Old 02-26-2010, 11:10 AM   #1
Mac323
Member#: 108505
Default Finally Finished: TSR-70 Kit, Cosworth Manifold, Build Motor + MORE
With the 3000 directions my car has taken since i purchased her in 2006, she is finally squared away and is everything I have hoped for. Of course, as everyone knows, there are still some things I want to add, as modding cars is never FINISHED, but this should give you guys an idea of what the most recent set of mods looks like.
My goal for the car was something that was fast, handled well, and flew under the radar (as much as any STI possibly could).
Here she is the first week after purchase. Getting some tints!
Heres how she turned out.
Mod List:
Exterior:
-Wingless Trunk (de-badged)
-Window Tint (30% sides, 20% rear)
-Painted WRX Sideskirts
-BFC Modified Headlights (TSX Lenses, Painted, Cleared)
-BFC Custom Front and Rear Emblems
-Full Sticker De-badge of Entire Car
-Roof Vane Removed
-JDM Roof Vent
-JDM Rain Guards
-KS-Tech Hood Scoop Delete
Interior:
-Full 2006 WRX Interior (Black / Gray)
-Forester Din Pocket
-Alpine IDA-x305 Head Unit
-AEM Boost Gauge in Defi Pod (On A-pillar)
-Killer-B Type R Shift Knob
-Painted Gauge Cluster
Suspension:
-BC Racing Inverted Coilovers
-BC Racing Front and Rear Camber Plates
-Whiteline Front and Rear Sway Bars
-Whiteline Ball Joint and Tie-Rod Extenders
-Kartboy Front and Rear Endlinks
-Cusco Rear Underbrace
Drivetrain:
-Exedy Twin Plate Clutch
-Cusco Motor and Transmission Mounts
-Kartboy Pitch-Stop Mount
-Kartboy Exhaust Hangers x4
Brakes:
-Stock
Wheels / Tires:
-Stock Silver 17x8 (5x114.3) BBS Wheels
-Falken RT-615 Tires (255/40/17)
-McGuard Spline Drive Lug Nuts
LongBlock:
-Weisco 100mm Pistons
-Eagle H-Beam Rods w/ ARP Rod Bolts
-ACL Race Main and Rod Bearings
-Modified 2008 STI Oil Pump
-Gates Racing Kevlar Timing Belt
-Brian Crower 272/272 AVCS Camshafts
-Brian Crower Valve Springs
-Brian Crower Titanium Retainers
-One Step Colder Spark Plugs
-Killer-B Ultimate Oil Pickup
Bolt Ons:
-APS TSR-70 Twinscroll Rotated Turbo Kit
-APS Downpipe
-APS DR725 FMIC Core
-APS Split Pulse Header
-Cobb Tuning Cat Back Exhaust
-KS-Tech 86mm Cold Air Intake
-Cosworth intake Manifold (Reversed)
-Custom Top-Feed TGV Deletes
-Grimmspeed Phelonic Spacers (8mm)
-Grimmspeed Ported Throttle Body
-Custom 2.5" Intercooler Piping
-Tial 50mm Blow Off Valve
-Tial 44mm External Wastegate
-Hallman RX Manual Boost Controller
-Witch Hunter 1000cc Injectors
-Aeromotive Top-Feed Fuel Rails
-Custom -6 AN SS Fuel Lines and Fittings
-Aeromotive Quick Disconnect Fuel Fittings
-PandL Fuel Pressure Regulator w/ Aeromotive FPR Gauge
-BM Customs Catch Can
-Perrin Crank Pulley
-Ball Racing SS AVCS Lines
-Koyo Aluminum RS Radiator
-Mishimoto Slim Fans w/ Mounting Kit
-TIC Radiator T-Bolt Clamps
-Perrin Coolant Overflow
-ARC Upgraded Thermostat
-Cobb Accessport Version 2
Other:
-Gimmick Motorsports Hood Dampers
-Optima Red Top Battery (Relocated to Trunk)
-Taylor Aluminum Battery Box
-Custom Sheet Metal Radiator Shroud
-Powder Coated Brembo Calipers
-Weight Reduction
Last but not least, I wanted to thank those who helped with building my car.
