.6	3192	0	0	1	31.5	-0.33	88.4	2.78	12.69
1104	1.78	3279	0	0	1	29.5	0.95	95.47	2.86	13.16
1339	1.98	3413	0	0	1	27	2.5	114.52	3.02	13.11
1620	2.18	3514	0	0	1	23	4.55	129.39	3.12	12.67
1918	2.45	3668	0	0	1	20.5	7.25	153.04	3.3	12.85
2173	2.77	3839	0	0	1	17	11.06	177.8	3.5	12.3
2459	3.29	3983	0	0	1	15.5	16.02	223.75	3.8	11.36
2717	3.93	4202	0	0	1	14.5	21.93	278.66	4.04	10.98
3010	4.49	4476	0	0	1	13	26.63	341.23	4.22	10.75
3284	4.63	4737	0	0	1	13.5	29.56	361.31	4.28	10.89
3556	4.66	5030	0	0	1	13.5	29.51	379.33	4.4	10.88
3787	4.56	5235	0	0	1	15	29.23	397.18	4.42	11
4100	4.48	5492	0	0	1	15	28.34	411.37	4.48	11.13
4336	4.37	5754	0	0	1	15	28	426.59	4.5	11.17
4603	4.25	5954	0	0	1	15.5	28.25	413.4	4.52	10.94
4875	4.1	6116	0	0	1	16	28.17	419.48	4.52	10.92
5184	4.04	6306	0	0	1	16.5	28.05	430.64	4.5	11.1
5419	3.91	6482	0	0	1	17.5	27.9	432.56	4.5	10.94
5725	3.84	6724	0	0	1	18.5	27.85	436.83	4.54	11.17
5980	3.75	6912	0	0	1	19.5	27.73	427.44	4.56	11.04
Code:
0	0.63	2591	0	0	1	46	-9.27	27.99	1.96	13.41
287	1.22	2632	0	0	1	37.5	-3.32	57.75	2.44	13.3
570	1.42	2725	0	0	1	33	-1.89	66.37	2.56	12.99
861	1.51	2799	0	0	1	31.5	-1.08	73.55	2.58	12.98
1116	1.58	2894	0	0	1	31	-0.18	77.78	2.66	13.16
1403	1.72	3018	0	0	1	29.5	0.68	86.37	2.72	13.32
1656	1.81	3134	0	0	1	28	1.51	94.27	2.86	12.8
1960	1.88	3232	0	0	1	27.5	2.67	100.15	2.88	12.7
2202	2.08	3361	0	0	1	25	3.96	119.33	3.04	12.74
2497	2.26	3510	0	0	1	23.5	5.7	138.74	3.2	13.13
2769	2.52	3664	0	0	1	20.5	7.83	157.4	3.3	13.07
3014	2.76	3813	0	0	1	18.5	11.42	174.59	3.54	12.04
3304	3.2	3984	0	0	1	17.5	15.77	217.84	3.78	11.23
3548	3.74	4197	0	0	1	16.5	20.69	264.73	3.98	11.25
3855	4.24	4488	0	0	1	15	25.35	322.17	4.16	11.04
4103	4.65	4728	0	0	1	14.5	29.22	364.19	4.34	10.66
4396	4.7	5000	0	0	1	15	30.57	392.15	4.38	11.01
4630	4.65	5220	0	0	1	15	30.45	405.53	4.44	11.17
4938	4.49	5483	0	0	1	15	29.8	416.35	4.48	11.16
5192	4.38	5770	0	0	1	15	29.28	416.99	4.5	11.36
5477	4.23	5924	0	0	1	15.5	29.36	419.19	4.54	11.17
5733	4.15	6174	0	0	1	16	29.13	438.14	4.48	11.14
6027	4.01	6382	0	0	1	16.5	29.01	420.62	4.54	11
6267	3.98	6564	0	0	1	17.5	28.83	429.16	4.52	11
using EQ Tuning software
Old 02-23-2010, 11:21 PM   #2
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
wow man looks great, is this s built block or stock??? 30+psi FTW
seanathanq83 is offline   Reply With Quote
Old 02-23-2010, 11:28 PM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
updated the first post. its a sleeved ej257 with rods n pistons.
Old 02-23-2010, 11:30 PM   #4
wrxsomeday
Member#: 141991
08 STi AW
12 Legacy 3.6R
holy poop, 32psi..that's like a damn diesel!
nice numbers though...be interesting to see what it could make on 93 or race gas.
what are you building it for?...drag I'm assuming?
wrxsomeday is offline   Reply With Quote
Old 02-23-2010, 11:45 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
no, its my daily driver....i have a gutted wrx thats gonna be my drag strip car.
i just turned the mbc down 4 turns. im not gonna run that kinda boost everyday.
Old 02-23-2010, 11:48 PM   #6
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Nice tune Ron!
I do have a Question for you.
what made you choose this over the atp 35r?
I mean it seems like this turbo is under achieving...
Cory
renosubby is offline   Reply With Quote
Old 02-23-2010, 11:50 PM   #7
MattPersman
Member#: 139385
30 psi Ron, thats like daily driving nice results maybe I need to try one of those forge BPVs
MattPersman is offline   Reply With Quote
Old 02-23-2010, 11:58 PM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
Originally Posted by renosubby View Post
Nice tune Ron!
Cory
it was cheaper
450 is underachieving? jeez
mind you my OG Green did 375 and the HTA Green did 400.
Old 02-24-2010, 12:01 AM   #9
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
I would think that it would make around 500whp, I think its VERY laggy as well! JMHO.
