Old 02-24-2010, 08:00 PM   #1
madkayaker
Member#: 57378
2002 wrx w/ sti swap
04 sti, 11 forester xt
Default inner timing belt cover guides
I need someones expert advice.
I just got some inner timing belt covers and they don't have holes for the belt guides. Has anybody used these covers without guides? Are they necessary?
Best I can tell by searching the part numbers, the ones without the guides say they are for a auto trans wrx. Why would a manual trans need the guides and an auto not?
madkayaker is offline   Reply With Quote
Old 12-17-2010, 09:23 PM   #2
SubyNewbie60
Member#: 166487
1996 Impreza, caged
and swapped
Bumping for the same question. Is this going to cause an issue for me running them on a manual transmission?
SubyNewbie60 is offline   Reply With Quote
Old 12-17-2010, 11:34 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
On a manual transmission car, it is possible for the engine to turn backwards if the car is bumped or rolls while in gear. If this happens the guides will prevent the belt from jumping off the sprockets and skipping teeth. An auto trans car has no direct coupling between the engine and drivetrain so the same thing can't happen and the guides are not necessary.
Meatys Timing Belt Changing Guide Meatbawl Service & Maintenance 802 11-18-2016 11:01 AM
Timing belt cover and checking the timing belt Pinned Service & Maintenance 14 12-28-2015 01:09 AM
Help Please! Timing belt cutting into timing belt cover behind A/C idler pulley Kansai Subaru Service & Maintenance 14 10-23-2008 05:05 AM
ej257 timingbelt tensioner, belts+timing belt cover, wrx intake manifold+throttlebody White 2.5rs Private 'Wanted' Classifieds 1 07-19-2005 02:11 PM
Instructions for taking timing belt cover off to inpect the timing belt? scoobbee Service & Maintenance 3 05-09-2005 07:33 PM