Dave Brown @ MSPT
Gerry, Konrad, Mo, Colin, Mike, @ MSPT
Rob and Kenny @ Fizz Autosports NY
Adam, Rob, and Manny @ No Limit Motorsports
Rick G @ GT Spec / Rav Spec
Costas @ Rally Armor / LISC
Adam (BM-STI)
Shaun @ Unique Finish
JB @ Black Flame Customs
Mac323 is offline   Reply With Quote
Old 02-26-2010, 11:10 AM   #2
Mac323
Member#: 108505
Dyno Tuning Pictures, Plots, Videos.
After completing the motor/turbo build and finally getting everything broken in and situated, My tuner and I brought the car over to No Limit Motorsport in Medford, NY for a Dyno tune on February 20th, 2010. We had planned for both pump and c16 maps, however as everyone knows, nothing ever goes as planned.
Got the car on the dyno and after 5 Pulls we had to call it quits.
Here is what the 5th Pull got us to.
VIDEO!
Car made 460whp on NLM's Dyno Dynamics (CF of 1.12) on Pump Gas (93 octane) at just under 24psi. As you can see, once the car got to 6400rpm's we hit a wall, and the power flat-lined. We maxed out the MAF. With extrapolation, you can say that the pull by 7000rpms should have been closer to 480whp.
Spoke to Dave Brown @ MSPT today, and we decided to order a new intake from the guys over at KS-Tech to solve our issue. Hopefully sometime in the next two weeks we can get back to the dyno and get some final numbers for pump gas, as well as racegas.
Old 02-26-2010, 11:15 AM   #3
stikid2005
Member#: 76228
2005 STI (sold)
OBP Seibon carbon
very clean setup. And nice cosworth mani as well, hopefully next winter I will start my motor build.
stikid2005 is offline   Reply With Quote
Old 02-26-2010, 11:15 AM   #4
JustAnotherSubie
Member#: 185224
2013 EVO X GSR
Wicked White
Clean STi! Very sleeper!
JustAnotherSubie is offline   Reply With Quote
Old 02-26-2010, 11:16 AM   #5
spec b 002
Member#: 217716
2010 STI se
nasty sleeper
spec b 002 is offline   Reply With Quote
Old 02-26-2010, 11:16 AM   #6
Rube1966
Member#: 239231
2008 Sti
Sweet! Thats some serious HP!
Rube1966 is offline   Reply With Quote
Old 02-26-2010, 11:19 AM   #7
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
turned out nice Mac! You don't see any belt slipage with how you designed your pulley setup? The way you have it doesn't really give much "wrap" on the crank pulley and alt pulley. Other than that, she looks pretty!
D Money is offline   Reply With Quote
Old 02-26-2010, 12:39 PM   #8
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Car is looking great, cant wait for some Larger intake and C16 numbers
Keep it up!
RallySport Direct is online now   Reply With Quote
Old 02-26-2010, 12:45 PM   #9
dobsd001
Member#: 211176
Car is extemely subtle until the boot was planted.
Love it
dobsd001 is offline   Reply With Quote
Old 02-26-2010, 12:53 PM   #10
Mac323
Member#: 108505
Thanks Everyone!
D. I know there isnt much 'wrap' but so far I have not had a single issue, and there are a bunch of guys who run their setups this way, so I dont think it will be a problem.
Old 02-26-2010, 12:56 PM   #11
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
very nice! i really like your setup
shadowmd is offline   Reply With Quote
Old 02-26-2010, 01:02 PM   #12
F EVOZ
Member#: 134516
o2 WRX BlankitaRIP
o6 STi Blanca
congrats homie!
You deserve it man, been a long time coming
F EVOZ is offline   Reply With Quote
Old 02-26-2010, 01:06 PM   #13
StraightBoosted
Member#: 199196
2002 WRX Impreza
One word. CLEAN!
StraightBoosted is offline   Reply With Quote
Old 02-26-2010, 01:24 PM   #14
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
Talk about rotated. Any more and the turbo would be facing the shock tower!
cpunlamd is offline   Reply With Quote
Old 02-26-2010, 01:32 PM   #15
DTsubie
Member#: 196493
2005 STI
Oh my great looking STI
DTsubie is offline   Reply With Quote
Old 02-26-2010, 01:43 PM   #16
MKXIII
Member#: 130388
2007 WRX STI Limited
Urban Steel Gray Metallic
Thats because the TSR70 kit was R&D'd on a RHD car that has the master cylinders usual against the firewall, therefore they **** the turbo at even more of an extreme angle to clear them.
