#1 |
Member#: 234357
Vehicle:2009 WRX Sportwagen zum einbauen! |
Event: dyno pull / baseline
Location: Cobb Tuning/Surgeline Ambient Temp: ~50 Elevation: ~50 Weather: mostly cloudy Tires: Michelin Pilot Sport A/S Plus, 225/45ZR17 Car: 2009 WRX Sedan Tuner: None Dyno Info: Mustang Peak HP at RPM: 241whp @ ~5800rpm Peak Torque at RPM: 239wtq @ ~4400rpm Target Boost: stock Target AFR: stock Fuel: pump unleaded 92 [color=black]Power Modifications: None, all stock. baseline run with 8500miles on the motor. This may still not be spot on. But it should be significantly more accurate then my last run. And yes, the A/F is still 'scary'.... Got to love the horribly dangerous factory subaru tune... :/
#2 |
Member#: 12281
Vehicle:08 FSXT Tiger's Blood |
seems more realistic than your last numbers, even though you dont want to hear that...
#3 | |
Member#: 234357
I'd much rather have accurate low numbers then incorrect high numbers. The whole point of this run (and the previous) was just to get a good baseline on their dyno so that I can see the starting point before I start doing things to it. Got it down the strip a few times over the weekend also. I was satisfied with the trap speed (100-101), however I wasn't getting the car off the line fast so my time was only 13.95 ![]() |
#4 |
Member#: 12281
what were your 60fts?
#5 |
Member#: 234357
2.24
lol. I was going to make a thread for the run, but I think I'd get a ton of crap for my lousy launches. However, I don't drive the car very often, so driving it is not 'instinctual' yet. Just for a bit of redemption. I used to have a 00' Ford Escort ZX2, and nearly stock I could get a 2.3 60/ft with that, and on my 83' Honda V65 Magna, I get ruffly a 1.9 60/ft with that. |
#6 |
Member#: 56203
Vehicle:00 RSTI Coupe |
with you trapping only 101 id say these numbers are more reasonable.
#7 |
Member#: 298954
NWIC
Vehicle:2008 WRX sedan Spark Silver |
those numbers are not that bad for completely stock with minor bolt-on's my friend is running 315whp / 354ftlb with that VF52
#8 |
Member#: 212399
NWIC
Vehicle:09 wrx 301hp/328tq '00 miata blue |
mine put down 291/335 on that dyno at stage 2. you should strongly consider getting a downpipe and tune.
anyway, check here to compare your numbers to others: http://accessecu.com/dyno/ |
#9 |
Member#: 234357
Whoa, brought my thread back up from the dead.
I won't be able to really do anything to the car until sometime well after the motor goes kaput. Mine is within the 'bad' range and she's still going strong... just waiting for those bearings to go out :/ |
#10 |
Member#: 263470
Well i think everyones numbers are over exagerrated, I was at 237whp full stage2+ with the AVO TMIC, now 315 WHP with HTA68 on an very low reading mustang dyno.
#11 |
Member#: 246224
Vehicle:2012 WRX Sedan WRB awesomeness |
If anyone had any sort of basic math skills here you would realize a 265 crank horsepower AWD car would never put those numbers to the wheels. Your average drivetrain loss in an AWD car ranges from 20-25%. you would be putting anywhere between 198 and 212 to the wheels.
#12 | |
Member#: 212399
NWIC
#13 | |
Member#: 234357
They don't have 265bhp, it's more like 295-300bhp. Surgeline's dyno is not one of the low reading Mustangs. However, to make the comparison a little more accurate, the stock 08+Sti's also put about 240awhp on their dyno. Edit: fixed the first post to bring back the graph.. |
#14 | |
Member#: 157029
SWIC
Vehicle:VF52 Legacy GT |
If you had any sort of common sense, you'd realize that a manufacturer's crank horsepower numbers are not always 100% correct, and cars can definitely be "underrated" from the factory. And if you took a look at what stock 09+ WRXs are running and trapping in the quarter, it's very easy to see that Subaru's rating of 265 HP for this car is pretty conservative. IIRC, there was a guy at that ran a 12.9x in a bone stock 09+. You really think a 205 whp car that weighs what a WRX weighs is going to do that? If you take 100% of AWD cars with 265 horsepower, the chances of them all being between 198-212 whp are very slim. There's a lot more to it than "oh derp 20-25% drivetrain loss". Last edited by DansSpace; 02-19-2012 at 02:20 PM. |
#15 | |
Member#: 225225
Vehicle:11 WRX 335HP, 394TQ, 93 VF52!! |
the wrx has 8.2:1 compression vs. the STI's only 8.0:1. both have the same flow turbo and the wrx flows 14.3 psi vs. the STI at only 14.7psi. the STI has dual AVCS while the wrx only has single but the wrx has a lot less rotational mass in the tranny, diff's, wheels etc (why it weighs more). knowing the timing would make it perfect. based on that i dont see how bph can be -40 to the wrx! and once in the car that margin is a hell of a lot lower. subi's to scared to say it for real because people wont by the STI. what i dont get is you could stage 1 the STI at 18psi tapering to 14psi and get 350bph all day long! |
#16 | |||||
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
#17 |
Member#: 246224
Really? So in other words when you spend that additional $8,500 on an STI; you are spending it on the drivetrain, suspension and brakes. No real difference in power.
Good to know. Glad I didnt waste that money on a DD that is no quicker on the street than my current car. |
#18 |
Member#: 157029
SWIC
#19 | |
Member#: 212399
NWIC
there have been a bunch of threads comparing the wrx vs. stiwhere have you been? living in alaska or something? |
#20 | |
Member#: 246224
If the car is indeed putting down and average of 237 to the wheels and the actual horsepower is closer to 300 to the crank then the car loses 20-21% of its power though the drivetrain. Snarky retard. |
#21 |
Member#: 234357
awww... my suddenly bumped 2 year old thread is suddenly going down hill...
![]() The whole reason I made this thread way back when was because I had previously posted a different dyno result (the dyno wasn't functioning properly) and the result was way off, and I got alot of crap for it. So I had it ran again and this is what it ended up with, which for their dyno, seems about right. |
#22 |
Member#: 157029
SWIC
#23 | |
Member#: 157029
SWIC
![]() So because you used math to come up with 300hp, an arbitrary number by the way, since subaru says the car has 265, all of a sudden I'm retarded? Ok. Sounds correct. |
#24 |
Member#: 72829
W. Canada
Vehicle:2006 HTA68'd wagon Powered by RomRaider |
#25 |
Member#: 261612
Same peak torque, STI has 10HP more on the top end. I guess I'd believe that. Need a bigger sample size to know for sure though.
| Thread Tools | |
| Display Modes | |
| Dyno Tune: 2.0L + VF43 makes 285 whp | dsolis | Proven Power Bragging | 54 | 04-05-2010 06:34 AM |
| Dyno Tune: Motion Lab Tuning Makes 264whp On A '02 WRX TD04 + 2.5L w/STi Cams | Motion Lab Tuning | Proven Power Bragging | 7 | 02-09-2010 06:17 PM |
| Dyno Tune: 08 WRX 2.5L with TD06 18G 8CM^2 Makes 285.6 WHP | N1KN4K | Proven Power Bragging | 26 | 11-26-2009 03:12 PM |
| Dyno Tune: TD04 at P&L makes 320whtq with new TMIC | sszyma | Proven Power Bragging | 28 | 11-09-2009 04:04 PM |
| Dyno Tune: 2.5L + ATP35 makes 360whp | 2gnt2wrx | Proven Power Bragging | 12 | 10-31-2009 08:32 AM |
