Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 02-25-2010, 09:49 PM   #1
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
Default 700 whp goal
Hey there first time ever posting here but thought someone might be interested in reading what i have done and what i will be doing soon, my goal is 700awhp on a dynapak what i have so far
ATP bolt on gt3582R w/ 44 mm waste gate .9 bar spring
Wiseco drop in pistons
eagle rods
kelford 272 cams
prosport unequal manifold/up pipe
bosch ID injectors 1000-1600cc variable injectors
utec delta
3 inch turbo back
walbro drop in
txs fmic and intake
and supporting mods (this included headwork etc.)
with this set up i made 510whp at 26psi ca 91 limited by the wastegate spring
what i think i will need to do to reach my goal
1.4 bar wastegate spring
dual walbro set up
75 wet shot of nitrous
does anyone have some input on what else i will need to do to do the fuel system in order to support about 35psi of boost? what are the limitations to the factory lines?
Rexxyou is offline   Reply With Quote
Old 02-25-2010, 09:57 PM   #2
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Bigger turbo.
But seriously, car sounds sweet. Videos? Track time?
C J is offline   Reply With Quote
Old 02-25-2010, 10:01 PM   #3
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
edit.
Old 02-25-2010, 10:09 PM   #4
hobbesnapoli
Member#: 221436
02 WRX vf39
If you're trying to do this on c16 you could either add a bosch 044 or another walbro - use a factory feed line (pushing it, but it will do it)- then fuel rails and a good regulator.
If you want to use E85 you'll need a larger feed line and probably larger injectors as well.
Be careful with the nitrous- make sure you're not experiencing a significant drop in fuel pressure when it's activated.
hobbesnapoli is offline   Reply With Quote
Old 02-25-2010, 10:21 PM   #5
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
ATP35r won't make 700 at the wheels.
KP is offline   Reply With Quote
Old 02-25-2010, 10:22 PM   #6
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
no not by itself it wont...
Old 02-25-2010, 10:24 PM   #7
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
im confident with about 35psi i will be close to if not over 600whp, and a 75 shot on this set up in an easy 100-120whp extra
Old 02-25-2010, 10:27 PM   #8
06njsti
Member#: 150986
06 #001 LSB STi
is this a joke? youll need 2 atp 35r's to make that much and i doubt an unsleeved block would last you any time at all. Atleast on somewhat of a true reading dyno
06njsti is offline   Reply With Quote
Old 02-25-2010, 10:30 PM   #9
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
If you'd like, follow my build. I'm shooting for the same goal of 700whp but I can assure you I have alot more then what you listed there. First you'd need a bigger turbo, complete fuel system, probably a bigger fmic, ditch the intake, standalone of some sort, crazy head work, bigger cams, etc etc. The car sounds good man, but your goals are unrealistic with what you have right now. If you do end up going crazy with it, just be ready to spend lots and lots of money.
D Money is offline   Reply With Quote
Old 02-25-2010, 10:36 PM   #10
Tay06wrx
Member#: 185673
2006 WRX
Why not go rotated and get that new HTA3586? I'm no expert by any means but people seem to be making crazy power with that turbo. Plus it seems like going rotated would yield you more of a gain. Someone correct me if i'm wrong, don't wanna give you any bad or misleading info.
Tay06wrx is offline   Reply With Quote
Old 02-25-2010, 10:45 PM   #11
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
whats funny about this, i made 510whp at 26 psi on a dynapack on California 91, not sure if you know this or not but ca 91 is garbage, to add c16 and 11 extra pounds of boost it will make over 600whp on the same dyno. at least. so to think that about 10 more psi and a 75 shot of nitrous wont make an extra 200whp is foolish, obviously the bolt on gt35 alone wont make to much over 600whp pushed to the limit but with nitrous im confident i can squeeze another 100whp out no sweat and of course im not going to run race fuel and nitrous everyday... once in a while so im pretty sure my engine will be fine for a few pulls at that kinda stress level
Old 02-25-2010, 10:46 PM   #12
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
im already happy with the turbo i have, i considered going rotated but i like the factory appearance this turbo has.