MK
MKXIII is offline   Reply With Quote
Old 02-26-2010, 02:23 PM   #17
1_STi_2NV
Member#: 197567
Nice looking sti...sleeper
1_STi_2NV is offline   Reply With Quote
Old 02-26-2010, 02:41 PM   #18
Mac323
Member#: 108505
Originally Posted by MKXIII View Post
MK,
I think you forgot the L.
lol.
Old 02-26-2010, 03:00 PM   #19
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
That is how you build a street car people. ****ing awesome.
Dolphin Overton is offline   Reply With Quote
Old 02-26-2010, 03:12 PM   #20
Mac323
Member#: 108505
Thanks man.
For those wondering. I would not say the build is 100% complete. The motor is for sure, as there is really not much more i wish to do besides having some things powdercoated (intake/ic pipes/ etc)
As for the rest of the car, there are some things i want to do to finish it all up.
The car will see the drag strip and a road course or two once it gets warmer out, but 99% of the time its a street car. With that in mind, i want to upgrade a few more things around the car, as well as Take some more weight out of it if possible while keeping a 100% stock, untouched look. Which means, Door cards, exterior pieces, rear seats, carpet, dash, will all remain intact.
Heres what I have in mind.
Drivetrain:
-ACPT Carbon Fiber Driveshaft
-Kartboy Short Shifter
-Various Kartboy/Tic Bushings
Exterior:
-Replica V-Limited Front Lip
-Redo Window Tint
-Shave Trunk
-PDR
Interior:
-Sparco Chrono Road Seats
-Sparco Bases / Sliders
-Innovate Wideband o2 Gauge Mounted in the Glove Box
-Convert Clock/HVAC/Door Switches/Key Ring to Red (InteriorFlair)
Brakes:
-Upgraded Pads (Unknown Brand/Model)
-Girodisc 2piece Front Rotors
-Girodisc 2piece Rear Rotors
-Girodisc SS Brake Lines
Suspension:
-Cusco Titanium Front Strut Bar
-Oswald Performance Subframe
-Oswald Performance Rear Strut Triangle
-TIC Fender Cowl Braces
Other:
-Oswald Performance Rear Bumper Beam
-Nitto NT05 (255/40/17) - To Replace Falken RT615 (255/40/17)
Once i get most of these parts, it will probably shave another 100 LBS off of the car. There are a few more "Free" things i can do to remove weight from the car. I can also stand to drop some weight, so that is in the works as well.
Old 02-26-2010, 03:28 PM   #21
MKXIII
Member#: 130388
Originally Posted by Mac323 View Post
MK,
lol.
haha yeah i did... never knew **** was a vulgar term, it describes a chicken after all...
MK
Old 02-26-2010, 04:53 PM   #22
zae
Member#: 239556
That manifold has got to be the ugliest thing ive ever seen. I know im a newbie, but what I will do for u is, take it off ur hands n I will put it on my future STi. Ill give u the red wrinkle stock one for free. See how nice I am lol
zae is offline   Reply With Quote
Old 02-26-2010, 07:30 PM   #23
bpang1
Member#: 67225
2015 Audi S4
Red
bad-ass sir...takes sleeper to another level.
bpang1 is offline   Reply With Quote
Old 02-26-2010, 09:06 PM   #24
chlnOrSlpn?
Member#: 97785
2015 WRB STi Limited
EFI Logics/CTSUBIE
Good to see it finally done man! I hope to see you at some meets this year!
chlnOrSlpn? is offline   Reply With Quote
Old 02-26-2010, 09:17 PM   #25
CatfaceType-R
Member#: 81102
awesome car, not that i've never seen it before or anything
CatfaceType-R is offline   Reply With Quote
FineLine - 2006STI APS TSR 70 Reverse Intake Manifold Fine Line Imports NASIOC Project Cars 85 02-17-2011 01:16 PM
2006 STI APS TSR 70 build Fine Line Imports Proven Power Bragging 15 02-23-2010 03:41 PM
APS twin scroll rotated turbo kit TSR-70 who would buy it or not? 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 237 02-07-2010 12:16 PM
For Sale: APS TSR 70 twin scroll turbo kit with intake and full race" reversed piping syoung0298 Engine/Power/Exhaust 25 09-23-2008 03:10 PM
Turbine inquiry about APS TSR 70 Twin Scroll Turbo Kit... nomorem3 Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-11-2006 02:59 PM
