Old 02-26-2010, 11:17 AM   #1
MyogiNightKid
Member#: 184576
98 BK EJ205
Default JDM EJ205 into BK
Im 1/2 through the wiring on my swap and I had a few queries before I button up the dash and start on the mechanical.
1) I know I need a turbo x-member, will a 07 GDF STi work?
2) Will I be able to retain OBD as long as the JDM ECU has OBD ?
MyogiNightKid is offline   Reply With Quote
Old 02-26-2010, 11:11 PM   #2
subyboy
Member#: 119432
2005 Impreza WRX
World Rally Blue
1) Yes you can use your stock a-arms but you will need to shim them to make them fit right.
2)The JDM ecus' are all obd1.
subyboy is offline   Reply With Quote
Old 02-27-2010, 08:42 AM   #3
MyogiNightKid
Member#: 184576
98 BK EJ205
What is needed to shim the A-Arms? Washers? Any visual aids?
Old 02-27-2010, 08:43 AM   #4
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
With an 07 GD chassis cross, your rack and pinion won't fit right.
Find a x-member from a bugeye, everything will be much easier.
DHRDAN is offline   Reply With Quote
Old 02-27-2010, 08:45 AM   #5
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
Yes washers... get stainless washers that fit the best. Not really that hard, but people tend to cheap out on this very crucial part.
Should cost no more than $10.
Old 02-27-2010, 09:32 AM   #6
MyogiNightKid
Member#: 184576
98 BK EJ205
There's also a '04 STi crossmember available, from what Ive read it will fit with 04 and below?
Will do, thanks! The bloke also has the entire front STi subframe for sale, so I may just go with the STi C/As and steering rack, but its a bit $$$
F/S (OH): 1998 BK Legacy w/ JDM EJ205 MyogiNightKid MWSOC Private Classifieds 55 07-22-2010 06:14 AM
FS : OH: 1998 BK Legacy w/ JDM EJ205 MyogiNightKid Private Vehicle 'For Sale' Classifieds 91 07-22-2010 06:13 AM
JDM BD/BG/BK projector headlights opened - pics inside subysouth Legacy Forum 36 10-20-2009 07:06 PM
Warehouse Clearance - JDM STI V7 EJ207, JDM STI V7 Hybrid, JDM EJ205 AVCS!! Gruppe-S Engine/Power/Exhaust 24 01-09-2007 10:07 PM
tips for USDM EJ205 to JDM EJ205 swap? Chuck H Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-16-2005 08:37 PM