If this is the final tune of course!
I would expect full boost about 4400-4500 to be what it should be, but this turbo doesn't seem to kick in till almost 5000
Im not saying its not making power. Just that it should make more!
Old 02-24-2010, 12:12 AM   #10
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Sweeeet! Get those injectors yet you need the E85 for some real good times...
TDagen is offline   Reply With Quote
Old 02-24-2010, 12:21 AM   #11
Phatron
Member#: 36033
CEO PhatBottiTuning
U think it should make 500whp on 91+meth?
"full boost" is relative to what its set at......show me a turbo hitting 30psi at 4400rpm.
it hits 20psi at 4000rpm......which is better than most of the dom3xtr's that have been posted.
Old 02-24-2010, 12:28 AM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
Heres my 2nd log in Ed's software.....the first one wasnt too pretty
Old 02-24-2010, 08:28 AM   #13
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
People have to understand what 470whp actually means on a road dyno. That is crazy power. On a SAE corrected dynojet 530-540whp would be had out of this set up, which is very imoressive to say the least (and he is still on a TMIC!!!).
Congrats Ron, Im sure it felt damn good doing a few pulls at that power level. 1-1.5 turns of the mbc should get me there with you (~30-31psi).
So with 4 psi more and 2 degrees less you made 20whp more roughly. Thats close enough to say our turbo's are performing relative. When do you think your 10cm^2 starts to pull on my baby back housing'ed turbo? Im not sure either of us are going to turn it up all that much more to find out.
Nonetheless, take her out to the track when you get a chance. You should be able to destroy my time, but Im curious to see how the traps line up. I'm going to be heading down to the shop after work. Ill update you on your injectors.
STi Mikey is offline   Reply With Quote
Old 02-24-2010, 09:02 AM   #14
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
Yup, probably about 950 whp if you take it down to Oceanside
Congrats man, throw some cams at it and let it rev
I've ran into some problems with the SD stuff, but it's mostly the lack of a running test car and my pos asus laptop. However, I've been doing more preliminary work on the STi stuff as a result.
Merp is offline   Reply With Quote
Old 02-24-2010, 09:34 AM   #15
fourmicah
Member#: 128760
2015 STI
Great job Ron, I'm glad to see that DOM 4XTR putting out those numbers.
fourmicah is offline   Reply With Quote
Old 02-24-2010, 09:40 AM   #16
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
Looks sick Ron damn I need that KS tech 83mm maf housing!! What size injectors are you running?? Makes me want to ditch my E85 efforts and go with meth. Awesome stuff here I'd like to replace my OG green with one of these by the end of the season.
perrin247 is offline   Reply With Quote
Old 02-24-2010, 09:41 AM   #17
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Big jam. Nicely done.
I'm glad the new valve got rid of the boost leak, but watch your AFR learning with that one. I've seen it wander back and forth on that valve for some reason and putting a stock BPV on made it stop on every car with no other changes.
Innovative Tuning is offline   Reply With Quote
Old 02-24-2010, 09:41 AM   #18
fourmicah
Member#: 128760
2015 STI
That's the amazing part! Is this just straight meth injection or a combo with water. Does meth have any cooling properties, or does it just keep knock down? Can someone explain more?
Old 02-24-2010, 09:49 AM   #19
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
where are the dom 4.0xtr deals ron?!?!?
ownnij is offline   Reply With Quote
Old 02-24-2010, 09:50 AM   #20
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
Nice numbers
Cbgrandtheftauto is offline   Reply With Quote
Old 02-24-2010, 10:22 AM   #21
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
I do not believe there should be any WOT learning in Ron's case. The max C /min D learings have been changed from 40g/sec to 85g/sec. So the car doesnt learn WOT corrections when going part throttle on the highway
Old 02-24-2010, 11:32 AM   #22
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Yup that's a good trick. I go to 90, but 85 should be plenty. Ron seems to want to do things properly in terms of the scaling and fuel trims, as I do, so it still bugs the heck out of me.
Old 02-24-2010, 11:38 AM   #23
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Any ideas as to why the forge seems to induce corrections?
Old 02-24-2010, 11:52 AM   #24
Phatron
Member#: 36033
CEO PhatBottiTuning
Default Re: Road Tune: 2.5L + Dom4-XTR Makes 470whp on 91+meth
Cuz the forge can come with a little chitty spring.....so little that the vacuum being pulled by the return line to the intake sucks it open under vacuum.
Old 02-24-2010, 12:00 PM   #25
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Hmmmmmmm. I have a chitty little spring myself....... Why I havnt changed it to compare fuel learnings is beyond me.
I just live with the fact my car cruises at 15.7-16.7 It seems to be happy there anyway being that there is almost 11k on the motor.
Dyno Tune: 2.5L Shortblock + VF39 = 270hp/310tq w/ 91 oct (05 WRX) Kenji815 Proven Power Bragging 28 06-19-2010 07:21 PM
Dyno Tune: Torqued Performance 09wrx 2.5L + 3076 + E85 makes 434whp duece212 Proven Power Bragging 18 12-16-2009 11:15 PM
Dyno Tune: 2.5L hybrid + VF39 makes 352whp on 92 octane *03wRx* Proven Power Bragging 8 11-08-2009 11:18 PM
Road Tune: 2.5L + FP Green (interesting differences in tuning strategies) Phatron Proven Power Bragging 28 11-04-2009 02:58 PM
Dyno Tune: 2.5L + ATP35 makes 360whp 2gnt2wrx Proven Power Bragging 12 10-31-2009 08:32 AM