Old 02-25-2010, 10:46 PM   #13
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
PTE 6262
Old 02-25-2010, 11:02 PM   #14
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
on a block with drop in pistons and rods you want to run 35psi and nitrous? You won't even make it off the dyno.
Old 02-25-2010, 11:06 PM   #15
berdugo
Member#: 163108
07 EuroDM STi 2.5L
nice goal. you need to upgrade your fuel system and be careful with the nitrous kit, it can give you tons of problems or can blow up your engine. you need to do some extensive research with nitrous
berdugo is offline   Reply With Quote
Old 02-25-2010, 11:09 PM   #16
corzy666
Member#: 177840
2000 swapped RS
White 330whp
I agree that you probably won't make 700whp.
You need to really build the engine and get a bigger turbo if you REALLY want 700awhp.
And by the way a 75 shot of nitrous adds 75hp at the crank.
corzy666 is offline   Reply With Quote
Old 02-25-2010, 11:12 PM   #17
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
the cooling properties of the nitrous alone make power with a 50 shot i made 63whp w/o any tunning
Old 02-25-2010, 11:15 PM   #18
berdugo
Member#: 163108
07 EuroDM STi 2.5L
interesting. what brand of nitrous kit are you using? does it have progressive controller?
Old 02-25-2010, 11:19 PM   #19
MRX WRX
Member#: 114566
2005 STI
aspen white
on a turbo car a 75 shot makes about 85 at the wheels give or take. NOS cools the charge air dramatically.
MRX WRX is offline   Reply With Quote
Old 02-25-2010, 11:40 PM   #20
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Will you make 700 on that dyno before it blows up, maybe. But considering your results on 91, that dyno is EXTREMELY generous and I can't imagine anyone considering that a legit number. GL
OppositeLock is offline   Reply With Quote
Old 02-26-2010, 12:06 AM   #21
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
NO.1 your turbo without being rotated will be at or past its efficiecy range due to the turbine side on stock location not being as efficient as rotated.NO.2 big boost + spray = cracked sleeve-guarenteed.Also you did not list any headwork,so without it no way.Trust me I have built quite a few 600+whp suby's and your set-up even with spray might make 600whp maybe,remember once you get within a few pounds psi of the limits of your turbo every extra pound of boost might net you 5whp.I am not trying to be a jerk or anything but I am just stating facts from past experiences and set-ups I have done for customers.
john 1badSTI is offline   Reply With Quote
Old 02-26-2010, 12:10 AM   #22
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
I have personally only seen 2 cars make 700WHP with a standard 35r. 1 was a inline 6 with a 50 shot and the other was a concrete block 4g63 with ALOT_ALOT of boost. Both barley cracked 700whp, both trapped over 145mph.
I doubt the atp will make 700 AWHP on the Ej25, even with 100shot all you are going to make is TQ, which is going to toss those little eagle rods out the block.
Junior2JZ is offline   Reply With Quote
Old 02-26-2010, 12:13 AM   #23
john 1badSTI
Member#: 77470
^^^well said JR.Hey JR when the hell is nice weather gonna get here?
Old 02-26-2010, 12:30 AM   #24
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Can the ATP 35r push 35 psi of boost? I thought I heard those stock location boys were hitting a brick wall @ 29-30psi...?.?.? Anyone confirm this?
TDagen is offline   Reply With Quote
Old 02-26-2010, 12:33 AM   #25
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
using nx stage one efi kit with msd window switch, fuel pressure switch, and electronic wot switch
700+WHP BUILDUP-I have an EJ22 and I want to stroke it with an EJ25 crank WRXINTX Built Motor Discussion 13 12-03-2008 09:15 AM
350 WHP goal, turbo? injectors? Mecanic07 Newbies & FAQs 42 04-29-2008 10:06 AM
Video of 700 whp m3 trying to autocross ProjectL Motorsports 15 03-05-2008 10:40 AM
WHP Goals for a 30r Subiemaddness Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 02-11-2008 07:38 PM
350+ whp....goal on pump whats needed. Porkchop-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 12-05-2003 05:51 PM
